Filesystem library problems
This problem might be a little bit more software but I am not sure how to deal with it.
I want to configure my apalis imx6 to connect to a Filezilla server on a different device.
I am writing code one C++ with VS Code and ApolloX Torizon.
The problem is that I am trying to use the library. At first it gives no errors but when I press run and debug then I get the ‘filesystem’ has not been declared error.
From what I understood I have to configure something in tasks.json like the following:
"tasks": [
    "label": "build",
    "type": "shell",
    "command": "g++",
    "args": [
      "-g",
      "${file}",
      "-o",
      "${fileDirname}/${fileBasenameNoExtension}",
      "-lstdc++fs"
    "group": {
      "kind": "build",
      "isDefault": true
But I don’t know where exactly to put it in the file and what parameters I need to put here: "${fileDirname}/${fileBasenameNoExtension.
Also this is my code:
void connectToFtpServer(const string& serverAddress, const string& username, const string& password) {
    filesystem::path ftpUrl = "ftp://" + username + ":" + password + "@" + serverAddress + "/";
    cout << "Connecting to FTP server " << serverAddress << " as user " << username << std::endl;
    cout << "Listing directory contents:" << std::endl;
    for (const auto& entry : filesystem::directory_iterator(ftpUrl)) {
        cout << entry.path() << endl;
void uploadFileToFtpServer(const string& localFilePath, const string& remoteFilePath, const string& serverAddress, const string& username, const string& password) {
    filesystem::path remoteFileUrl = "ftp://" + username + ":" + password + "@" + serverAddress + "/" + remoteFilePath;
    cout << "Uploading file " << localFilePath << " to remote location " << remoteFileUrl << endl;
    filesystem::copy(localFilePath, remoteFileUrl, filesystem::copy_options::skip_existing);
    cout << "File uploaded succesfully" << endl;
I am not sure if this is because something is not configured in VS Code to use this library or something is not configured on my Torizon.
I checked the version of C++ in VS Code and it should be able to support the library.
Could you try to add add #include <filesystem> at the top of your code file, before any function declarations, to include the header file that declares the filesystem library?
I have done that already.
Hi @Svetoslav !
If I understood correctly, it is indeed related to software.
Therefore, I have a question:
If we for a moment forget about Apalis, Torizon, and ApolloX, are you able to create a program in your computer that successfully connects and communicates (file exchange) with the FTP server?
When I am developing something, I usually prefer to be sure that I am able to make it work without all the difficulties and specifics of the embedded system. Of course, it is not always possible to do this, but in your case, I think that it should be possible.
I can’t test the connection at the moment but my main problem is that the library is not recognized in the system I don’t know if the connection is even available since I can’t go pass the errors.
Hi @Svetoslav !
If the problem is with the usage of filesystem, you can try a simpler example, right?
Like creating a common file, moving, copying, etc.
Then you don’t even need the FTP.
It’s important to find ways to simplify the problem in order to solve it.
I already tried this.
Using filesystem for checking how much memory is used in a specific folder but it doesn’t work there either.
Is that wat you meant to try?
Dear @Svetoslav,
Could you get this simple program running on your development machine without any errors?
Does it work if you access the filesystem functions like this example: std::filesystem::path
Please take a look at this: https://stackoverflow.com/questions/55474690/stdfilesystem-has-not-been-declared-after-including-experimental-filesystem
Let me know if that helps :slight_smile:
Dear @Svetoslav,
Do you have any updates on this topic?
