Exchange t20 witch what?
So i have next question. What board can I use instead of colibri t20 v1.2 that I can use to upload a system image without major programing interference? Do you have any board that is still available for sale?
Hello!
If you’re looking for a replacement for the Colibri T20 v1.2 that allows you to upload a system image with minimal programming changes, you might consider the Colibri iMX6ULL or Colibri iMX7 modules. These modules are part of the Toradex Colibri family and are designed to be compatible with the same carrier boards as the T20, which can help simplify your transition.
Both the Colibri iMX6ULL and iMX7 support Torizon, Toradex’s user-friendly industrial Linux platform, which can facilitate system image management and deployment, reducing the need for extensive programming adjustments.
These modules are generally available for purchase through Toradex’s sales channels. I recommend checking the current availability and ensuring they meet your specific application requirements for a smooth transition.
Hardware Migration | Toradex Developer Center.
