Ethetnet switch deferred probing
We are using Ethernet Port2 with a LAN9374 Switch connected. We are enable DSA drivers in the menuconfig.
While bootup we are able to detect the LAN9374, switch but we are getting deferred probing and
Below is the device tree,
/* Verdin ETH_2_RGMII */
&cpsw_port2 {
	phy-handle = <&cpsw3g_phy1>;
	phy-mode = "rgmii-rxid";
	fixed-link {
		speed = <1000>;
		full-duplex;
lan9374: switch@1 {
                    compatible = "microchip,lan9374";
                    spi-cpha;
                    spi-cpol;
                    reg = <1>;
                    spi-max-frequency = <2000000>;
                    ethernet-ports {
                            #address-cells = <1>;
                            #size-cells = <0>;
                            port@0 {
                                    reg = <0>;
                                    label = "lan1";
                                    phy-mode = "internal";
                                    phy-handle = <&t1phy0>;
                            port@1 {
                                    reg = <1>;
                                    label = "lan2";
                                    phy-handle = <&t1phy1>;
                            port@2 {
                                    reg = <2>;
                                    label = "lan4";
                                    phy-handle = <&t1phy2>;
                            port@3 {
                                    reg = <3>;
                                    label = "lan6";
                                    phy-handle = <&t1phy3>;
                            port@4 {
                                    reg = <4>;
                                    phy-mode = "rgmii";
                                    tx-internal-delay-ps = <2000>;
                                    rx-internal-delay-ps = <2000>;
                                    ethernet = <&cpsw_port2>;
                                    fixed-link {
                                            speed = <1000>;
                                            full-duplex;
                            port@5 {
                                    reg = <5>;
                                    label = "lan7";
                                    phy-mode = "rgmii";
                                    fixed-link {
                                            speed = <1000>;
                                            full-duplex;
                            port@6 {
                                    reg = <6>;
                                    label = "lan5";
                                    phy-handle = <&t1phy6>;
                            port@7 {
                                    reg = <7>;
                                    label = "lan3";
                                    phy-handle = <&t1phy7>;
                    mdio {
                            #size-cells = <0>;
                            t1phy0: ethernet-phy@0{
                                    reg = <0x0>;
                            t1phy1: ethernet-phy@1{
                                    reg = <0x1>;
                            t1phy2: ethernet-phy@2{
                                    reg = <0x2>;
                            t1phy3: ethernet-phy@3{
                                    reg = <0x3>;
                            t1phy6: ethernet-phy@6{
                                    reg = <0x6>;
                            t1phy7: ethernet-phy@7{
                                    reg = <0x7>;
below is the error we are getting,
[    1.303053] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    1.348558] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.758624] davinci_mdio 8000f00.mdio: Configuring MDIO in manual mode
[    1.804547] davinci_mdio 8000f00.mdio: davinci mdio revision 9.7, bus freq 1000000
[    1.818383] mdio_bus 8000f00.mdio: MDIO device at address 7 is missing.
[    1.825049] davinci_mdio 8000f00.mdio: phy[0]: device 8000f00.mdio:00, driver TI DP83867
[   12.314148] am65-cpsw-nuss 8000000.ethernet eth0: PHY [8000f00.mdio:00] driver [TI DP83867] (irq=359)
[    0.612653] Key type id_resolver registered
[    0.616938] Key type id_legacy registered
[    0.621103] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.627968] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    0.671611] Key type asymmetric registered
[    0.675830] Asymmetric key parser 'x509' registered
[    0.680890] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.688702] io scheduler mq-deadline registered
[    0.693369] io scheduler kyber registered
[    0.701277] pinctrl-single 4084000.pinctrl: 34 pins, size 136
[    0.708105] pinctrl-single f4000.pinctrl: 171 pins, size 684
[    0.720842] Serial: 8250/16550 driver, 12 ports, IRQ sharing enabled
[    0.739461] brd: module loaded
[    0.747716] loop: module loaded
[    0.755122] tun: Universal TUN/TAP device driver, 1.6
[    0.761232] VFIO - User Level meta-driver version: 0.3
[    0.768073] usbcore: registered new interface driver uas
[    0.773622] usbcore: registered new interface driver usb-storage
[    0.779797] usbcore: registered new interface driver ums-sddr09
[    0.785887] usbcore: registered new interface driver ums-sddr55
[    0.792490] UDC core: g_mass_storage: couldn't find an available UDC
[    0.799664] i2c_dev: i2c /dev entries driver
[    0.806284] sdhci: Secure Digital Host Controller Interface driver
[    0.812685] sdhci: Copyright(c) Pierre Ossman
[    0.817369] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.823779] ledtrig-cpu: registered to indicate activity on CPUs
[    0.830139] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[    0.837117] usbcore: registered new interface driver usbhid
[    0.842831] usbhid: USB HID core driver
[    0.847971] SPI driver ti-dac7612 has no spi_device_id for ti,dac7612
[    0.854601] SPI driver ti-dac7612 has no spi_device_id for ti,dac7612u
[    0.861285] SPI driver ti-dac7612 has no spi_device_id for ti,dac7612ub
[    0.868127] optee: probing for conduit method.
