dmesg
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.14.52-v2.6b2+g9ace52b (fabatera@debian) (gcc version 5.2.1 20151005 (Linaro GCC 5.2-2015.11-2) ) #2 SMP Th6
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Toradex Apalis iMX6Q/D Module on Ixora Carrier Board
[ 0.000000] cma: CMA: reserved 320 MiB at 62000000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 524288
[ 0.000000] free_area_init_node: node 0, pgdat 80929fc0, node_mem_map d0f57000
[ 0.000000] DMA zone: 3264 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 417792 pages, LIFO batch:31
[ 0.000000] HighMem zone: 832 pages used for memmap
[ 0.000000] HighMem zone: 106496 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 7 pages/cpu @d0f0d000 s7936 r8192 d12544 u32768
[ 0.000000] pcpu-alloc: s7936 r8192 d12544 u32768 alloc=8*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 521024
[ 0.000000] Kernel command line: enable_wait_mode=off vmalloc=400M ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext3 rootwait fec_M
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Memory: 1740748K/2097152K available (6555K kernel code, 277K rwdata, 2180K rodata, 335K init, 417K bss, 356404K reserved, )
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe6800000 - 0xff000000 ( 392 MB)
[ 0.000000] lowmem : 0x80000000 - 0xe6000000 (1632 MB)
[ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
[ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
[ 0.000000] .text : 0x80008000 - 0x80890064 (8737 kB)
[ 0.000000] .init : 0x80891000 - 0x808e4f00 ( 336 kB)
[ 0.000000] .data : 0x808e6000 - 0x8092b480 ( 278 kB)
[ 0.000000] .bss : 0x8092b488 - 0x80993a48 ( 418 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] L310 cache controller enabled
[ 0.000000] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1024 kB
[ 0.000000] Switching to timer-based delay loop
[ 0.000007] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
[ 0.000848] Console: colour dummy device 80x30
[ 0.001255] console [tty1] enabled
[ 0.001285] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[ 0.001315] pid_max: default: 32768 minimum: 301
[ 0.001488] Mount-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.001510] Mountpoint-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.009514] Initializing cgroup subsys debug
[ 0.009538] Initializing cgroup subsys freezer
[ 0.009577] CPU: Testing write buffer coherency: ok
[ 0.009928] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.010020] Setting up static identity map for 0x1066c9e0 - 0x1066ca38
[ 0.011772] CPU1: Booted secondary processor
[ 0.011798] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.012636] CPU2: Booted secondary processor
[ 0.012657] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.013484] CPU3: Booted secondary processor
[ 0.013506] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.013608] Brought up 4 CPUs
[ 0.013689] SMP: Total of 4 processors activated (24.00 BogoMIPS).
[ 0.013706] CPU: All CPU(s) started in SVC mode.
[ 0.014318] devtmpfs: initialized
[ 0.018167] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.018524] pinctrl core: initialized pinctrl subsystem
[ 0.018900] regulator-dummy: no parameters
[ 0.045735] NET: Registered protocol family 16
[ 0.054243] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.054914] cpuidle: using governor ladder
[ 0.054933] cpuidle: using governor menu
[ 0.055218] CPU identified as i.MX6Q, silicon rev 1.5
[ 0.055328] Use WDOG1 as reset source
[ 0.065208] syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
[ 0.065544] vdd1p1: 800 <--> 1375 mV at 1100 mV
[ 0.065930] vdd3p0: 2625 <--> 3400 mV at 3000 mV
[ 0.066300] vdd2p5: 2000 <--> 2750 mV at 2400 mV
[ 0.066666] vddarm: 725 <--> 1450 mV at 1150 mV
[ 0.070514] vddpu: 725 <--> 1450 mV
[ 0.070873] vddsoc: 725 <--> 1450 mV at 1175 mV
[ 0.072917] syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
[ 0.075521] syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
[ 0.080919] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.080947] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.081804] imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.096954] bio: create slab <bio-0> at 0
[ 0.097763] 1P8V: 1800 mV
[ 0.097986] 2P5V: 2500 mV
[ 0.098188] 3P3V: 3300 mV
[ 0.098494] usb_otg_vbus: 5000 mV
[ 0.098784] usb_host_vbus_hub: 5000 mV
[ 0.099061] usb_host_vbus: 5000 mV
[ 0.099126] usb_host_vbus: supplied by usb_host_vbus_hub
[ 0.099445] vgaarb: loaded
[ 0.100138] SCSI subsystem initialized
[ 0.100338] libata version 3.00 loaded.
