Error: The recipe linux-libc-headers is trying to install files into a shared area when those files already exist
Hi all,
When building my project I am getting the error described below. When a searched about, I funded that the solution is to delete the Deploy files, but if I do this, my build gets broken because missing files error.
Someone could please help us?
Adriano Munin
ERROR: linux-libc-headers-4.12-r0 do_package_write_ipk: The recipe linux-libc-headers is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7at2hf-neon/linux-libc-headers-dev_4.12-r0_armv7at2hf-neon.ipk
(not matched to any task)
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7at2hf-neon/linux-libc-headers-dbg_4.12-r0_armv7at2hf-neon.ipk
Please verify which recipe should provide the above files.
The build has stopped, as continuing in this scenario WILL break things - if not now, possibly in the future (we’ve seen builds fail several months later). If the system knew how to recover from this automatically it would, however there are several different scenarios which can result in this and we don’t know which one this is. It may be you have switched providers of something like virtual/kernel (e.g. from linux-yocto to linux-yocto-dev), in that case you need to execute the clean task for both recipes and it will resolve this error. It may be you changed DISTRO_FEATURES from systemd to udev or vice versa. Cleaning those recipes should again resolve this error, however switching DISTRO_FEATURES on an existing build directory is not supported - you should really clean out tmp and rebuild (reusing sstate should be safe). It could be the overlapping files detected are harmless in which case adding them to SSTATE_DUPWHITELIST may be the correct solution. It could also be your build is including two different conflicting versions of things (e.g. bluez 4 and bluez 5 and the correct solution for that would be to resolve the conflict. If in doubt, please ask on the mailing list, sharing the error and filelist above.
ERROR: linux-libc-headers-4.12-r0 do_package_write_ipk: If the above message is too much, the simpler version is you’re advised to wipe out tmp and rebuild (reusing sstate is fine). That will likely fix things in most (but not all) cases.
ERROR: linux-libc-headers-4.12-r0 do_package_write_ipk: Function failed: sstate_task_postfunc
ERROR: Logfile of failure stored in: /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/linux-libc-headers/4.12-r0/temp/log.do_package_write_ipk.22145
ERROR: Task (/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-kernel/linux-libc-headers/linux-libc-headers_4.12.bb:do_package_write_ipk) failed with exit code ‘1’
ERROR: glibc-2.26-r0 do_package_write_ipk: The recipe glibc is trying to install files into a shared area when those files already exist. Those files and their manifest location are:
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libsotruss_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libc6-pic_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/ldd_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libc6-pcprofile_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/catchsegv_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libc6-staticdev_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libc6-doc_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libmemusage_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libc6-dbg_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libsegfault_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/tzcode_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libc6_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libc6-extra-nss_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libc6-utils_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libc6-dev_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/sln_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libcidn1_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/libc6-thread-db_2.26-r0_armv7ahf-neon.ipk
/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/deploy/ipk/armv7ahf-neon/nscd_2.26-r0_armv7ahf-neon.ipk
ERROR: glibc-2.26-r0 do_package_write_ipk: If the above message is too much, the simpler version is you’re advised to wipe out tmp and rebuild (reusing sstate is fine). That will likely fix things in most (but not all) cases.
ERROR: glibc-2.26-r0 do_package_write_ipk: Function failed: sstate_task_postfunc
ERROR: Logfile of failure stored in: /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/armv7ahf-neon-angstrom-linux-gnueabi/glibc/2.26-r0/temp/log.do_package_write_ipk.22146
ERROR: Task (/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/glibc/glibc_2.26.bb:do_package_write_ipk) failed with exit code ‘1’
Hi @adrianomunin.eld ,
Normally this issue happens when deleting the build/tmp folder without deleting the deploy folder.
What happens is that the build is trying to generate the files again, but those files were already deployed by another build before. To solve this issue, you will need to delete the files available in the deploy folder directly, and Yocto will build and deploy these files again.
If you want to start a clean build, the suggestion is to delete build/tmp and build/deploy and restart the bitbake.
