Using the above command, I have successfully built the SDK.
tdx-xwayland-upstream-glibc-x86_64-meta-toolchain-qt5-upstream-armv7at2hf-neon-apalis-imx6-toolchain-6.5.0.sh
After setting up Kit in Qtcreator using the above toolchain, when i create a using qmake, it works perfectly, but it gives me a fatal error with cmake.
fatal error: gnu/stubs-soft.h: No such file or directory
“I’m not sure what is going wrong here. Can you please offer any assistance?”
Let me know if there is any additional information that I can provide to help solve the issue.
Thanks for asking your question on Toradex community!
Regarding your question, the information shared do not give much to suggest cause of error or what happened wrong. Unfortunately we do not direct article available at the moment for using cmake to cross compile to help you with steps. If you can share steps what you followed and at what steps you get this error, we can try to test same at our end.
That said please re-check if you have configure your terminal for cross compiling.
Once the SDK is built, it creates a script file in the deploy/sdk/tdx-xwayland-upstream-glibc-x86_64-meta-toolchain-qt5-upstream-armv7at2hf-neon-apalis-imx6-toolchain-6.5.0.sh.
I executed the script to acquire the SDK, which will installed the SDK in opt/tdx-xwayland-upstream/6.5.0.
Source the environment file and open Qt Creator IDE from the shell. The IDE automatically detects the arm-tdx-linux-gnueabi-g++ compiler.
After completing the necessary tasks to create Kit, I created a Qt project and attempted to build it using CMake, but encountered an error. Attached is my error log.
I have tried to modify the CMakeLists.txt file, but unfortunately, the changes did not have any effect.
After testing the BSP V2.8 SDK, I was able to cross-compile my Qt(Cmake) project without any ABI errors. I don’t know why it’s not working with BSP V6.