[ 0.100625] usbcore: registered new interface driver usbfs
[ 0.100706] usbcore: registered new interface driver hub
[ 0.100815] usbcore: registered new device driver usb
[ 0.101783] i2c-gpio i2c.18: using pins 80 (SDA) and 62 (SCL)
[ 0.103216] i2c i2c-1: IMX I2C adapter registered
[ 0.105144] stmpe-i2c 2-0041: stmpe811 detected, chip id: 0x811
[ 0.107086] i2c i2c-2: IMX I2C adapter registered
[ 0.107956] i2c i2c-3: IMX I2C adapter registered
[ 0.108116] Linux video capture interface: v2.00
[ 0.108168] pps_core: LinuxPPS API ver. 1 registered
[ 0.108185] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.108230] PTP clock support registered
[ 0.120548] imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.140543] imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.141406] MIPI CSI2 driver module loaded
[ 0.141627] Advanced Linux Sound Architecture Driver Initialized.
[ 0.143303] Switched to clocksource mxc_timer1
[ 0.153044] NET: Registered protocol family 2
[ 0.153981] TCP established hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.154158] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.154444] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.154597] TCP: reno registered
[ 0.154625] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.154701] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.154999] NET: Registered protocol family 1
[ 0.155326] RPC: Registered named UNIX socket transport module.
[ 0.155348] RPC: Registered udp transport module.
[ 0.155363] RPC: Registered tcp transport module.
[ 0.155376] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.155396] PCI: CLS 0 bytes, default 64
[ 0.156062] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[ 0.157176] imx rpmsg driver is registered.
[ 0.157490] imx_busfreq busfreq.16: DDR medium rate not supported.
[ 0.158033] Bus freq driver module loaded
[ 0.158986] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.160427] bounce pool size: 64 pages
[ 0.166029] VFS: Disk quotas dquot_6.5.2
[ 0.166315] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.167869] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.168596] NFS: Registering the id_resolver key type
[ 0.168656] Key type id_resolver registered
[ 0.168674] Key type id_legacy registered
[ 0.169345] fuse init (API version 7.22)
[ 0.169927] msgmni has been set to 3207
[ 0.172991] io scheduler noop registered
[ 0.173016] io scheduler deadline registered
[ 0.173201] io scheduler cfq registered (default)
[ 0.175367] backlight.17 supply power not found, using dummy regulator
[ 0.177710] MIPI DSI driver module loaded
[ 0.179423] mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
[ 0.179470] fbcvt: 1920x1080@60: CVT Name - 2.073M9
[ 0.179575] mxc_sdc_fb fb.20: registered mxc display driver hdmi
[ 0.198798] mxc_sdc_fb fb.20: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 0.213375] imx-ipuv3 2400000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
[ 0.247270] mxc_sdc_fb fb.20: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 0.282958] Console: switching to colour frame buffer device 240x67
[ 0.318914] mxc_sdc_fb fb.21: mxcfb1 is turned off!
[ 0.319065] mxc_sdc_fb fb.22: mxcfb2 is turned off!
[ 0.319219] mxc_sdc_fb fb.23: mxcfb3 is turned off!
[ 0.320727] imx-sdma 20ec000.sdma: no iram assigned, using external mem
[ 0.321158] imx-sdma 20ec000.sdma: no event needs to be remapped
[ 0.321499] imx-sdma 20ec000.sdma: loaded firmware 3.2
[ 0.324245] imx-sdma 20ec000.sdma: initialized
[ 0.325939] pfuze100-regulator 2-0008: Full layer: 2, Metal layer: 1
[ 0.326644] pfuze100-regulator 2-0008: FAB: 0, FIN: 0
[ 0.326738] pfuze100-regulator 2-0008: pfuze100 found.
