Failed in "do_image_bootfs" when building "tdx-reference-multimedia-image"
I have been trying to build the reference image: “tdx-reference-multimedia-image” based on Verdin IMX8MM. I used to successfully build the image by simply invoking: “bitbake tdx-reference-multimedia-image”. Later I cleaned “linux-toradex” and “u-boot-toradex” respectively and re-bitbaked the 2 packages subsequently. And then when I attempted to build the image again, there is an error and I don’t know how to solve it:
quan_shen@quan-shen:~/oe-core/build$ bitbake tdx-reference-multimedia-image
Loading cache: 100% |###############################################################################################################################################################################| Time: 0:00:00
Loaded 3920 entries from dependency cache.
Build Configuration:
BB_VERSION = “1.46.0”
BUILD_SYS = “x86_64-linux”
NATIVELSBSTRING = “universal”
TARGET_SYS = “aarch64-tdx-linux”
MACHINE = “verdin-imx8mm”
DISTRO = “tdx-xwayland”
DISTRO_VERSION = “5.7.2-devel-20230718061040+build.0”
TUNE_FEATURES = “aarch64”
TARGET_FPU = “”
meta-toradex-nxp = “HEAD:b288744310a77181db0fde2bee5d86e7d890f28b”
meta-freescale = “HEAD:f66fdef1c2dc735690a7ec7dd44a534d69ea3918”
meta-freescale-3rdparty = “HEAD:4c0a166fa2809f74c93bd4c56d9a0f7ccb7818c8”
meta-toradex-tegra = “HEAD:43b5af1d01a9c166e41e0ec3c93efc57c5c130b9”
meta-toradex-bsp-common = “HEAD:f88e4c50e64ca144a7a15bd50c92a13d325f6780”
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python = “HEAD:7007d14c2558f86a49c2e2acb6154432c2ba4092”
meta-freescale-distro = “HEAD:5d882cdf079b3bde0bd9869ce3ca3db411acbf3b”
meta-toradex-demos = “HEAD:a5ab14682a0b863f36987ee6f8f3f2ec8b637250”
meta-qt5 = “HEAD:5ef3a0ffd3324937252790266e2b2e64d33ef34f”
meta-toradex-distro = “HEAD:e9a1072abf323fe3e91c7aead182130417c2226d”
meta-poky = “HEAD:8485f6da8c49c7a8cd1d768facf3ff3b746f3b49”
meta = “HEAD:4045bf02bbc6e87a05ba689a63c675e49c940772”
Initialising tasks: 100% |##########################################################################################################################################################################| Time: 0:00:11
Sstate summary: Wanted 938 Found 935 Missed 3 Current 2390 (99% match, 99% complete)
NOTE: Executing Tasks
ERROR: tdx-reference-multimedia-image-1.0-r0 do_image_bootfs: Command ‘install -m 0644 -D /home/quan_shen/oe-core/build/deploy/images/verdin-imx8mm/overlays/sources /home/quan_shen/oe-core/build/tmp/work/verdin_imx8mm-tdx-linux/tdx-reference-multimedia-image/1.0-r0/bootfs/overlays/sources’ returned 1:
b"install: omitting directory ‘/home/quan_shen/oe-core/build/deploy/images/verdin-imx8mm/overlays/sources’\n"
ERROR: Logfile of failure stored in: /home/quan_shen/oe-core/build/tmp/work/verdin_imx8mm-tdx-linux/tdx-reference-multimedia-image/1.0-r0/temp/log.do_image_bootfs.203977
ERROR: Task (/home/quan_shen/oe-core/build/../layers/meta-toradex-demos/recipes-images/images/tdx-reference-multimedia-image.bb:do_image_bootfs) failed with exit code ‘1’
ERROR: tdx-reference-multimedia-image-1.0-r0 do_image_wic: Execution of ‘/home/quan_shen/oe-core/build/tmp/work/verdin_imx8mm-tdx-linux/tdx-reference-multimedia-image/1.0-r0/temp/run.do_image_wic.204001’ failed with exit code 1
ERROR: Logfile of failure stored in: /home/quan_shen/oe-core/build/tmp/work/verdin_imx8mm-tdx-linux/tdx-reference-multimedia-image/1.0-r0/temp/log.do_image_wic.204001
From my understanding, it fails when it’s executing the function: “do_image_bootfs()”. I have tried cleaning the image first by calling: “bitbake tdx-reference-multimedia-image -c cleanall”, prior to rebuilding it, but it failed the same way. I just want to try to avoid deleting the whole “tmp” folder as rebuilding the image after that is very time-consuming. Could anyone please advise on this? Thanks in advance!
Could anyone please help? Thanks!
Hi @quan_shen , sorry for the late reply. If this issue persists, you can try to delete build/cache build/deploy build/tmp, then rebuild the image.
Thanks. The problem has been solved.