Daniel Morais
Hi Daniel,
now I excluded the tmp and deploy content but and I am getting the error described below:
DEBUG: Executing python function set_image_size
DEBUG: Python function set_image_size finished
DEBUG: Executing python function extend_recipe_sysroot
NOTE: Direct dependencies are [‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/opkg/opkg_0.3.5.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/pseudo/pseudo_1.8.2.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/update-rc.d/update-rc.d_0.7.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/pigz/pigz_2.3.4.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/opkg-utils/opkg-utils_0.3.5.bb:do_populate_sysroot’, ‘/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/glibc/glibc_2.26.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-kernel/dtc/dtc_1.4.4.bb:do_populate_sysroot’, ‘/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-kernel/kmod/depmodwrapper-cross_1.0.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/dosfstools/dosfstools_4.1.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/prelink/prelink_git.bb:do_populate_sysroot’, ‘/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/qemu/qemuwrapper-cross_1.0.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/fdisk/gptfdisk_1.0.3.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/makedevs/makedevs_1.0.1.bb:do_populate_sysroot’, ‘/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/gcc/gcc-cross_7.3.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/parted/parted_3.2.bb:do_populate_sysroot’, ‘/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-kernel/kmod/kmod-native_git.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/bc/bc_1.06.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-support/lzop/lzop_1.03.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-angstrom/recipes-tweaks/xz/xz_5.2.0.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-bsp/u-boot/u-boot-mkimage_2017.09.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/e2fsprogs/e2fsprogs_1.43.5.bb:do_populate_sysroot’, ‘/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-freescale-3rdparty/recipes-bsp/u-boot/u-boot-toradex_2016.11.bb:do_populate_sysroot’, ‘/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/glibc/ldconfig-native_2.12.1.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/pbzip2/pbzip2_1.1.13.bb:do_populate_sysroot’, ‘/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/quilt/quilt-native_0.65.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-support/bmap-tools/bmap-tools_3.4.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/mtools/mtools_4.0.18.bb:do_populate_sysroot’, ‘virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-connectivity/openssl/openssl_1.0.2o.bb:do_populate_sysroot’, ‘/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/mklibs/mklibs-native_0.1.43.bb:do_populate_sysroot’, ‘/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_4.9-2.3.x.bb:do_populate_sysroot’, ‘/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/gcc/gcc-runtime_7.3.bb:do_populate_sysroot’, ‘/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/binutils/binutils-cross_2.29.1.bb:do_populate_sysroot’]
NOTE: Installed into sysroot: [‘dosfstools-native’, ‘gptfdisk-native’, ‘gcc-cross-arm’, ‘parted-native’, ‘bc-native’, ‘lzop-native’, ‘u-boot-mkimage-native’, ‘mtools-native’, ‘linux-toradex’, ‘binutils-cross-arm’, ‘mpfr-native’, ‘gmp-native’, ‘libmpc-native’]
NOTE: Skipping as already exists in sysroot: [‘opkg-native’, ‘pseudo-native’, ‘update-rc.d-native’, ‘pigz-native’, ‘opkg-utils-native’, ‘glibc’, ‘dtc-native’, ‘depmodwrapper-cross’, ‘prelink-native’, ‘qemuwrapper-cross’, ‘makedevs-native’, ‘kmod-native’, ‘xz-native’, ‘e2fsprogs-native’, ‘u-boot-toradex’, ‘ldconfig-native’, ‘pbzip2-native’, ‘quilt-native’, ‘bmap-tools-native’, ‘openssl-native’, ‘mklibs-native’, ‘gcc-runtime’, ‘libarchive-native’, ‘pkgconfig-native’, ‘automake-native’, ‘gnu-config-native’, ‘libtool-native’, ‘libsolv-native’, ‘autoconf-native’, ‘linux-libc-headers’, ‘binutils-native’, ‘elfutils-native’, ‘shadow-native’, ‘texinfo-dummy-native’, ‘zlib-native’, ‘util-linux-native’, ‘gettext-minimal-native’, ‘readline-native’, ‘ncurses-native’, ‘lzo-native’, ‘attr-native’, ‘systemd-systemctl-native’, ‘cryptodev-linux-native’, ‘makedepend-native’, ‘bison-native’, ‘flex-native’, ‘qemu-native’, ‘popt-native’, ‘gtk-doc-native’, ‘bzip2-native’, ‘debianutils-native’, ‘nss-native’, ‘python3-setuptools-native’, ‘python3-native’, ‘libgcc’, ‘expat-native’, ‘rpm-native’, ‘cmake-native’, ‘m4-native’, ‘xproto-native’, ‘util-macros-native’, ‘glib-2.0-native’, ‘alsa-lib-native’, ‘pixman-native’, ‘sqlite3-native’, ‘nspr-native’, ‘unzip-native’, ‘db-native’, ‘file-native’, ‘dbus-native’, ‘curl-native’, ‘gettext-native’, ‘libpcre-native’, ‘libffi-native’, ‘libpng-native’]