[ 0.328267] SW1AB: 300 <--> 1875 mV at 1375 mV
[ 0.329684] SW1C: 300 <--> 1875 mV at 1375 mV
[ 0.330512] SW2: at 1000 mV
[ 0.331317] SW3A: 400 <--> 1975 mV at 1500 mV
[ 0.332157] SW3B: at 1500 mV
[ 0.332965] SW4: at 1000 mV
[ 0.333774] SWBST: 5000 <--> 5150 mV at 5000 mV
[ 0.334592] VSNVS: 1000 <--> 3000 mV at 3000 mV
[ 0.334831] VREFDDR: 750 mV
[ 0.335621] VGEN1: 800 <--> 1550 mV at 1500 mV
[ 0.336464] VGEN2: 800 <--> 1550 mV at 1500 mV
[ 0.337297] VGEN3: 1800 <--> 3300 mV at 3000 mV
[ 0.338126] VGEN4: 1800 <--> 3300 mV at 1800 mV
[ 0.338966] VGEN5: 1800 <--> 3300 mV at 2500 mV
[ 0.339797] VGEN6: 1800 <--> 3300 mV at 2800 mV
[ 0.340157] Serial: IMX driver
[ 0.340616] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58, base_baud = 5000000) is a IMX
[ 1.272506] console [ttymxc0] enabled
[ 1.277101] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
[ 1.286343] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 61, base_baud = 5000000) is a IMX
[ 1.295547] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 62, base_baud = 5000000) is a IMX
[ 1.308527] serial: Freescale lpuart driver
[ 1.317162] imx sema4 driver is registered.
[ 1.325324] [drm] Initialized drm 1.1.0 20060810
[ 1.334283] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[ 1.351302] brd: module loaded
[ 1.362032] loop: module loaded
[ 1.369124] at24 1-0050: 256 byte 24c02 EEPROM, writable, 1 bytes/write
[ 1.380575] ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
[ 1.392471] ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
[ 1.404419] ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
[ 1.416522] ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
[ 1.431528] ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
[ 1.442468] ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 1.455248] ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 1.469722] scsi0 : ahci_platform
[ 1.477372] ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 71
[ 1.492394] spi_imx 2008000.ecspi: probed
[ 1.501417] tun: Universal TUN/TAP device driver, 1.6
[ 1.510659] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.521180] vcan: Virtual CAN interface driver
[ 1.529786] CAN device driver interface
[ 1.537931] 2090000.can supply xceiver not found, using dummy regulator
[ 1.549507] flexcan 2090000.can: device registered (reg_base=e69f0000, irq=142)
[ 1.561082] 2094000.can supply xceiver not found, using dummy regulator
[ 1.572600] flexcan 2094000.can: device registered (reg_base=e69f8000, irq=143)
[ 1.585083] 2188000.ethernet supply phy not found, using dummy regulator
[ 1.613689] pps pps0: new PPS source ptp0
[ 1.623194] libphy: fec_enet_mii_bus: probed
[ 1.633065] fec 2188000.ethernet eth0: registered PHC device 0
[ 1.643222] PPP generic driver version 2.4.2
[ 1.651674] PPP BSD Compression module registered
[ 1.660342] PPP Deflate Compression module registered
[ 1.669419] PPP MPPE Compression module registered
[ 1.678249] NET: Registered protocol family 24
[ 1.686790] usbcore: registered new interface driver asix
[ 1.696302] usbcore: registered new interface driver ax88179_178a
[ 1.706475] usbcore: registered new interface driver cdc_ether
[ 1.716390] usbcore: registered new interface driver cdc_eem
[ 1.726057] usbcore: registered new interface driver net1080
[ 1.735692] usbcore: registered new interface driver cdc_subset
[ 1.745593] usbcore: registered new interface driver zaurus
[ 1.755143] usbcore: registered new interface driver cdc_ncm
[ 1.764735] usbcore: registered new interface driver huawei_cdc_ncm
[ 1.774899] usbcore: registered new interface driver qmi_wwan
[ 1.784479] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.794893] ehci-pci: EHCI PCI platform driver
[ 1.803367] usbcore: registered new interface driver cdc_acm
[ 1.812952] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.825046] usbcore: registered new interface driver cdc_wdm
[ 1.833339] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.833383] ahci-imx 2200000.sata: no device found, disabling link.
