I’m running in the same issue past days with u-boot 2019.07.
After checking the u-boot error message I found this:
Have a look into the file ./arch/arm/mach-imx/mx7/soc.c of the u-boot source.
You will find this table:
--------8<-----------------------------
#ifdef CONFIG_IMX_BOOTAUX
196 /*
197 * Table of mappings of physical mem regions in both
198 * Cortex-A7 and Cortex-M4 address spaces.
199 *
200 * For additional details check sections 2.1.2 and 2.1.3 in
201 * i.MX7Dual Applications Processor Reference Manual
202 *
203 */
204 const struct rproc_att hostmap[] = {
205 /* aux core , host core, size */
206 { 0x00000000, 0x00180000, 0x8000 }, /* OCRAM_S */
207 { 0x00180000, 0x00180000, 0x8000 }, /* OCRAM_S */
208 { 0x20180000, 0x00180000, 0x8000 }, /* OCRAM_S */
209 { 0x1fff8000, 0x007f8000, 0x8000 }, /* TCML */
210 { 0x20000000, 0x00800000, 0x8000 }, /* TCMU */
211 { 0x00900000, 0x00900000, 0x20000 }, /* OCRAM_128KB */
212 { 0x20200000, 0x00900000, 0x20000 }, /* OCRAM_128KB */
213 { 0x00920000, 0x00920000, 0x20000 }, /* OCRAM_EPDC */
214 { 0x20220000, 0x00920000, 0x20000 }, /* OCRAM_EPDC */
215 { 0x00940000, 0x00940000, 0x20000 }, /* OCRAM_PXP */
216 { 0x20240000, 0x00940000, 0x20000 }, /* OCRAM_PXP */
217 { 0x10000000, 0x80000000, 0x0fff0000 }, /* DDR Code alias */
218 { 0x80000000, 0x80000000, 0xe0000000 }, /* DDRC */
219 { /* sentinel */ }
220 };
221 #endif
------>8-------------------------------------
The error is the wrong size in line 218. Replace 0xe0000000 with 0x60000000
Background:
The max. DDR size is from 8000’0000 to DFFF’FFFF
Therefore the size is not 0xe0000000 it’s 0x60000000
The hostmap will be used in ./arch/arm/mach-imx/imx_bootaux.c to check the valid region.
Hope this help you
