OS: linux
:: x64
:: WSL 2
Distro: Ubuntu 22.04.3 LTS
Extension activation logs:
Activating Torizon IDE ...
Telemetry is enabled
Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://github.com/toradex/torizon-experimental-torizon-ide-v2-docs/blob/main/USAGE-DATA.md#opt-out
Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
Resolving host IP address ...
Host IP address OK
Docker installed OK
ERROR :: Docker is not running. Please start the Docker runtime daemon
ERROR :: Docker compose is not installed. Please install Docker compose https://docs.docker.com/compose/install/
PowerShell OK
git OK
dig OK
avahi-resolve OK
nmap OK
iputils-ping OK
file OK
sshpass OK
net-tools OK
Cloning project templates
Project templates clone OK
Checkout templates repo to v2.3.1 OK
Checking connected devices ...
Scanning Torizon devices ...
Configuring debug id_rsa ...
Debug id_rsa OK
ERROR :: Errors during the initialization of Torizon IDE Extension.
HOUSTON WE HAVE A PROBLEM!
PLEASE READ THE LOGS!
WARNING :: Device not reached! Please check if the device is turned on and connected to the network.
ERROR :: 10.0.1.40 not reached
ERROR :: validate-deps-running failed with exit code 69
Tasks logs:
* Executing task in folder qtMixer: pwsh -nop .conf/validateDepsRunning.ps1
⚠️ VALIDATING ENVIRONMENT
InvalidOperation: /home/mmarcos/torizon/testProjects/testAlsaQtNet/qtMixer/.conf/validateDepsRunning.ps1:48:1
Line |
48 | docker info 2> $null | Out-Null
| Cannot run a document in the middle of a pipeline: /usr/bin/docker.
❌ Docker is not running!
⚠️ Please start Docker
⚠️ Please make sure to reload the VS Code window after starting Docker
* The terminal process "pwsh '-nop', '.conf/validateDepsRunning.ps1'" terminated with exit code: 69.
* Terminal will be reused by tasks, press any key to close it.
Reported by: @undefined
If you have more data that you think that is interesting from the context of the issue please reply below.
