Yes.
https://developer.toradex.com/getting-started/module-2-first-steps-with-torizon/build-and-run-your-first-c-application-arm64?som=apalis-imx8&board=apalis-evaluation-board&os=torizon&desktop=windows
Tried to follow steps from above link, was not able to see the dialog in step 15 (do you want to build it box) but it went ahead building and then received above mentioned error.
Software: Microsoft Visual Studio Community 2019 (Version 16.11.3) , Toradex Torizon C/C++ support stable version
Hardware: Apalis imx8QM 4GB WB IT V1.1 on eval board 06805227
Contents of moses.exe
Serving on http://kubernetes.docker.internal:5000
INFO:root:REST → /api/version/docker
INFO:root:REST ← /api/version/docker - 200
INFO:root:REST → /api/eulas
INFO:root:REST ← /api/eulas - 200
INFO:root:REST → /api/devices
INFO:root:REST ← /api/devices - 200
INFO:root:REST → /api/devices/06805227
INFO:root:REST ← /api/devices/06805227 - 200
INFO:root:REST → /api/devices/06805227/images
INFO:root:SSH - Creating tunnel to 06805227
INFO:root:SSH - Tunnel to 06805227 activated
INFO:root:REST ← /api/devices/06805227/images - 200
INFO:root:REST → /api/devices/06805227/containers
INFO:root:REST ← /api/devices/06805227/containers - 200
INFO:root:REST → /api/devices/06805227/processes
INFO:root:SSH - Connecting to device 06805227
INFO:root:SSH - Connected to device 06805227
INFO:root:REST ← /api/devices/06805227/processes - 200
INFO:root:REST → /api/devices/06805227/storage
INFO:root:REST ← /api/devices/06805227/storage - 200
INFO:root:REST → /api/devices/06805227/memory
INFO:root:REST ← /api/devices/06805227/memory - 200
INFO:root:REST → /api/applications/load
INFO:root:REST ← /api/applications/load - 200
INFO:root:REST → /api/applications/d7953771-325d-47ae-ae41-431ef8756e11/sdk/container
ERROR:root:Error: 548 SDK container not found. SDK Container not found: 404 Client Error for http+docker://localnpipe/v1.41/containers/hello%20world_arm64v8-debian_bullseye_debug_d7953771-325d-47ae-ae41-431ef8756e11_sdk/json: Not Found (“No such container: hello world_arm64v8-debian_bullseye_debug_d7953771-325d-47ae-ae41-431ef8756e11_sdk”)
ERROR:root:Exception: SDK Container not found: 404 Client Error for http+docker://localnpipe/v1.41/containers/hello%20world_arm64v8-debian_bullseye_debug_d7953771-325d-47ae-ae41-431ef8756e11_sdk/json: Not Found (“No such container: hello world_arm64v8-debian_bullseye_debug_d7953771-325d-47ae-ae41-431ef8756e11_sdk”)
ERROR:root:404 Client Error for http+docker://localnpipe/v1.41/containers/hello%20world_arm64v8-debian_bullseye_debug_d7953771-325d-47ae-ae41-431ef8756e11_sdk/json: Not Found (“No such container: hello world_arm64v8-debian_bullseye_debug_d7953771-325d-47ae-ae41-431ef8756e11_sdk”)
INFO:root:REST ← /api/applications/d7953771-325d-47ae-ae41-431ef8756e11/sdk/container - 548
INFO:root:REST → /api/platforms
INFO:root:REST ← /api/platforms - 200
INFO:root:REST → /api/progress/create
INFO:root:REST ← /api/progress/create - 200
INFO:root:REST → /api/applications/d7953771-325d-47ae-ae41-431ef8756e11/sdk/update
INFO:root:REST → /api/progress/status
ERROR:root:Error: 530 Local docker exception. Docker exception: invalid reference format
INFO:root:REST ← /api/progress/status - 200
INFO:root:REST ← /api/applications/d7953771-325d-47ae-ae41-431ef8756e11/sdk/update - 530
INFO:root:REST → /api/applications/d7953771-325d-47ae-ae41-431ef8756e11/sdk/run
ERROR:root:400 Client Error for http+docker://localnpipe/v1.41/images/hello%20world_arm64v8-debian_bullseye_debug_d7953771-325d-47ae-ae41-431ef8756e11_sdk_image/json: Bad Request (“no such image: hello world_arm64v8-debian_bullseye_debug_d7953771-325d-47ae-ae41-431ef8756e11_sdk_image: invalid reference format”)
File “docker\api\client.py”, line 268, in _raise_for_status
File “requests\models.py”, line 953, in raise_for_status
requests.exceptions.HTTPError: 400 Client Error: Bad Request for url: http+docker://localnpipe/v1.41/images/hello%20world_arm64v8-debian_bullseye_debug_d7953771-325d-47ae-ae41-431ef8756e11_sdk_image/json
During handling of the above exception, another exception occurred:
File “flask\app.py”, line 1513, in full_dispatch_request
File “flask\app.py”, line 1499, in dispatch_request
File “connexion\decorators\decorator.py”, line 48, in wrapper
File “connexion\decorators\uri_parsing.py”, line 144, in wrapper
File “connexion\decorators\validation.py”, line 384, in wrapper
File “connexion\decorators\parameter.py”, line 121, in wrapper
File “api.py”, line 1411, in applications_application_sdk_run_get
File “applicationconfig_sdk.py”, line 378, in start_sdk_container
File “applicationconfig_sdk.py”, line 239, in _start_sdk_container
File “docker\models\images.py”, line 316, in get
File “docker\utils\decorators.py”, line 19, in wrapped
File “docker\api\image.py”, line 253, in inspect_image
File “docker\api\client.py”, line 274, in _result
File “docker\api\client.py”, line 270, in _raise_for_status
File “docker\errors.py”, line 31, in create_api_error_from_http_exception
docker.errors.APIError: 400 Client Error for http+docker://localnpipe/v1.41/images/hello%20world_arm64v8-debian_bullseye_debug_d7953771-325d-47ae-ae41-431ef8756e11_sdk_image/json: Bad Request (“no such image: hello world_arm64v8-debian_bullseye_debug_d7953771-325d-47ae-ae41-431ef8756e11_sdk_image: invalid reference format”)
INFO:root:REST ← /api/applications/d7953771-325d-47ae-ae41-431ef8756e11/sdk/run - 500
INFO:root:REST → /api/applications/d7953771-325d-47ae-ae41-431ef8756e11/updated
INFO:root:Image has never been built.
INFO:root:REST ← /api/applications/d7953771-325d-47ae-ae41-431ef8756e11/updated - 200
INFO:root:REST → /api/applications/d7953771-325d-47ae-ae41-431ef8756e11/build
INFO:root:REST ← /api/applications/d7953771-325d-47ae-ae41-431ef8756e11/build - 530
Thanks.
