grh
January 26, 2021, 9:27pm
1
I can successfully fetch and push from my private git repo using my generated ssh keys, but when I point my Yocto recipe to the same repo, I get an authentication error, as if it is not able to find the ssh keys during the Yocto build.
Any suggestions?
alex.tx
February 2, 2021, 10:07pm
2
We have newer try to use Yocto with password protected repositories. I’d recommend to use a https://www.yoctoproject.org/community/ for help.
grh
February 19, 2021, 3:52pm
3
Actually, I managed to figure it out. I specified the SRC_URI in my recipe as follows:
git://git@blah.github.com/GitHubAccountName/repo-name.git
Then, in my .ssh/config file on my build machine, I specified which keys to use for a given Host, like this:
Host blah.github.com
Hostname github.com
PreferredAuthentications publickey
IdentityFile ~/.ssh/id_myprivatekeyfile
The key appears to be that the blah.github.com value in the SRC_URI must match a valid Host value in the .ssh/config file.
These two links gave me the clues I needed:
https://stackoverflow.com/questions/3225862/multiple-github-accounts-ssh-config
https://goinpaths.gitlab.io/post/yocto-tips/
alex.tx
February 19, 2021, 8:45pm
4
Thanks for sharing a solution.
SRC_URI must include protocol=ssh. Here is how to clone repo from private GitLab when ssh is already configured on the machine:
SRC_URI += "git://git@private-gitlab.com:/root/project.git;protocol=ssh;branch=main"
Is there any way to provide username and password for git repo in SRC_URI using https protocol?
Prathamesh Kulkarni
Hi @prathamesh.kulkarni ,
Have you tried something like the following?
SRC_URI = "git://git@bitbucket.org/myworkspace/myrepo.git;protocol=https;user=myusername:my-app-password;"
Although this is for Bitbucket, you can try to add “user=” at the end of the link.
More information on SRC_URI: 5 Variables Glossary — Bitbake dev documentation
Please, if you have more questions regarding this issue, can you open a new ticket? This is an old ticket and it’s already solved.
Hiago.
