External memory bus (EIM) on iMX6
Do you provide sample code for EIM on iMX6 on linux please?
Hi
The WEIM interface is configured in the device-tree.
We configure it for a non multiplexed bus with 3 chip selects, each taking up a memory size of 32M.
With this, and two banks of 128k SRAM on CS0/CS1 connected to the Evaluation Board’s X3 on can access that memory at physical address 0x0800000 and 0x0a000000.
root@colibri-imx6:~# memtester -p 0x08000000 128K 1
memtester version 4.3.0 (32-bit)
Copyright (C) 2001-2012 Charles Cazabon.
Licensed under the GNU General Public License version 2 (only).
pagesize is 4096
pagesizemask is 0xfffff000
want 0MB (131072 bytes)
Loop 1/1:
  Stuck Address       : ok
  Random Value        : ok
  Compare XOR         : ok
  Compare SUB         : ok
  Compare MUL         : ok
  Compare DIV         : ok
  Compare OR          : ok
  Compare AND         : ok
  Sequential Increment: ok
  Solid Bits          : ok
  Block Sequential    : ok
  Checkerboard        : ok
  Bit Spread          : ok
  Bit Flip            : ok
  Walking Ones        : ok
  Walking Zeroes      : ok
Done.
root@colibri-imx6:~# devmem2 0x08000000
/dev/mem opened.
Memory mapped at address 0x76f73000.
Read at address  0x08000000 (0x76f73000): 0x00000001
You could use one of the mmap family systemcalls to get access to get access from within your program.
Max