DEBUG: sed -e ‘s:[1]*/:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/recipe-sysroot-native/:g’ /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/sysroots-components/x86_64/gcc-cross-arm/fixmepath /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/sysroots-components/x86_64/gmp-native/fixmepath | xargs sed -i -e ‘s:FIXMESTAGINGDIRTARGET:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/recipe-sysroot:g; s:FIXMESTAGINGDIRHOST:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/recipe-sysroot-native:g’ -e ‘s:FIXME_COMPONENTS_DIR:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/sysroots-components:g’ -e ‘s:FIXME_HOSTTOOLS_DIR:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/hosttools:g’ -e ‘s:FIXME_PKGDATA_DIR:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/pkgdata/apalis-imx6:g’ -e ‘s:FIXME_PSEUDO_LOCALSTATEDIR:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/pseudo/:g’ -e ‘s:FIXME_LOGFIFO:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/temp/fifo.10149:g’
DEBUG: Python function extend_recipe_sysroot finished
DEBUG: Executing shell function do_image_wic
INFO: Creating image(s)…
WARNING: bootloader config not specified, using defaults
ERROR: _exec_cmd: install -m 0644 -D /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../deploy/images/apalis-imx6/zImage-imx6q-apalis-eval.dtb /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/deploy-core-image-minimal-image-complete/Angstrom-core-image-minimal-glibc-ipk-v2017.12-apalis-imx6/tmp.wic.aquzrx3d/boot.1/imx6q-apalis-eval.dtb returned ‘1’ instead of 0
output: install: cannot stat ‘/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../deploy/images/apalis-imx6/zImage-imx6q-apalis-eval.dtb’: No such file or directory
WARNING: exit code 1 from a shell command.
ERROR: Function failed: do_image_wic (log file is located at /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_image_wic.10149)
Do you know what can be?
Adriano Munin
  1. ^/ ↩︎
Please try to execute a clean and build it again as below:
bitbake <image-recipe> -c cleanall && bitbake <image-recipe>
Daniel Morais
Hi Daniel,
thanks for the quick response, but I get the same error.
I deleted the tmp and deploy content, and then execute “bitbake core-image-minimal -c cleanall && bitbake core-image-minimal”, as suggested.
NOTE: Direct dependencies are ['/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_4.9-2.3.x.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-freescale-3rdparty/recipes-bsp/u-boot/u-boot-toradex_2016.11.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/gcc/gcc-cross_7.3.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/glibc/glibc_2.26.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/bc/bc_1.06.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/pbzip2/pbzip2_1.1.13.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/dosfstools/dosfstools_4.1.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/qemu/qemuwrapper-cross_1.0.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-angstrom/recipes-tweaks/xz/xz_5.2.0.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/prelink/prelink_git.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/pseudo/pseudo_1.8.2.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-kernel/dtc/dtc_1.4.4.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/glibc/ldconfig-native_2.12.1.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-connectivity/openssl/openssl_1.0.2o.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/quilt/quilt-native_0.65.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/gcc/gcc-runtime_7.3.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/update-rc.d/update-rc.d_0.7.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/mtools/mtools_4.0.18.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/parted/parted_3.2.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-bsp/u-boot/u-boot-mkimage_2017.09.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-support/lzop/lzop_1.03.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/makedevs/makedevs_1.0.1.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/binutils/binutils-cross_2.29.1.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/pigz/pigz_2.3.4.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/opkg-utils/opkg-utils_0.3.5.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/fdisk/gptfdisk_1.0.3.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/mklibs/mklibs-native_0.1.43.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/opkg/opkg_0.3.5.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-support/bmap-tools/bmap-tools_3.4.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-kernel/kmod/depmodwrapper-cross_1.0.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/e2fsprogs/e2fsprogs_1.43.5.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-kernel/kmod/kmod-native_git.bb:do_populate_sysroot']
NOTE: Installed into sysroot: ['linux-toradex', 'gcc-cross-arm', 'bc-native', 'dosfstools-native', 'mtools-native', 'parted-native', 'u-boot-mkimage-native', 'lzop-native', 'binutils-cross-arm', 'gptfdisk-native', 'gmp-native', 'mpfr-native', 'libmpc-native']
