Etnaviv driver in OS but Qt5 reports software rendering
I’m working on bringing up Qt5 application code on the i.MX6 in Torizon/Docker.
I’ve derived our application container from torizon/qt5-wayland:3.2.1.
The OS has the etnaviv graphics driver enabled and the GPU is present in the container and detected by kms-setup.sh. /dev/dri and /dev/galcore are mapped to the container.
Currently, I am bypassing wayland using eglfs, e.g.
kms-setup.sh ./application.bin -platform eglfs.
(Note however, that running on Wayland produces similar output about using LLVMpipe).
The application does come up on the display, but Qt reports:
qml: Running on a software rasterizer (LLVMpipe), expect limited performance.
Is this expected for etnaviv? The message appears to be accurate as trying e.g. weston-simple-egl reports only 16 fps:
$>weston-simple-egl
65 frames in 5 seconds: 13.000000 fps
81 frames in 5 seconds: 16.200001 fps
80 frames in 5 seconds: 16.000000 fps
and further backed up by looking at top when the program is running, weston is using an entire CPU core while drawing.
Hey @bw908,
While I look into this, can you let us know which Torizon release you are using?
If you are on Torizon with BSP 6, you can use sudo tdx-info and post the results.
It will look something like 6.5.0+build.8 or 6.6.0-devel-20240309+build.527
And the post has a tag of Apalis IMX6, is this correct? And for completeness, which carrier board / display type are you using?
-Eric
I think I found the problem… I just need more coffee. :coffee:
Our modified DTS file did not have the gpu_2d and gpu_3d nodes enabled, so of course as far as the OS was concerned, there was no GPU. :man_facepalming:
@bw908,
That makes sense. Glad you found the solution. Also It must have been a good brew!
-Eric
