we developed our own Qt application with the Qt Creator and an SDK built with yocto and BSP6.
An SVN repository with login access on a company server is used for software versioning.
To add the Qt application to our image, I created a recipe to generate it from the source code when building the image.
Therefore I set the SRC_URI to the following:
SRC_URI = "svn://<repo_path>;module=<name>;protocol=http;rev=HEAD"
But fetching fails with the following error:
/usr/bin/env svn --non-interactive --trust-server-cert co --no-auth-cache --ignore-externals -r HEAD http://<repo_path>/<name>@HEAD <name> failed with exit code 1, output:
svn: E170013: Unable to connect to a repository at URL 'http://<repo_name>/<name>'
svn: E215004: No more credentials or we tried too many times.
Authentication failed
The credentials for the SVN repository are stored on my build machine under ~/.local/share/keyrings/Default.keyring
When I call the first line of the error output in a console in the home directory of my build machine the repository is checked out correctly.
Why doesn’t yocto use the saved login data?
Markus