[    0.872735] optee: revision 4.0 (2a5b1d12)
[    0.873062] optee: dynamic shared memory is enabled
[    0.882700] optee: initialized driver
[    0.888520] Initializing XFRM netlink socket
[    0.893033] NET: Registered PF_PACKET protocol family
[    0.898290] Key type dns_resolver registered
[    0.903140] registered taskstats version 1
[    0.907379] Loading compiled-in X.509 certificates
[    0.922406] ti-sci 44043000.system-controller: ABI: 3.1 (firmware rev 0x0009 '9.1.8--v09.01.08 (Kool Koala)')
[    1.025108] lm73 2-0049: sensor 'lm73'
[    1.029779] lm73 2-004a: sensor 'lm73'
[    1.033681] omap_i2c 4900000.i2c: bus 2 rev0.12 at 100 kHz
[    1.040659] i2c 0-0030: Fixed dependency cycle(s) with /bus@f0000/i2c@20000000/pmic@30/regulators/buck2
[    1.081284] input: tps65219-pwrbutton as /devices/platform/bus@f0000/20000000.i2c/i2c-0/0-0030/tps65219-pwrbutton.2.auto/input/input0
[    1.093929] evbug: Connected device: input0 (tps65219-pwrbutton at tps65219-pwrbutton/input0)
[    1.095633] rtc-ds1307 0-0032: oscillator failed, set time!
[    1.101547] rtc-ds1307 0-0032: registered as rtc0
[    1.106524] rtc-ds1307 0-0032: hctosys: unable to read the hardware clock
[    1.115517] at24 0-0050: supply vcc not found, using dummy regulator
[    1.122517] at24 0-0050: 256 byte 24c02 EEPROM, writable, 16 bytes/write
[    1.129463] omap_i2c 20000000.i2c: bus 0 rev0.12 at 400 kHz
[    1.135831] ti-sci-intr 4210000.interrupt-controller: Interrupt Router 5 domain created
[    1.144280] ti-sci-intr bus@f0000:interrupt-controller@a00000: Interrupt Router 3 domain created
[    1.153559] ti-sci-inta 48000000.interrupt-controller: Interrupt Aggregator domain 28 created
[    1.164359] ti-udma 485c0100.dma-controller: Number of rings: 82
[    1.172797] ti-udma 485c0100.dma-controller: Channels: 48 (bchan: 18, tchan: 12, rchan: 18)
[    1.184024] ti-udma 485c0000.dma-controller: Number of rings: 150
[    1.194426] ti-udma 485c0000.dma-controller: Channels: 35 (tchan: 20, rchan: 15)
[    1.204909] printk: console [ttyS2] disabled
[    1.209396] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 287, base_baud = 3000000) is a 8250
[    1.218307] printk: console [ttyS2] enabled
[    1.226773] printk: bootconsole [ns16550a0] disabled
[    1.238092] 2810000.serial: ttyS0 at MMIO 0x2810000 (irq = 288, base_baud = 3000000) is a 8250
[    1.247827] 2820000.serial: ttyS3 at MMIO 0x2820000 (irq = 289, base_baud = 3000000) is a 8250
[    1.257577] 2830000.serial: ttyS5 at MMIO 0x2830000 (irq = 290, base_baud = 3000000) is a 8250
[    1.267274] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 291, base_baud = 3000000) is a 8250
[    1.277001] 2850000.serial: ttyS4 at MMIO 0x2850000 (irq = 292, base_baud = 3000000) is a 8250
[    1.286684] 2860000.serial: ttyS7 at MMIO 0x2860000 (irq = 293, base_baud = 3000000) is a 8250
[    1.357443] am65-cpsw-nuss 8000000.ethernet: initializing am65 cpsw nuss version 0x6BA01103, cpsw version 0x6BA81103 Ports: 3 quirks:00000006
[    1.370386] am65-cpsw-nuss 8000000.ethernet: initialized cpsw ale version 1.5
