Facing build error while building b2qt ( QT 5.9.6 very) for i.mx6 platform
We are trying to compile boot2Qt for Toradex Colibri iMX6 Target
When we follow the steps defined here : https://doc.qt.io/QtForDeviceCreation/qtee-custom-embedded-linux-image.html
Host : Ubuntu 16.04
repo init -u git://code.qt.io/yocto/boot2qt-manifest -m v5.9.6.xml
repo sync
export MACHINE=colibri-imx6
source ./setup-environment.sh
bitbake b2qt-embedded-qt5-image
Got following error:
WARNING: firmware-imx-1_5.4-r0 do_fetch: Failed to fetch URL git://git.freescale.com/imx/imx-firmware.git;branch=master;destsuffix=/home/nischay/Toradex/Boot2Qt_5.9.6/build-colibri-imx6/tmp/work/all-poky-linux/firmware-imx/1_5.4-r0/firmware-imx-5.4/git, attempting MIRRORS if available
ERROR: firmware-imx-1_5.4-r0 do_fetch: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS=“unix:abstract=/tmp/dbus-6e0VKSRZme”; export SSH_AUTH_SOCK=“/run/user/1000/keyring/ssh”; export PATH=“/home/nischay/Toradex/Boot2Qt_5.9.6/build-colibri-imx6/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/nischay/Toradex/Boot2Qt_5.9.6/sources/poky/scripts:/home/nischay/Toradex/Boot2Qt_5.9.6/build-colibri-imx6/tmp/sysroots/x86_64-linux/usr/bin/allarch-poky-linux:/home/nischay/Toradex/Boot2Qt_5.9.6/build-colibri-imx6/tmp/sysroots/colibri-imx6/usr/bin/crossscripts:/home/nischay/Toradex/Boot2Qt_5.9.6/build-colibri-imx6/tmp/sysroots/x86_64-linux/usr/sbin:/home/nischay/Toradex/Boot2Qt_5.9.6/build-colibri-imx6/tmp/sysroots/x86_64-linux/usr/bin:/home/nischay/Toradex/Boot2Qt_5.9.6/build-colibri-imx6/tmp/sysroots/x86_64-linux/sbin:/home/nischay/Toradex/Boot2Qt_5.9.6/build-colibri-imx6/tmp/sysroots/x86_64-linux/bin:/home/nischay/Toradex/Boot2Qt_5.9.6/sources/poky/scripts:/home/nischay/Toradex/Boot2Qt_5.9.6/sources/poky/bitbake/bin:/home/nischay/bin:/home/nischay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin”; export HOME=“/home/nischay”; LANG=C git -c core.fsyncobjectfiles=0 clone --bare --mirror git://git.freescale.com/imx/imx-firmware.git /home/nischay/Toradex/Boot2Qt_5.9.6/build-colibri-imx6/../downloads/git2/git.freescale.com.imx.imx-firmware.git --progress failed with exit code 128, output:
Cloning into bare repository ‘/home/nischay/Toradex/Boot2Qt_5.9.6/build-colibri-imx6/../downloads/git2/git.freescale.com.imx.imx-firmware.git’…
fatal: unable to connect to git.freescale.com:
git.freescale.com: No address associated with hostname
ERROR: firmware-imx-1_5.4-r0 do_fetch: Fetcher failure for URL: ‘git://git.freescale.com/imx/imx-firmware.git;branch=master;destsuffix=/home/nischay/Toradex/Boot2Qt_5.9.6/build-colibri-imx6/tmp/work/all-poky-linux/firmware-imx/1_5.4-r0/firmware-imx-5.4/git’. Unable to fetch URL from any source.
ERROR: firmware-imx-1_5.4-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/nischay/Toradex/Boot2Qt_5.9.6/build-colibri-imx6/tmp/work/all-poky-linux/firmware-imx/1_5.4-r0/temp/log.do_fetch.12093
ERROR: Task (/home/nischay/Toradex/Boot2Qt_5.9.6/sources/meta-freescale/recipes-bsp/firmware-imx/firmware-imx_5.4.bb:do_fetch) failed with exit code ‘1’
NOTE: Tasks Summary: Attempted 2803 tasks of which 2800 didn’t need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 3 ERROR messages shown, returning a non-zero exit code.
Hi @yatish.m
Greetings from Toradex Community.
Please try to manually download the package link and put to the downloads/git2, then “bitbake firmware-imx” again.finally bitbake b2qt-embedded-qt5-image to build full image.
Did you checked our qt article??if not please have a look link
Hi @ashok.tx ,
Thank you for suggestion and workaround, after following the steps that you suggested fixed the issue and build was successful.
Yatish
Hi yatish
you are welcome. Thanks for the update.
