Ethernet not working: Apalis iMX8 QuadPlus 2GB Wi-Fi / Bluetooth V1.0B with Ixora V1.1A
Hi all,
just installed the new minimal reference using Easy Installer on Apalis iMX8 QuadPlus 2GB Wi-Fi / Bluetooth V1.0B with Ixora V1.1A. Yet somehow it does not connect to the network using ethernet. connmanctl provides following output:
connmanctl> services
connmanctl>
cat /etc/issue
TDX Wayland with XWayland 5.4.0+build.11 (dunfell) \n \l
Apalis-iMX8_Reference-Minimal-Image
Ethernet should work, since I download the reference image using this. Am I doing something wrong?
On startup it shows following output:
[ OK ] Started Connection service.
[ OK ] Started Network Service.
[ 7.291023] Micrel KSZ9031 Gigabit PHY 5b040000.ethernet-1:07: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=5b040000.ethernet-1:07, irq=305)
Below some more outptus.
Thanks and regards
root@apalis-imx8-06494395:~# ip -4 a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
root@apalis-imx8-06494395:~# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:14:2D:63:18:BB
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:204 errors:0 dropped:0 overruns:0 frame:0
          TX packets:204 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:13684 (13.3 KiB)  TX bytes:13684 (13.3 KiB)
root@apalis-imx8-06494395:~# connmanctl technologies
/net/connman/technology/bluetooth
  Name = Bluetooth
  Type = bluetooth
  Powered = False
  Connected = False
  Tethering = False
/net/connman/technology/p2p
  Name = P2P
  Type = p2p
  Powered = False
  Connected = False
  Tethering = False
/net/connman/technology/wifi
  Name = WiFi
  Type = wifi
  Powered = False
  Connected = False
  Tethering = False
/net/connman/technology/ethernet
  Name = Wired
  Type = ethernet
  Powered = True
  Connected = False
  Tethering = False
Hi @PAR !
Just to be sure: you are connecting an ethernet cable to your Ixora board, right?
Did you check if the network that you connected to your module has a DHCP server running?
Hi @henrique.tx,
yes I connect to the ixora-board. I have an iMX6 with the same type of board and when I connect, it works just fine. But your answer implice, that our IT-department might have done something (which is possible).
thanks and regards
Patrick
Edit: According to IT this should work. But also, why does connmanctl does not show any ethernet service? usually it shows something like this: ethernet_985dad375f63_cable
Both LEDs of the ethernet are on (green permanent, orange blinking)
Best
Patrick
Hi @PAR !
You are right. Something should show up using connmanctl sevices.
When you plug/unplug the ethernet cable on the ixora, are you able to see some messages about it on dmesg?
I get this when I unplug/plug:
[ 5098.155669] fec 5b040000.ethernet eth0: Link is Down
[ 5102.853668] fec 5b040000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 5102.861653] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Also, could you try to establish a direct network connection to your PC? Or maybe use a router with your PC and your module specifically to test the ethernet of the module?
