File corruption after power loss on Docker volume
I’m experiencing an issue with file saving inside docker container on a defined volume.
Scenario:
Inside a Docker container, we write files to a bind-mounted volume pointing to a host directory (/home/root/configs).
After writing a file using either vim or a C application (which explicitly calls fsync() on the file descriptor), if the device is power-cut abruptly, the file appears truncated or corrupted upon reboot.
The same operation performed outside the container on the host does not result in corruption.
Technical Details:
The volume is defined in docker-compose.yml as:
    ```yaml
    driver_opts:
      type: none
      device: /home/root/configs
      o: bind,rw,sync,commit=1
The file is written with: open(), write(), fsync(), and close() in C.
However, even with this, the corruption still occurs if the device loses power before a clean shutdown.
From inside the container, the mount shows:
/dev/disk/by-label/otaroot on /root/logs type ext4 (rw,relatime)
→ indicating that mount options such as sync or commit=1 are not in effect.
Questions:
  • Are there any specific kernel or filesystem settings in TorizonCore that could interfere with data persistence even after calling fsync()?
  • Is there an official best practice from Toradex for ensuring data persistence inside containers under sudden power loss scenarios?
Thank you in advance for your support.
Riccardo
Hello Riccardo,
Thank you for the detailed description of your issue. I’ll address your questions step by step.
1. Behavior of Data Persistence, fsync(), and Filesystem Settings
Inside a Docker container using a bind mount to the host directory, when writing files and calling fsync(), you are ensuring data is flushed from userspace and the container environment down to the kernel and storage stack (1).
However, even with fsync(), data may still be buffered in the kernel or the storage device itself (such as eMMC), especially if the storage’s write cache is enabled and does not honor flushes or if unexpected power loss interrupts these processes.
Your observation—that files written directly on the host can survive power loss more reliably—might be due to differences in how data paths behave with containerization. However, in principle, fsync() called from within a container should be as effective as when called from the host, since bind mounts provide direct access to the underlying filesystem.
2. Docker Bind Mount Options and Limitations
  • The sync and commit=1 options you specified in docker-compose.yml are passed to the mount helper inside Docker, but for bind mounts, only the bind and ro/rw options have effect. Options like sync and commit=1 are ignored for bind mounts—they are not propagated to the base filesystem.
  • The actual base filesystem’s options (e.g., /dev/disk/by-label/otaroot mounted as ext4) determine the ultimate persistence characteristics. You would have to mount your root or relevant mount point with options like sync or commit=1 outside of Docker, at the OS level, for them to take effect.
3. Toradex Best Practices and Additional Protection
Please refer to these best-practice guidelines:
Key recommendations:
  1. eMMC Write Reliability: Ensure that your module’s eMMC is write-reliability enabled. This minimizes the risk of data corruption during a sudden power loss. You can check this in U-Boot by mmc info and confirm the presence of WRREL. (2)
  2. Host Mount Options: If your application relies on enhanced data consistency, remount your host filesystem (e.g., ext4) with additional safety options such as sync or a smaller commit interval (commit=1). For example:
    mount -o remount,sync /dev/disk/by-label/otaroot /
    But be aware: using sync can drastically decrease performance and increase flash wear.
  3. Application-level Protection: Continue calling fsync() after every critical write. Avoid using O_SYNC or mounting with sync unless absolutely necessary, as these have significant performance penalties.
  4. Consider Docker Volumes: While bind mounts are common, Docker volumes may provide a slightly improved abstraction, but ultimate behavior is still governed by the host filesystem. (1)
  5. Torizon/OSTree Safety: TorizonCore, when updating with OSTree, uses atomic operations for upgrades, but this doesn’t apply to generic application data written at runtime—so the above precautions are still needed for your files (3).
Summary Table
Setting Where to Change Effect
sync, commit=1 OS-level mount options Yes, affects disk writes
Application fsync() Your C application Flushes to kernel and storage
Write-reliability eMMC config Enables atomic sector writes
Docker mount options Only bind,rw for bind Others ignored for bind mounts
Final Notes
  • The filesystem’s commit interval and cache handling may cause you to see data loss even after fsync() if the storage hardware does not honor flushes or loses power in the middle of transferring blocks.
  • True power-loss safety is very difficult to achieve in software alone, but all of the above can reduce the risk.
For further reading:
If you need details on checking or setting eMMC write reliability, or adjusting host mount options at runtime, let me know and I can provide specific commands.
Greetings @raccoman,
Not that we are aware of.
We don’t have any specific recommendations. We usually would just say the usual recommendations with data persistence. Doing syncs after important file operations and such.
When you say “file corruption” is observed what do you observe exactly?
Also I noticed you’re on a somewhat old version of Torizon (5.7.2). As a sanity check could you perhaps try on a newer version of Torizon OS. Perhaps the newer versions of the kernel or Docker would improve or fix your use-case. I haven’t heard of such reports of file corruption recently. So either no one else is doing sudden power losses with no proper shutdown on their devices (unlikely), or maybe the situation really is improved on the newer versions.
If the newer versions do not address your issue, then perhaps you could share your exact steps for running your container, writing the file, and shutting down the device for further analysis and reproduction attempts.
