I’m working on a custom board equipped with a Colibri iMX6 module and the LAN9500A USB to Ethernet controller without EEPROM for the network interface. Operating system is Linux (Yocto). The LAN9500A is connected to a RJ45 jack with integrated Magnetics and LEDs.
I can see the LAN9500A is detected and correct driver is loaded…, Everything works fine when a cable is plugged…
The only problem is that when I unplug the Ethernet cable from the RJ45 socket, Linux does not detect it, and the status LEDs stay ON or may be blinking… However, if I again plug the network cable, link goes down then up again and it works okay…
Does anyone have any ideas?
