I typed this command on the terminal ./update.sh -n -d /dev/ttyUSB0 and when this message appeared Colibri VF rootfs detected Put the module in recovery mode and press [ENTER]... I turned on the module short circuiting these pins and this message appear:
config file
parse vf_flash/vybrid_usb_work.conf
starting associating phase
association phase succeeded, response was 0x23454523
HAB security state: development mode (0x00000505)
== work item
filename colibri-vf_bin/u-boot.imx
load_size 0 bytes
load_addr 0x00000000
dcd 1
clear_dcd 0
plug 1
jump_mode 2
jump_addr 0x00000000
== end work item
main dcd length 8
sub dcd length 4
loading binary file(colibri-vf_bin/u-boot.imx) to 3f4074e8, skip=0, fsize=6eb18 type=aa
<<<453400, 453400 bytes>>>
failed (status 0x00000000)
jumping to 0x3f4078e8
