Hi Ahmed49,
It seems like you are encountering issues with the initialization of the Torizon IDE Extension due to the .NET SDK versions installed on your WSL Ubuntu-24.04 environment. Here are a few steps you can follow to troubleshoot and potentially resolve this issue:
Verify .NET SDK Installation:
Ensure that the .NET SDKs are correctly installed and recognized by your system. You can list the installed SDKs using the following command:dotnet --list-sdks -
Check Compatibility:
Verify that the versions of the .NET SDKs you have installed are compatible with the Torizon IDE Extension. The extension might have specific requirements for the .NET SDK version. Refer to the Torizon documentation or release notes for the required .NET SDK version. -
Environment Configuration:
Ensure that your environment variables are correctly set up. Sometimes, the IDE might not pick up the correct SDK if the environment variables are not properly configured. You can set theDOTNET_ROOTenvironment variable to point to the installation path of the .NET SDK. -
Extension Logs:
Check the logs for the Torizon IDE Extension in Visual Studio Code. These logs can provide more detailed information about what might be going wrong during initialization. You can access the logs from the “Output” pane in Visual Studio Code and select “Torizon IDE Extension” from the dropdown. -
Reinstall the Extension:
Sometimes, reinstalling the extension can resolve initialization issues. You can uninstall the Torizon IDE Extension from Visual Studio Code and then reinstall it. -
Update WSL and Dependencies:
Ensure that your WSL and all related dependencies (including Docker and Visual Studio Code) are up to date. Sometimes, updates can resolve compatibility issues.
If none of these steps resolve the issue, please provide the specific error message from the logs, and we can further investigate the problem.
[Your Name]
