Dear Sir,
I am new to build OS, I am using Colibri VF61 module and Colibri Evaluation board,
Development System: Ubuntu 18.04 64bit.
I am following below link for building OS.
In this In stuck at Compilation step.
root@rahulk-ThinkCentre-E73:/home/rahulk/Toradex_Dev/u-boot-toradex# make -j3 2>&1 | tee build.log
make: arm-none-linux-gnueabihf-gcc: Command not found
/bin/sh: 1: arm-none-linux-gnueabihf-gcc: not found
dirname: missing operand
Try ‘dirname --help’ for more information.
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/config.h
CFG u-boot.cfg
GEN include/autoconf.mk.dep
scripts/Makefile.autoconf:79: recipe for target ‘u-boot.cfg’ failed
make[1]: *** [u-boot.cfg] Error 1
make[1]: *** Waiting for unfinished jobs…
scripts/Makefile.autoconf:50: recipe for target ‘include/autoconf.mk.dep’ failed
make[1]: *** [include/autoconf.mk.dep] Error 1
make: *** No rule to make target ‘include/config/auto.conf’, needed by ‘include/config/uboot.release’. Stop.
I already set tool chain arm-none-linux-gnueabihf-gcc
$ echo “export ARCH=arm” >> ~/export_compiler
$ echo “export DTC_FLAGS=‘-@’” >> ~/export_compiler
$ echo “export PATH=~/gcc-linaro/bin/:$PATH” >> ~/export_compiler
$ echo “export CROSS_COMPILE=arm-none-linux-gnueabihf-” >> ~/export_compiler
$ source ~/export_compiler
but still unable to compile and build code.
Please can you help me out.
