hi, i am trying run a code based on tracking.
#include
#include
#include
#include
#include
#include
#include
#include
using namespace std;
using namespace cv;
int main( int argc, char** argv ){
// show help
if(argc<2){
cout<<
" Usage: tracker <video_name>\n"
" examples:\n"
" example_tracking_kcf Bolt/img/%04d.jpg\n"
" example_tracking_kcf faceocc2.webm\n"
<< endl;
return 0;
// declares all required variables
Rect2d roi;
Mat frame;
// create a tracker object
Ptr tracker = TrackerKCF::create();
// set input video
std::string video = argv[1];
VideoCapture cap(video);
// get bounding box
cap >> frame;
roi=selectROI("tracker",frame);
//quit if ROI was not selected
if(roi.width==0 || roi.height==0)
return 0;
// initialize the tracker
tracker->init(frame,roi);
// perform the tracking process
printf("Start the tracking process, press ESC to quit.\n");
for ( ;; ){
// get frame from the video
cap >> frame;
// stop the program if no more images
if(frame.rows==0 || frame.cols==0)
break;
// update the tracking result
tracker->update(frame,roi);
// draw the tracked object
rectangle( frame, roi, Scalar( 255, 0, 0 ), 2, 1 );
// show image with the tracked object
imshow("tracker",frame);
//quit on ESC button
if(waitKey(1)==27)break;
return 0;
Actually i have a cross compiler. i am using the ‘make’ file to do so. And i am getting the following error.
src/MyApp.cpp:603: error: undefined reference to 'cv::TrackerKCF::create()'
src/MyApp.cpp:614: error: undefined reference to 'cv::Tracker::init(cv::_InputArray const&, cv::Rect_ const&)'
src/MyApp.cpp:624: error: undefined reference to 'cv::Tracker::update(cv::_InputArray const&, cv::Rect_&)'
collect2: error: ld returned 1 exit status
make: *** [all] Error 1
Please suggest some solution for this.
