Hi Toradex,
I’m try to compile U-boot for Colibri VF61 from source code.
I’m following to Build U-Boot and Linux Kernel from Source Code | Toradex Developer Center for U-boot build. But after u-boot upgrade I got fail of Linux loading.
Below log:
U-Boot 2015.04-00359-g7f94666 (Mar 30 2016 - 15:19:58)
CPU: Freescale Vybrid VF610 at 500 MHz
Reset cause: WDOG A5 DRAM: 256 MiB
NAND: 512 MiB MMC: FSL_SDHC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Model: Toradex Colibri VF61 256MB IT V1.2A, Serial# 04886361
Net: FEC
Booting from NAND...
UBI: default fastmap pool size: 200
UBI: default fastmap WL pool size: 25
UBI: attaching mtd1 to ubi0
UBI: attached by fastmap
UBI: fastmap pool size: 200
UBI: fastmap WL pool size: 100
UBI: attached mtd1 (name "mtd=3", size 510 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 4075, bad PEBs: 5, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 44/16, WL threshold: 4096, image sequence number: 0
UBI: available PEBs: 0, total reserved PEBs: 4075, PEBs reserved for bad PEB handling: 75
Read **0 bytes from volume kernel to 82000000**
Volume kernel not found! Booting from
MMC/SD card... Failed to mount ext2
filesystem...
** Unrecognized filesystem type ** Booting from NFS... FEC Waiting for
PHY auto negotiation to complete......... TIMEOUT !
BOOTP broadcast 1
How to solve this issue?
WBR,
Oleg
