I am using architechture arm32 and want to install torizoncore-builder but not able to do getting menifest error. I am using ubuntu wsl on ubuntu I install torizon Extension and i am connected with colibri imx7D 1gb.I want push Application on torizon cloud.
error: docker: no matching manifest for linux/arm/v7 in the manifest list entries.Give steps to solve this issue.
Hello! Thank you for reaching out.
To install TorizonCore Builder on your Ubuntu system (for an arm32 target), please ensure you meet these requirements and follow these steps:
Your Linux filesystem must be compatible with the Docker
overlay2storage driver. Ubuntu’s default (ext4) is compatible, but if you’ve changed filesystems, verify compatibility:
TorizonCore Builder Requirements -
Use the Bash shell (not Zsh or others).
Installation Steps:
Open a terminal and run:mkdir -p ~/tcbdir/ && cd ~/tcbdir/ wget https://raw.githubusercontent.com/toradex/tcb-env-setup/master/tcb-env-setup.sh source tcb-env-setup.shThis approach ensures all the necessary environment variables are set, and tools are pulled correctly.
Installation instructions reference -
Verify the Installation:
Run:torizoncore-builder --help
If you still get a “manifest error”:
- Ensure you are running the command with Bash (not in VSCode or another shell).
- Confirm every new terminal session sources the
tcb-env-setup.shscript. - Make sure Docker is properly installed and running.
- Double-check your internet connection for Docker to pull required containers.
If you have a specific manifest error message, please share the exact message for more targeted help.
You are supposed to install torizoncore-builder on your host PC used for development, not on the module device.
We only build this torizoncore-builder container for amd64 devices.
https://hub.docker.com/r/torizon/torizoncore-builder/tags
Thank You for helping me. my Issue solved.
