I am trying to install the PyInstaller library using the pip on my Toradex Colibri IMX6, but I can’t get it successfully, it has an error performing the installation:
Running setup.py install for pyinstaller … error
Complete output from command /usr/bin/python -u -c "import setuptools, token ize;__file__='/tmp/pip-install-aafiXn/pyinstaller/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compi le(code, __file__, 'exec'))" install --record /tmp/pip-record-deZgH3/install-rec ord.txt --single-version-externally-managed --compile:
running install
running build
running build_bootloader
No precompiled bootloader found. Trying to compile it for you ...
Setting top to : /tmp/pip-install-aafiXn/pyinstall er/bootloader
Setting out to : /tmp/pip-install-aafiXn/pyinstall er/bootloader/build
Python Version : 2.7.13 (default, Dec 19 2017, 14: 46:00) [GCC 7.2.0]
Checking for 'gcc' (C compiler) : /usr/bin/gcc
Checking size of pointer : not found
Couldn't determine pointer size, only 32 or 64 bit are supported. Please use `--target-arch' to set the pointer size.
(complete log in /tmp/pip-install-aafiXn/pyinstaller/bootloader/build/config .log)
ERROR: Failed compiling the bootloader. Please compile manually and rerun se tup.py