[ 1.833390] ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
[ 1.865958] usbcore: registered new interface driver usb-storage
[ 1.876344] usbcore: registered new interface driver usbserial
[ 1.886466] usbcore: registered new interface driver usbserial_generic
[ 1.897283] usbserial: USB Serial support registered for generic
[ 1.907603] usbcore: registered new interface driver ftdi_sio
[ 1.917630] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.929199] usbcore: registered new interface driver option
[ 1.938985] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.950244] usbcore: registered new interface driver pl2303
[ 1.960160] usbserial: USB Serial support registered for pl2303
[ 1.970392] usbcore: registered new interface driver qcserial
[ 1.980473] usbserial: USB Serial support registered for Qualcomm USB modem
[ 1.992785] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 2.009177] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 2.018479] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 2.043331] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 2.053898] hub 1-0:1.0: USB hub found
[ 2.062016] hub 1-0:1.0: 1 port detected
[ 2.074069] ci_hdrc ci_hdrc.1: doesn't support gadget
[ 2.085604] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.094797] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 2.123339] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.133744] hub 2-0:1.0: USB hub found
[ 2.141754] hub 2-0:1.0: 1 port detected
[ 2.150665] mousedev: PS/2 mouse device common for all mice
[ 2.169435] input: stmpe-ts as /devices/soc0/soc.0/2100000.aips-bus/21a4000.i2c/i2c-2/2-0041/stmpe-ts/input/input0
[ 2.187563] rtc-ds1307 1-0068: rtc core: registered m41t00 as rtc0
[ 2.198253] snvs_rtc 20cc034.snvs-rtc-lp: can't get snvs-rtc clock
[ 2.208821] check_alarm_past: alarm in the past
[ 2.217824] snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc1
[ 2.230587] i2c /dev entries driver
[ 2.239701] mxc_v4l2_output v4l2_out.34: V4L2 device registered as video16
[ 2.251136] mxc_v4l2_output v4l2_out.34: V4L2 device registered as video17
[ 2.262589] i2c-core: driver [mag3110] using legacy suspend method
[ 2.273036] i2c-core: driver [mag3110] using legacy resume method
[ 2.283736] imx2-wdt 20bc000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
[ 2.296359] watchdog: Software Watchdog: cannot register miscdev on minor=130 (err=-16).
[ 2.308757] watchdog: Software Watchdog: a legacy watchdog module is probably present.
[ 2.321111] softdog: Software Watchdog Timer: 0.08 initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
[ 2.336726] sdhci: Secure Digital Host Controller Interface driver
[ 2.347337] sdhci: Copyright(c) Pierre Ossman
[ 2.356100] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.368378] mmc1: no vqmmc regulator found
[ 2.423324] mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[ 2.435764] mmc0: no vqmmc regulator found
[ 2.463365] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 2.483324] mmc0: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
[ 2.499897] mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
[ 2.513044] mxc_vpu 2040000.vpu: VPU initialized
[ 2.544083] caam 2100000.caam: Instantiated RNG4 SH0
[ 2.587571] mmc0: BKOPS_EN bit is not set
[ 2.610177] mmc0: new high speed DDR MMC card at address 0001
[ 2.621313] mmcblk0: mmc0:0001 004G90 3.68 GiB
[ 2.631066] mmcblk0boot0: mmc0:0001 004G90 partition 1 2.00 MiB
[ 2.642323] mmcblk0boot1: mmc0:0001 004G90 partition 2 2.00 MiB
[ 2.653677] hub 2-1:1.0: USB hub found
[ 2.662385] hub 2-1:1.0: 4 ports detected
[ 2.672020] mmcblk0: p1 p2
[ 2.682108] mmcblk0boot1: unknown partition table
[ 2.693893] mmcblk0boot0: unknown partition table
[ 2.792639] caam 2100000.caam: Instantiated RNG4 SH1
[ 2.802273] caam 2100000.caam: device ID = 0x0a160100 (Era 4)
[ 2.812645] caam 2100000.caam: job rings = 2, qi = 0
[ 2.906546] caam algorithms registered in /proc/crypto
[ 2.920242] caam_jr 2101000.jr0: registering rng-caam
[ 2.930838] platform caam_sm: blkkey_ex: 4 keystore units available
[ 2.942088] platform caam_sm: 64-bit clear key:
[ 2.951261] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 2.961533] platform caam_sm: 64-bit black key:
[ 2.970633] platform caam_sm: [0000] a0 f9 8c 1a c7 c3 bd 1a
[ 2.970647] usb 2-1.1: new high-speed USB device number 3 using ci_hdrc