[    1.377528] am65-cpsw-nuss 8000000.ethernet: ALE Table size 512
[    1.384310] am65-cpsw-nuss 8000000.ethernet: CPTS ver 0x4e8a010c, freq:500000000, add_val:1 pps:0
[    1.394826] am65-cpsw-nuss 8000000.ethernet: set new flow-id-base 19
[    1.405858] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[    1.411463] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[    1.419288] xhci-hcd xhci-hcd.3.auto: USB3 root hub has no ports
[    1.425302] xhci-hcd xhci-hcd.3.auto: hcc params 0x0258fe6d hci version 0x110 quirks 0x0000008020010010
[    1.434762] xhci-hcd xhci-hcd.3.auto: irq 300, io mem 0x31100000
[    1.441067] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    1.449343] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.456578] usb usb1: Product: xHCI Host Controller
[    1.461461] usb usb1: Manufacturer: Linux 6.1.80-6.7.0-devel+git.603f75dc931d xhci-hcd
[    1.469382] usb usb1: SerialNumber: xhci-hcd.3.auto
[    1.474881] hub 1-0:1.0: USB hub found
[    1.478673] hub 1-0:1.0: 1 port detected
[    1.587893] cpufreq: cpufreq_online: ->get() failed
[    1.592961] cpufreq: cpufreq_online: ->get() failed
[    1.597873] cpufreq-dt cpufreq-dt: failed register driver: -19
[    1.605791] mmc0: CQHCI version 5.10
[    1.611151] gpio-427 (CTRL_SLEEP_MOCI#): hogged as output/high
[    1.624772] debugfs: Directory 'spi0.3' with parent 'regmap' already present!
[    1.631983] debugfs: Directory 'spi0.3' with parent 'regmap' already present!
[    1.639312] debugfs: Directory 'spi0.3' with parent 'regmap' already present!
[    1.646574] max310x spi0.3: MAX14830 ID 0xff does not match
[    1.647181] mmc0: SDHCI controller on fa10000.mmc [fa10000.mmc] using ADMA 64-bit
[    1.652802] ad7606 spi1.0: failed to RESET: no RESET GPIO specified
[    1.690483] ad7606 spi1.1: failed to RESET: no RESET GPIO specified
[    1.717790] mmc0: new HS200 MMC card at address 0001
[    1.723739] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[    1.724900] ad7606 spi2.0: failed to RESET: no RESET GPIO specified
[    1.734963]  mmcblk0: p1 p2
[    1.738663] mmcblk0boot0: mmc0:0001 Q2J55L 16.0 MiB
[    1.745190] mmcblk0boot1: mmc0:0001 Q2J55L 16.0 MiB
[    1.751390] mmcblk0rpmb: mmc0:0001 Q2J55L 4.00 MiB, chardev (241:0)
[    1.834887] debugfs: Directory 'pd:182' with parent 'pm_genpd' already present!
[    1.855969] ALSA device list:
[    1.859008]   No soundcards found.
[    1.867911] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    1.875306] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    2.766564] EXT4-fs (mmcblk0p2): recovery complete
[    2.773349] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[    2.781970] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    2.789505] devtmpfs: mounted
[    2.794050] Freeing unused kernel memory: 2240K
[    2.798703] Run /sbin/init as init process
[    2.802804]   with arguments:
[    2.802811]     /sbin/init
[    2.802816]   with environment:
[    2.802821]     HOME=/
[    2.802826]     TERM=linux
[    2.933389] systemd[1]: System time before build time, advancing clock.
