I’m trying to build an image for a Colibri iMX7D 1GB following this guide on a virtual machine running Ubuntu 18.04.
I’m able to initialize repo but when I try to sync the repo, it fails.
Can you please tell me what I’m doing wrong?
I’ve installed repo initially installing the ‘phablet-tools’ package but it didn’t work. I’ve then unistalled the package and followed the installation procedure. The tool should be properly installed.
Git is also properly installed as I regularly use it in other projects.
I initialize repo:
repo init -u https://git.toradex.com/toradex-manifest.git -b dunfell-5.x.y -m tdxref/default.xml
Downloading Repo source from https://gerrit.googlesource.com/git-repo
remote: Counting objects: 4, done
remote: Finding sources: 100% (172/172)
remote: Total 172 (delta 95), reused 172 (delta 95)
Receiving objects: 100% (172/172), 160.12 KiB | 7.63 MiB/s, done.
Resolving deltas: 100% (95/95), completed with 26 local objects.
Downloading manifest from https://git.toradex.com/toradex-manifest.git
repo has been initialized in /home/estdev/oe-core
and then I try to sync it:
repo sync
Fetching: 0% (0/13) warming uperror: Cannot fetch meta-qt5.git from https://github.com/meta-qt5/meta-qt5.git
error: Cannot fetch bitbake.git from https://github.com/openembedded/bitbake.git
Fetching: 7% (1/13) bitbake.giterror: Cannot fetch meta-toradex-bsp-common.git from https://git.toradex.com/meta-toradex-bsp-common.git
error: Cannot fetch meta-freescale.git from https://github.com/Freescale/meta-freescale.git
error: Cannot fetch meta-toradex-demos.git from https://git.toradex.com/meta-toradex-demos.git
Fetching: 38% (5/13) meta-toradex-distro.giterror: Cannot fetch meta-toradex-tegra.git from https://git.toradex.com/meta-toradex-tegra.git
error: Cannot fetch meta-openembedded.git from https://github.com/openembedded/meta-openembedded.git
Fetching: 69% (9/13) meta-openembedded.giterror: Cannot fetch openembedded-core.git from https://github.com/openembedded/openembedded-core.git
Fetching: 100% (13/13), done in 1m9.343s
Garbage collecting: 100% (13/13), done in 0.170s
Fetching: 0% (0/8) warming uperror: Cannot fetch meta-freescale.git from https://github.com/Freescale/meta-freescale.git
Fetching: 50% (4/8) meta-toradex-bsp-common.giterror: Cannot fetch bitbake.git from https://github.com/openembedded/bitbake.git
Fetching: 100% (8/8), done in 1m8.357s
Garbage collecting: 100% (8/8), done in 0.035s
Fetching: 0% (0/4) warming uperror: Cannot fetch meta-freescale.git from https://github.com/Freescale/meta-freescale.git
Fetching: 100% (4/4), done in 1m2.586s
Garbage collecting: 100% (4/4), done in 0.015s
Fetching: 0% (0/3) warming uperror: Cannot fetch meta-freescale.git from https://github.com/Freescale/meta-freescale.git
Fetching: 100% (3/3), done in 36.237s
Garbage collecting: 100% (3/3), done in 0.025s
fatal: failed to unpack tree object HEAD
error.GitError: Cannot checkout meta-freescale.git: Cannot initialize work tree for meta-freescale.git
error: Cannot checkout meta-freescale.git
error.GitError: Cannot checkout meta-openembedded.git: Cannot initialize work tree for meta-openembedded.git
error: Cannot checkout meta-openembedded.git
error.GitError: Cannot checkout openembedded-core.git: Cannot initialize work tree for openembedded-core.git
error: Cannot checkout openembedded-core.git
Checking out: 100% (13/13), done in 0.842s
error: Unable to fully sync the tree.
error: Downloading network changes failed.
error: Checking out local projects failed.
Failing repos:
layers/meta-freescale
layers/meta-openembedded
layers/openembedded-core
Try re-running with "-j1 --fail-fast" to exit at the first error.
Thank you