[ 2.991974] platform caam_sm: [0008] 2b 18 fa 6c 0c 76 6b c7
[ 3.002186] platform caam_sm: 128-bit clear key:
[ 3.011329] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 3.021467] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 3.031555] platform caam_sm: 128-bit black key:
[ 3.040556] platform caam_sm: [0000] a5 85 26 bc 47 bf 1d bc
[ 3.050590] platform caam_sm: [0008] d5 f0 f1 e7 bb 7a 21 72
[ 3.060576] platform caam_sm: 192-bit clear key:
[ 3.069532] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 3.079529] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 3.089518] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 3.099500] platform caam_sm: 192-bit black key:
[ 3.108405] platform caam_sm: [0000] ad cf cf 64 d9 41 f3 9a
[ 3.118344] platform caam_sm: [0008] 97 08 86 ac fd 62 5f 7a
[ 3.128280] platform caam_sm: [0016] 6b 6d 73 e8 1b d6 ba 0b
[ 3.138201] platform caam_sm: [0024] 23 9d a2 24 ee f7 4b 08
[ 3.148040] platform caam_sm: 256-bit clear key:
[ 3.156723] platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
[ 3.166456] platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
[ 3.176124] platform caam_sm: [0016] 10 11 12 13 14 15 16 17
[ 3.185756] platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
[ 3.195300] platform caam_sm: 256-bit black key:
[ 3.203757] platform caam_sm: [0000] 5f 9e 7b 85 e0 0f b2 ba
[ 3.213290] platform caam_sm: [0008] dd 44 82 f3 f7 9a ff d6
[ 3.222801] platform caam_sm: [0016] 08 d3 00 09 e5 19 ec 07
[ 3.232318] platform caam_sm: [0024] 76 6a 9e fe a9 aa cb 14
[ 3.241768] platform caam_sm: 64-bit unwritten blob:
[ 3.250472] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 3.259849] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 3.269095] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 3.269340] usb-storage 2-1.1:1.0: USB Mass Storage device detected
[ 3.287937] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 3.288123] scsi1 : usb-storage 2-1.1:1.0
[ 3.304510] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 3.313616] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 3.322641] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 3.331616] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 3.340521] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.349347] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.358083] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.366790] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.375442] platform caam_sm: 128-bit unwritten blob:
[ 3.383460] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 3.392066] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 3.400629] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 3.409223] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 3.417747] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 3.426254] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 3.434727] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 3.443141] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 3.451588] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.459979] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.468340] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.476668] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.484947] platform caam_sm: 196-bit unwritten blob:
[ 3.492599] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 3.500837] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 3.509047] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 3.517230] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 3.525377] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 3.533500] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 3.541545] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 3.549533] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 3.557493] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.565419] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.573332] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.581204] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.589048] platform caam_sm: 256-bit unwritten blob:
[ 3.596284] platform caam_sm: [0000] 00 00 00 00 00 00 00 00
[ 3.604142] platform caam_sm: [0008] 00 00 00 00 00 00 00 00
[ 3.611955] platform caam_sm: [0016] 00 00 00 00 00 00 00 00
[ 3.619775] platform caam_sm: [0024] 00 00 00 00 00 00 00 00
[ 3.627572] platform caam_sm: [0032] 00 00 00 00 00 00 00 00