[    2.976726] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[    3.008674] systemd[1]: Detected architecture arm64.
[    3.069446] systemd[1]: Hostname set to <verdin-am62-15415780>.
[    3.406351] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[    3.415342] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[    3.514479] systemd[1]: Binding to IPv6 address not available since kernel does not support IPv6.
[    3.548663] systemd[1]: Queued start job for default target Graphical Interface.
[    3.607130] systemd[1]: Created slice Slice /system/getty.
[    3.631198] systemd[1]: Created slice Slice /system/modprobe.
[    3.655190] systemd[1]: Created slice Slice /system/serial-getty.
[    3.678480] systemd[1]: Created slice User and Session Slice.
[    3.701129] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    3.724957] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.749081] systemd[1]: Reached target Host and Network Name Lookups.
[    3.772706] systemd[1]: Reached target Path Units.
[    3.788715] systemd[1]: Reached target Remote File Systems.
[    3.808691] systemd[1]: Reached target Slice Units.
[    3.824705] systemd[1]: Reached target Swaps.
[    3.871849] systemd[1]: Listening on RPCbind Server Activation Socket.
[    3.892973] systemd[1]: Reached target RPC Port Mapper.
[    3.913656] systemd[1]: Listening on Syslog Socket.
[    3.929216] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    3.953678] systemd[1]: Listening on Journal Audit Socket.
[    3.977430] systemd[1]: Listening on Journal Socket (/dev/log).
[    4.001439] systemd[1]: Listening on Journal Socket.
[    4.021738] systemd[1]: Listening on Network Service Netlink Socket.
[    4.045609] systemd[1]: Listening on udev Control Socket.
[    4.069289] systemd[1]: Listening on udev Kernel Socket.
[    4.089334] systemd[1]: Listening on User Database Manager Socket.
[    4.133371] systemd[1]: Mounting Huge Pages File System...
[    4.153992] systemd[1]: Mounting POSIX Message Queue File System...
[    4.182095] systemd[1]: Mounting Kernel Debug File System...
[    4.197374] systemd[1]: Kernel Trace File System was skipped because of a failed condition check (ConditionPathExists=/sys/kernel/tracing).
[    4.216235] systemd[1]: Mounting Temporary Directory /tmp...
[    4.243302] systemd[1]: Starting Create List of Static Device Nodes...
[    4.270760] systemd[1]: Starting Load Kernel Module configfs...
[    4.317637] systemd[1]: Starting Load Kernel Module drm...
[    4.340461] systemd[1]: Starting Load Kernel Module fuse...
[    4.361976] fuse: init (API version 7.37)
[    4.373562] systemd[1]: Starting RPC Bind...
[    4.399731] systemd[1]: Starting File System Check on Root Device...
[    4.437467] systemd[1]: Starting Journal Service...
[    4.453696] systemd[1]: Load Kernel Modules was skipped because all trigger condition checks failed.
[    4.495614] systemd[1]: Starting Generate network units from Kernel command line...
[    4.528153] systemd[1]: Starting Apply Kernel Variables...
[    4.548328] systemd[1]: Starting Coldplug All udev Devices...
[    4.592364] systemd[1]: Started RPC Bind.
[    4.614071] systemd[1]: Mounted Huge Pages File System.
[    4.645754] systemd[1]: Started Journal Service.
[    5.019170] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[    5.107673] systemd-journald[156]: Received client request to flush runtime journal.