Here is my tdx-info:
Bootloader: U-Boot
Kernel version: 5.4.193-5.7.2+git.b60d3160fd04 #1-TorizonCore SMP PREEMPT Fri Dec 23 15:47:24 UTC 2022
Kernel command line: pci=nomsi root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/462f211b372fbfea3c16e9154648bd2052363f5fc9f9e464b6258d18a435d5eb/0
Distro name: NAME=“TorizonCore”
Distro version: VERSION_ID=5.7.2-build.20
Distro variant: VARIANT=“Docker”
Hostname: apalis-imx8-15310204
HW model: Toradex Apalis iMX8QM V1.1 on Apalis Evaluation Board
Toradex version: 0067 V1.1A
Serial number: 15310204
Processor arch: aarch64
Available block devices:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 1 30M 0 disk
sda1 8:1 1 30M 0 part /var/rootdirs/media/PlutoSDR
mmcblk0 179:0 0 29.1G 0 disk
mmcblk0p1 179:1 0 29.1G 0 part /sysroot
mmcblk0boot0 179:32 0 4M 1 disk
mmcblk0boot1 179:64 0 4M 1 disk
Step to reproduce:
  1. Create example container: docker run --privileged -v /home/torizon:/home -v /dev:/dev -v /var/run/dbus:/var/run/dbus -v /etc/os-release:/etc/host-os-release -d --restart always --name debian --network host --env-file .env -w /home/ torizon/debian:2.6.0-bullseye sh -c "tail -f /dev/null"
  2. Install vim package: docker exec -w /home/ debain sh -c 'apt-get update && apt-get install -y vim
  3. Create file inside the volume: docker exec -it debian echo "test" > test.txt
  4. Wait from 1 to 5 seconds and cut off the power to the toradex
  5. Wait for the reboot, and check on the host with cat test.txt that the file is empty, partial (if you use fsync inside a C program) or missing
I noticed that if we wait from 15s to 20s then file is persistent after power cycle, this make me think that there’s some kind of period interval inside docker that persist the file (?)
If you perform the same steps directly on the host, with power cut off in less then 1s from when the file has been created there aren’t any issues.
Okay I was able to reproduce similar results using similar steps as you described. However, I was also pretty easily able to get a empty file write when creating a file on the host as well and immediately cutting power.
This isn’t really a unique aspect of containers. Maybe file writes are a touch slower in containers, but file writes being left incomplete due to power cuts is a generic problem overall.
In this case the recommendation would be similar to how the issue is dealt with generally. If you have a critical file write/operation that must be written to disk even if a power cut occurred right after the operation, then using sync is the only way to guarantee the operation is flushed to the disk.
This works even in a container with a volume/bind-mount as I just tried for myself to be sure.
I do use fsync inside my C prgram, but I still get the issue… How did you performed the sync test?
Well, I didn’t do a C program. Going off the steps you provided I just wrote the file like so echo "test" > test.txt" && sync, so I ran the actual sync CLI command. Then I powered the device down within 1 second of executing this command. As long as I executed sync I never noticed any issues with the file write being completed properly.
There may be some underlying difference between fsync and sync since you’re trying to sync a file process that goes between two filesystems (the container and host filesystems).
So what do you recommend? How can I have the same behavior of sync on host while being inside the container?
As per my test sync seems to do the job compared to fsync. Perhaps a method involving executing sync from your C application would suffice. I don’t have much more to add as executing sync would always result in the file being written to disk fully as far as I could observe in my own tests.
@jeremias.tx we are running into this same issue. A file “touch” on a docker volume, followed by a sync() OS system call and a sleep of 1 second and then a reboot. The file does not reliably exist on the reboot.
Does anybody have an explanation of what is going on and what can be done about it?
My theory is that sync() is flushing blocks to the flash driver but the flash driver and/or flash chip is buffering these blocks. Is there anyway to determine that the driver and/or the flash chip has gone idle?
Found this command to see if the chip is busy with background processing:
sudo mmc extcsd read /dev/mmcblk2 | awk '/BKOPS_STATUS/ { print substr($5, 0, 4) }'
If that reports “0x00” it’s idle.
After a large 1GB file copy, it reported “0x02” for nearly 20 seconds after a sync CLI command ran and completed.
EDIT:
tdx-info details of our board:
Software summary
Kernel version:           6.6.101-7.4.0-devel-g557af2783d91 #1-Torizon SMP PREEMPT Thu Sep 25 07:49:28 UTC 2025
Kernel command line:      root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/8f8755c6d2d0536d92e659dbe395a0fed35d62a92e434f17d3ad4ad198b3594e/0 clk-imx8mp.mcore_booted=1
Distro name:              NAME="Torizon OS"
Distro version:           VERSION_ID=7.4.0-devel-20251114174422-build.0
Hostname:                 verdin-imx8mp-15697662
Hardware info
HW model:                 Toradex Verdin iMX8M Plus WB on Yavia Board
Toradex version:          0058 V1.1B
Serial number:            15697662
Just some ideas. Was the sync ran from the perspective of the Docker container or the host OS? Perhaps this makes a difference since ultimately via the Docker volume you want the file to persist on the host OS filesystem.
Another thing I found is that when defining a Docker volume you can pass mount options similar to how they would be defined in /etc/fstab: Volumes | Docker Docs
Maybe specifying mount options like sync on the Docker volume would help with the reliability of writing larger files.
It turned out this was a red-herring. The problem was elsewhere. Thanks for your response, though!
The background behavior of the chip is interesting but I’d have to assume that is just book-keeping operations that are durable in the face of a reset.
Just to have the information here for others. What was the problem in your case? If you don’t mind sharing this information.
The file was being durably created. On reboot, it was a race condition between checking the file’s existence in one piece of code and removing it in another piece of code.
I see it was an application level issue. Well thank you for clarifying.