[ 3.635340] platform caam_sm: [0040] 00 00 00 00 00 00 00 00
[ 3.643053] platform caam_sm: [0048] 00 00 00 00 00 00 00 00
[ 3.650755] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 3.658432] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.666100] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.673732] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.681313] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.689129] platform caam_sm: 64-bit black key in blob:
[ 3.696286] platform caam_sm: [0000] c4 6f 4f c1 55 4c b3 b2
[ 3.703896] platform caam_sm: [0008] a3 f2 15 14 66 cf 4d 79
[ 3.711482] platform caam_sm: [0016] fe af 0f dd 59 27 e4 49
[ 3.719074] platform caam_sm: [0024] 53 d7 17 af f9 bd 7b ef
[ 3.726663] platform caam_sm: [0032] 8d 64 23 35 0b 6b 1e 58
[ 3.734243] platform caam_sm: [0040] 0f 20 81 6c f8 2f 14 6f
[ 3.741812] platform caam_sm: [0048] 0a 90 ba 5c f0 a9 15 5e
[ 3.749375] platform caam_sm: [0056] 00 00 00 00 00 00 00 00
[ 3.756928] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.764492] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.772037] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.779531] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.786961] platform caam_sm: 128-bit black key in blob:
[ 3.794030] platform caam_sm: [0000] 68 6b fe cb 5f 9b 4f 3b
[ 3.801413] platform caam_sm: [0008] 38 49 03 34 d9 80 64 ff
[ 3.808838] platform caam_sm: [0016] 4b 5d 77 5d 9f 7c 52 c3
[ 3.816292] platform caam_sm: [0024] 67 4d f1 57 10 dc 2b b2
[ 3.823778] platform caam_sm: [0032] 13 e3 e0 4d 74 e9 22 29
[ 3.831274] platform caam_sm: [0040] 75 b1 75 6e 65 fe d5 15
[ 3.838797] platform caam_sm: [0048] 44 a2 da af 0d c7 59 8c
[ 3.846343] platform caam_sm: [0056] 3e 13 10 69 e3 69 80 b1
[ 3.853917] platform caam_sm: [0064] 00 00 00 00 00 00 00 00
[ 3.861464] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.868987] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.876522] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.884054] platform caam_sm: 192-bit black key in blob:
[ 3.891247] platform caam_sm: [0000] 0e fc 24 4e 2b 26 3c 24
[ 3.898839] platform caam_sm: [0008] 53 b9 db fb 63 3e ac ae
[ 3.906457] platform caam_sm: [0016] 18 26 17 71 dc dd 05 ea
[ 3.914103] platform caam_sm: [0024] 14 df ff f6 45 dd c8 93
[ 3.921746] platform caam_sm: [0032] 0b bb a0 cc 25 a8 d4 52
[ 3.929434] platform caam_sm: [0040] 9b 70 1a 07 79 b3 58 d8
[ 3.937147] platform caam_sm: [0048] a5 c2 92 dc 68 5a 18 54
[ 3.944875] platform caam_sm: [0056] f5 6d d8 43 26 e4 68 e6
[ 3.952623] platform caam_sm: [0064] 83 84 c6 75 81 e4 f4 5a
[ 3.960366] platform caam_sm: [0072] 00 00 00 00 00 00 00 00
[ 3.968123] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 3.975869] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 3.983604] platform caam_sm: 256-bit black key in blob:
[ 3.991011] platform caam_sm: [0000] f4 cd 14 18 14 b5 eb 59
[ 3.998822] platform caam_sm: [0008] a1 3b fc 5a 87 43 bb f9
[ 4.006648] platform caam_sm: [0016] ff 59 cc e7 96 14 e1 40
[ 4.014504] platform caam_sm: [0024] b9 f1 48 93 fd 05 0d db
[ 4.022381] platform caam_sm: [0032] 4b d7 10 49 49 ee 15 b7
[ 4.030291] platform caam_sm: [0040] d1 c8 70 00 3e 18 fd 25
[ 4.038234] platform caam_sm: [0048] d8 d3 ff 9b fd 72 49 78
[ 4.046195] platform caam_sm: [0056] 72 47 d7 6f a7 27 fe 39
[ 4.054185] platform caam_sm: [0064] cb 0b 90 93 f2 8f 53 fd
[ 4.062147] platform caam_sm: [0072] 0c 95 9c 90 01 9f 39 93
[ 4.070114] platform caam_sm: [0080] 00 00 00 00 00 00 00 00
[ 4.078097] platform caam_sm: [0088] 00 00 00 00 00 00 00 00
[ 4.086343] platform caam_sm: restored 64-bit black key:
[ 4.094024] platform caam_sm: [0000] f3 65 4b 5f 29 76 16 34
[ 4.102052] platform caam_sm: [0008] 0c cd f0 48 4f 21 ec 8f
[ 4.110122] platform caam_sm: restored 128-bit black key:
[ 4.117962] platform caam_sm: [0000] a5 85 26 bc 47 bf 1d bc
[ 4.126089] platform caam_sm: [0008] d5 f0 f1 e7 bb 7a 21 72
[ 4.134241] platform caam_sm: restored 192-bit black key:
[ 4.142166] platform caam_sm: [0000] ad cf cf 64 d9 41 f3 9a
[ 4.150382] platform caam_sm: [0008] 97 08 86 ac fd 62 5f 7a
[ 4.158632] platform caam_sm: [0016] 0b ef 62 b5 57 c9 09 67
[ 4.166865] platform caam_sm: [0024] ea 65 23 1f b1 87 54 7b
[ 4.175079] platform caam_sm: restored 256-bit black key:
[ 4.183053] platform caam_sm: [0000] 5f 9e 7b 85 e0 0f b2 ba