[    5.274510] audit: type=1334 audit(1651167747.340:2): prog-id=5 op=LOAD
[    5.282843] audit: type=1334 audit(1651167747.348:3): prog-id=6 op=LOAD
[    6.315835] random: crng init done
[    6.457505] pwm-backlight backlight-mezzanine: supply power not found, using dummy regulator
[    6.478837] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    6.559742] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    6.622077] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    6.651482] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    6.666361] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    6.768924] ina2xx 2-0040: power monitor ina260 (Rshunt = 0 uOhm)
[    6.775416] k3-m4-rproc 5000000.m4fss: device does not reserved memory regions, ret = -22
[    6.802850] omap8250 2b300000.serial: No clock speed specified: using default: 48000000
[    6.819543] 2b300000.serial: ttyS1 at MMIO 0x2b300000 (irq = 491, base_baud = 3000000) is a 8250
[    6.820889] ina2xx 2-0041: power monitor ina260 (Rshunt = 0 uOhm)
[    6.835420] k3-m4-rproc 5000000.m4fss: reserved memory init failed, ret = -22
[    6.845856] remoteproc remoteproc0: releasing 5000000.m4fss
[    6.863211] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    6.868654] k3-m4-rproc: probe of 5000000.m4fss failed with error -22
[    6.878852] ina2xx 2-0042: power monitor ina260 (Rshunt = 0 uOhm)
[    6.887890] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    6.898528] ina2xx 2-0043: power monitor ina260 (Rshunt = 0 uOhm)
[    6.906761] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    6.917368] ina2xx 2-0044: power monitor ina260 (Rshunt = 0 uOhm)
[    6.933419] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    6.942865] ina2xx 2-0045: power monitor ina260 (Rshunt = 0 uOhm)
[    6.965396] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    6.985245] ina2xx 2-0046: power monitor ina260 (Rshunt = 0 uOhm)
[    7.002987] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    7.026680] ina2xx 2-0047: power monitor ina260 (Rshunt = 0 uOhm)
[    7.034634] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    7.039227] ina2xx 2-004b: power monitor ina260 (Rshunt = 0 uOhm)
[    7.054557] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    7.220777] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    7.228034] rtc-ti-k3 2b1f0000.rtc: registered as rtc1
[    7.256193] platform 78000000.r5f: R5F core may have been powered on by a different host, programmed state (0) != actual state (1)
[    7.266300] pvrsrvkm: loading out-of-tree module taints kernel.
[    7.276285] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    7.292851] platform 78000000.r5f: configured R5F for IPC-only mode
[    7.299834] platform 78000000.r5f: device does not have reserved memory regions, ret = -22
[    7.308442] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: reserved memory init failed, ret = -22
[    7.327181] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    7.345156] [drm] Initialized tidss 1.0.0 20180215 for 30200000.dss on minor 0
[    7.367687] Console: switching to colour frame buffer device 240x67
[    7.368657] remoteproc remoteproc0: releasing 78000000.r5f
[    7.368707] k3_r5_rproc bus@f0000:bus@b00000:r5fss@78000000: k3_r5_cluster_rproc_init failed, ret = -22
[    7.368804] k3_r5_rproc: probe of bus@f0000:bus@b00000:r5fss@78000000 failed with error -22
[    7.465959] tidss 30200000.dss: [drm] fb0: tidssdrmfb frame buffer device
[    7.483475] PVR_K:  182: Device: fd00000.gpu
[    7.489366] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    7.523673] PVR_K:  182: Read BVNC 33.15.11.3 from HW device registers
[    7.580794] PVR_K:  182: RGX Device registered with BVNC 33.15.11.3
[    7.629298] [drm] Initialized pvr 23.3.6512818 20170530 for fd00000.gpu on minor 1
[    7.679071] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    9.686532] ksz-switch spi0.1: found switch: LAN9374, rev 1
[    9.699347] remoteproc remoteproc0: 30074000.pru is available
[    9.717138] remoteproc remoteproc1: 30078000.pru is available
[    9.726949] ksz-switch spi0.1: found switch: LAN9374, rev 1
[   10.689753] audit: type=1334 audit(1651705158.952:4): prog-id=7 op=LOAD
[   10.697483] audit: type=1334 audit(1651705158.956:5): prog-id=8 op=LOAD
[   11.190899] audit: type=1334 audit(1651705159.452:6): prog-id=9 op=LOAD
[   11.203236] audit: type=1334 audit(1651705159.464:7): prog-id=10 op=LOAD
