I’m right at the beginning with Torizon and Docker Images. Now I’m trying to make port 5555/UDP visible from my container to the network. I can do this in the console with docker -p … or in portainer.io but I can’t manage to configure this in Visual Studio Code (.NET Core application)
I guess I have to change config.yaml? I have tried that:
ports:
common: {5555:5555}
debug: {}
release: {}
props:
common:
expose: 'EXPOSE 5555 5555'
This gives me the error message with the Toradex plugin V1.1:
Bad Request ("invalid port
specification: “5555:5555"”) Remote
docker exception.
With the early access version there is no error message but the port is not configured (see portainer.io)
I only found some hints in this C/C++ Development and Debugging on TorizonCore Using Visual Studio Code but no example at all.