[ 4.191300] platform caam_sm: [0008] dd 44 82 f3 f7 9a ff d6
[ 4.199544] platform caam_sm: [0016] 08 d3 00 09 e5 19 ec 07
[ 4.207788] platform caam_sm: [0024] 76 6a 9e fe a9 aa cb 14
[ 4.216344] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
[ 4.224958] snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
[ 4.235794] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.244098] usbcore: registered new interface driver usbhid
[ 4.252452] usbhid: USB HID core driver
[ 4.264719] stmpe-adc stmpe-adc: Initialized
[ 4.273753] sgtl5000 2-000a: sgtl5000 revision 0x11
[ 4.285105] scsi 1:0:0:0: Direct-Access Kingston DataTraveler 2.0 PMAP PQ: 0 ANSI: 0 CCS
[ 4.433117] 2-000a: 1200 mV normal
[ 4.439858] sgtl5000 2-000a: Using internal LDO instead of VDDD
[ 4.460758] imx-sgtl5000 sound.31: sgtl5000 <-> 2028000.ssi mapping ok
[ 4.473857] imx-spdif sound-spdif.33: snd-soc-dummy-dai <-> 2004000.spdif mapping ok
[ 4.487871] imx-audio-hdmi sound-hdmi.32: hdmi-hifi <-> hdmi_audio.3 mapping ok
[ 4.499297] ipip: IPv4 over IPv4 tunneling driver
[ 4.507762] IPv4 over IPSec tunneling driver
[ 4.515798] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.524418] arp_tables: (C) 2002 David S. Miller
[ 4.532329] TCP: cubic registered
[ 4.539474] NET: Registered protocol family 10
[ 4.548487] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.557311] sit: IPv6 over IPv4 tunneling driver
[ 4.566570] NET: Registered protocol family 17
[ 4.574485] can: controller area network core (rev 20120528 abi 9)
[ 4.584210] NET: Registered protocol family 29
[ 4.592184] can: raw protocol (rev 20120528)
[ 4.599970] can: broadcast manager protocol (rev 20120528 t)
[ 4.609188] can: netlink gateway (rev 20130117) max_hops=1
[ 4.618608] NET: Registered protocol family 36
[ 4.626669] Key type dns_resolver registered
[ 4.636232] Registering SWP/SWPB emulation handler
[ 4.976890] imx6q-pcie 1ffc000.pcie: phy link never came up
[ 4.986154] imx6q-pcie 1ffc000.pcie: Failed to bring link up!
[ 4.995652] imx6q-pcie 1ffc000.pcie: failed to initialize host
[ 5.005281] imx6q-pcie: probe of 1ffc000.pcie failed with error -22
[ 5.017687] SW4: disabling
[ 5.024130] SW3B: disabling
[ 5.030603] SW2: disabling
[ 5.036997] regulator-dummy: disabling
[ 5.044695] imx mcc test is registered.
[ 5.053282] input: gpio-keys.35 as /devices/soc0/gpio-keys.35/input/input1
[ 5.065668] rtc-ds1307 1-0068: setting system clock to 2016-07-25 21:52:08 UTC (1469483528)
[ 5.084694] sd 1:0:0:0: [sda] 15671296 512-byte logical blocks: (8.02 GB/7.47 GiB)
[ 5.088427] ALSA device list:
[ 5.088435] #0: imx6q-apalis-sgtl5000
[ 5.088438] #1: imx-spdif
[ 5.088440] #2: imx-hdmi-soc
[ 5.126056] sd 1:0:0:0: [sda] Write Protect is off
[ 5.134824] sd 1:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 5.135296] sd 1:0:0:0: [sda] No Caching mode page found
[ 5.144744] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 5.158157] sd 1:0:0:0: [sda] No Caching mode page found
[ 5.167456] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 5.178324] sda: sda1
[ 5.187284] sd 1:0:0:0: [sda] No Caching mode page found
[ 5.196844] sd 1:0:0:0: [sda] Assuming drive cache: write through
[ 5.207007] sd 1:0:0:0: [sda] Attached SCSI removable disk
[ 5.229907] kjournald starting. Commit interval 5 seconds
[ 5.230061] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[ 5.230092] VFS: Mounted root (ext3 filesystem) readonly on device 179:2.
[ 5.230827] devtmpfs: mounted
[ 5.231407] Freeing unused kernel memory: 332K (80891000 - 808e4000)
[ 5.340839] random: systemd urandom read with 56 bits of entropy available
[ 5.355424] systemd[1]: systemd 226 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP)
[ 5.378607] systemd[1]: Detected architecture arm.
[ 5.404257] systemd[1]: Set hostname to <apalis-imx6>.
[ 5.415021] systemd[1]: Hardware watchdog 'imx2+ watchdog', version 0
[ 5.426277] systemd[1]: Set hardware watchdog to 20s.
[ 5.640311] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.673944] systemd[1]: Listening on networkd rtnetlink socket.
[ 5.703601] systemd[1]: Listening on udev Control Socket.
[ 5.733669] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.763635] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 5.793479] systemd[1]: Reached target Swap.
[ 5.813594] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.843698] systemd[1]: Reached target Paths.