[   12.048274] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   12.080164] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   12.088466] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   12.249146] am65-cpsw-nuss 8000000.ethernet eth1: configuring for fixed/rgmii-rxid link mode
[   12.266839] am65-cpsw-nuss 8000000.ethernet eth1: Link is Up - 1Gbps/Full - flow control off
[   12.305372] audit: type=1334 audit(1651705160.568:8): prog-id=11 op=LOAD
[   12.323641] audit: type=1334 audit(1651705160.584:9): prog-id=12 op=LOAD
[   12.325282] am65-cpsw-nuss 8000000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[   12.393024] 8021q: 802.1Q VLAN Support v1.8
[   12.397751] 8021q: adding VLAN 0 to HW filter on device eth0
[   12.397860] 8021q: adding VLAN 0 to HW filter on device eth1
[   12.922597] audit: type=1334 audit(1651705161.184:10): prog-id=13 op=LOAD
[   12.939344] audit: type=1334 audit(1651705161.200:11): prog-id=14 op=LOAD
[   13.480372] audit: type=1006 audit(1651705161.740:12): pid=645 uid=0 old-auid=4294967295 auid=0 tty=(none) old-ses=4294967295 ses=1 res=1
[   13.494401] audit: type=1300 audit(1651705161.740:12): arch=c00000b7 syscall=64 success=yes exit=1 a0=8 a1=ffffd46cda60 a2=1 a3=ffff9586b020 items=0 ppid=1 pid=645 auid=0 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/lib/systemd/systemd" key=(null)
[   13.522358] systemd-journald[156]: Data hash table of /run/log/journal/65337c446fa541d1b999ebf6541a26e1/system.journal has a fill level at 75.0 (2731 of 3640 items, 2097152 file size, 767 bytes per hash table item), suggesting rotation.
[   13.544371] systemd-journald[156]: /run/log/journal/65337c446fa541d1b999ebf6541a26e1/system.journal: Journal header limits reached or header out-of-date, rotating.
[   14.449006] PVR_K:  554: RGX Firmware image 'rgx.fw.33.15.11.3' loaded
[   14.462685] PVR_K:  554: Shader binary image 'rgx.sh.33.15.11.3' loaded
[   14.982641] am65-cpsw-nuss 8000000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[   19.813664] ksz-switch spi0.1: found switch: LAN9374, rev 1
[   19.820018] spi spi0.1: deferred probe pending
[   43.252755] kauditd_printk_skb: 12 callbacks suppressed
[   43.252785] audit: type=1334 audit(1651705191.516:18): prog-id=12 op=UNLOAD
[   43.265173] audit: type=1334 audit(1651705191.516:19): prog-id=11 op=UNLOAD
please let me know if am missing anything
The “deferred probe pending” issue with the LAN9374 switch on Toradex hardware is often related to power management or initialization timing. Here are some key areas to investigate:
  1. Power Supply Configuration: Ensure that the power supply for the Ethernet PHY is correctly set up in the device tree. This is crucial for proper initialization.
  2. GPIO Expander Initialization: Verify that any necessary GPIO expander initialization is completed before the Ethernet interface attempts to initialize. This can prevent timing issues.
  3. Regulator Definitions: Check that the regulator definitions in your device tree align with your actual hardware configuration. Mismatches here can lead to initialization problems.
For the Verdin family, specifically:
  1. The second Ethernet interface is available as a Reduced Gigabit Media-Independent Interface (RGMII) and is marked as “Reserved” in the interface documentation.
  2. The RGMII requires a PHY to be placed on the carrier board to function correctly.
Here are some recommended solutions:
  1. Always-On Regulator: Consider creating a regulator in the device tree that is always on and not controlled by a GPIO. This can help ensure consistent power supply.
  2. Device Tree Verification: Confirm which device tree is being loaded, as support for a second Ethernet port can vary between different carrier boards.
If you need more specific guidance, it would be helpful to know:
  • The specific Toradex module you are using.
  • The complete device tree configuration for your power management setup.
I hope this helps you resolve the issue.
Toradex AI Assistant
Any update on this issue?
Hi @naveenkumar.muthusam ,
This is for which module and OS?
I remember you were using Verdin AM62 but here you selected Verdin iMX6(which does not exist).
Hi @sahil.tx ,
I am using Verdin Am62 And yocto BSP - multimedia image
HI @sahil.tx ,
any updates on this issue?
any update on this?
I beleive that this is the same query which we are discussing over email, could you also update the BSP version
We have tested this issue on both with kernel version 6.1.80 as well as latest kernel version 7. We see the same issue on both versions.
