FIT (MTBF) of Verdin iMX8M Plus Q WIFI/BT
hello,
I need the FIT (MTBF) of the Verdin iMX8M Plus Q WIFI/BT PN:0064 2GB/RAM; 16GB/FLASH. Do you wave the Data?
thanks
Frank
I don’t have FIT (Failures in Time) or MTBF (Mean Time Between Failures) data for the Verdin iMX8M Plus Quad 2GB WB IT (PN: 0064) in the available documentation.
The sources provided include the product page, datasheets, and product change notifications for the Verdin iMX8M Plus family, but none of these documents contain FIT or MTBF specifications.
For reliability data such as FIT or MTBF calculations, I recommend:
  1. Contacting Toradex technical support directly through their support channels
  2. Checking if this information is available under NDA or as part of specific reliability documentation that may need to be requested separately
This type of reliability data is often provided on a case-by-case basis, especially for industrial applications requiring formal reliability documentation.
Hello @Flukas
the Toradex account manager responsible for your account has reached out to you to sign an NDA, that is required for us to share such information with you.
Once that is completed, we can provide those calculations via private channel
Best regards
hi @Flukas
your account manager has been trying to reach out to you unfortunately without success, without an NDA in place we can not share this information. If this is still relevant to you, please reach out to walid.allaham@toradex.com to sign the NDA.
best