[ 5.873879] systemd[1]: Created slice User and Session Slice.
[ 5.903561] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.933700] systemd[1]: Created slice System Slice.
[ 5.963771] systemd[1]: Created slice system-getty.slice.
[ 5.993735] systemd[1]: Created slice system-ppp.slice.
[ 6.023483] systemd[1]: Reached target Slices.
[ 6.053562] systemd[1]: Listening on udev Kernel Socket.
[ 6.083717] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 6.113609] systemd[1]: Listening on Journal Socket.
[ 6.145220] systemd[1]: Starting Export GPIOs to user space...
[ 6.175744] systemd[1]: Starting File System Check on Root Device...
[ 6.210073] systemd[1]: Starting Load Kernel Modules...
[ 6.225201] systemd[1]: Starting Setup Virtual Console...
[ 6.242958] systemd[1]: Starting Journal Service...
[ 6.261245] systemd[1]: Mounting Temporary Directory...
[ 6.263376] galcore: disagrees about version of symbol wake_up_process
[ 6.263388] galcore: Unknown symbol wake_up_process (err -22)
[ 6.263585] galcore: disagrees about version of symbol pid_vnr
[ 6.263589] galcore: Unknown symbol pid_vnr (err -22)
[ 6.264059] galcore: disagrees about version of symbol __task_pid_nr_ns
[ 6.264068] galcore: Unknown symbol __task_pid_nr_ns (err -22)
[ 6.264158] galcore: disagrees about version of symbol find_vpid
[ 6.264164] galcore: Unknown symbol find_vpid (err -22)
[ 6.264176] galcore: disagrees about version of symbol pid_task
[ 6.264191] galcore: Unknown symbol pid_task (err -22)
[ 6.264675] galcore: disagrees about version of symbol device_destroy
[ 6.264705] galcore: Unknown symbol device_destroy (err -22)
[ 6.264759] galcore: disagrees about version of symbol device_create
[ 6.264778] galcore: Unknown symbol device_create (err -22)
[ 6.264974] galcore: disagrees about version of symbol dev_err
[ 6.264980] galcore: Unknown symbol dev_err (err -22)
[ 6.465889] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 6.505657] systemd[1]: Mounting Debug File System...
[ 6.537506] systemd[1]: Mounted Debug File System.
[ 6.563620] systemd[1]: Mounted Temporary Directory.
[ 6.593926] systemd[1]: Started Journal Service.
[ 6.987900] EXT3-fs (mmcblk0p2): using internal journal
[ 7.201501] systemd-journald[183]: Received request to flush runtime journal from PID 1
[ 7.706138] galcore: disagrees about version of symbol wake_up_process
[ 7.717751] galcore: Unknown symbol wake_up_process (err -22)
[ 7.728812] galcore: disagrees about version of symbol pid_vnr
[ 7.740715] galcore: Unknown symbol pid_vnr (err -22)
[ 7.754927] galcore: disagrees about version of symbol __task_pid_nr_ns
[ 7.768741] galcore: Unknown symbol __task_pid_nr_ns (err -22)
[ 7.781287] galcore: disagrees about version of symbol find_vpid
[ 7.792393] galcore: Unknown symbol find_vpid (err -22)
[ 7.792564] galcore: disagrees about version of symbol pid_task
[ 7.792572] galcore: Unknown symbol pid_task (err -22)
[ 7.797673] galcore: disagrees about version of symbol device_destroy
[ 7.797681] galcore: Unknown symbol device_destroy (err -22)
[ 7.797724] galcore: disagrees about version of symbol device_create
[ 7.797729] galcore: Unknown symbol device_create (err -22)
[ 7.805060] galcore: disagrees about version of symbol dev_err
[ 7.805068] galcore: Unknown symbol dev_err (err -22)
[ 7.973885] adv7180 3-0021: no sensor pwdn pin available
[ 8.002875] random: nonblocking pool is initialized
[ 8.037881] max9526 3-0020: Device seems not to be a MAX9526
[ 8.759145] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 9.340764] using random self ethernet address
[ 9.349401] using random host ethernet address
[ 9.452258] usb0: HOST MAC 00:14:2d:ff:ff:fe
[ 9.461707] usb0: MAC 00:14:2d:ff:ff:ff
[ 9.704804] fec 2188000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=2188000.ethernet:07, ir)
[ 9.710861] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.737013] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.831478] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 13.059671] libphy: 2188000.ethernet:07 - Link is Up - 1000/Full
[ 13.066019] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