NOTE: Skipping as already exists in sysroot: ['u-boot-toradex', 'glibc', 'pbzip2-native', 'qemuwrapper-cross', 'xz-native', 'prelink-native', 'pseudo-native', 'dtc-native', 'ldconfig-native', 'openssl-native', 'quilt-native', 'gcc-runtime', 'update-rc.d-native', 'makedevs-native', 'pigz-native', 'opkg-utils-native', 'mklibs-native', 'opkg-native', 'bmap-tools-native', 'depmodwrapper-cross', 'e2fsprogs-native', 'kmod-native', 'systemd-systemctl-native', 'bzip2-native', 'qemu-native', 'makedepend-native', 'cryptodev-linux-native', 'pkgconfig-native', 'libgcc', 'linux-libc-headers', 'automake-native', 'libtool-native', 'texinfo-dummy-native', 'autoconf-native', 'gnu-config-native', 'gettext-minimal-native', 'ncurses-native', 'util-linux-native', 'readline-native', 'bison-native', 'zlib-native', 'flex-native', 'popt-native', 'libarchive-native', 'libsolv-native', 'python3-native', 'python3-setuptools-native', 'attr-native', 'nss-native', 'binutils-native', 'elfutils-native', 'shadow-native', 'lzo-native', 'debianutils-native', 'gtk-doc-native', 'pixman-native', 'glib-2.0-native', 'alsa-lib-native', 'xproto-native', 'util-macros-native', 'm4-native', 'expat-native', 'rpm-native', 'cmake-native', 'sqlite3-native', 'unzip-native', 'nspr-native', 'libpng-native', 'gettext-native', 'libpcre-native', 'libffi-native', 'file-native', 'dbus-native', 'db-native', 'curl-native']
DEBUG: sed -e 's:^[^/]*/:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/recipe-sysroot-native/:g' /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/sysroots-components/x86_64/gcc-cross-arm/fixmepath /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/sysroots-components/x86_64/gmp-native/fixmepath | xargs sed -i -e 's:FIXMESTAGINGDIRTARGET:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/recipe-sysroot:g; s:FIXMESTAGINGDIRHOST:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/recipe-sysroot-native:g' -e 's:FIXME_COMPONENTS_DIR:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/sysroots-components:g' -e 's:FIXME_HOSTTOOLS_DIR:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/hosttools:g' -e 's:FIXME_PKGDATA_DIR:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/pkgdata/apalis-imx6:g' -e 's:FIXME_PSEUDO_LOCALSTATEDIR:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/pseudo/:g' -e 's:FIXME_LOGFIFO:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/temp/fifo.31741:g'
INFO: Creating image(s)...
ERROR: _exec_cmd: install -m 0644 -D /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../deploy/images/apalis-imx6/zImage-imx6q-apalis-eval.dtb /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/deploy-core-image-minimal-image-complete/Angstrom-core-image-minimal-glibc-ipk-v2017.12-apalis-imx6/tmp.wic.c649h0k5/boot.1/imx6q-apalis-eval.dtb returned '1' instead of 0
output: install: cannot stat '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../deploy/images/apalis-imx6/zImage-imx6q-apalis-eval.dtb': No such file or directory
ERROR: Function failed: do_image_wic (log file is located at /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_image_wic.31741)
Adriano Munin
It’s strange since it’s not finding the imx6q-apalis-eval.dtb file, it seems that something messed your Yocto system.
Since you are using BSP 2.8, which is quite old, can you please try deleting the folders deploy, build/buildhistory, build/cache, build/sstate-cache and build/tmp-glibc and try to rebuild it again?
Daniel Morais
Hi Daniel,
this time the build process took much more time, but it brokes at the same point:
NOTE: Direct dependencies are ['/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-freescale-3rdparty/recipes-bsp/u-boot/u-boot-toradex_2016.11.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/makedevs/makedevs_1.0.1.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/dosfstools/dosfstools_4.1.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/fdisk/gptfdisk_1.0.3.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/pigz/pigz_2.3.4.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-support/bmap-tools/bmap-tools_3.4.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/mtools/mtools_4.0.18.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/gcc/gcc-runtime_7.3.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_4.9-2.3.x.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/update-rc.d/update-rc.d_0.7.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/opkg-utils/opkg-utils_0.3.5.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-support/lzop/lzop_1.03.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/pseudo/pseudo_1.8.2.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-kernel/kmod/kmod-native_git.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-bsp/u-boot/u-boot-mkimage_2017.09.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-connectivity/openssl/openssl_1.0.2o.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/mklibs/mklibs-native_0.1.43.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-kernel/dtc/dtc_1.4.4.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/glibc/ldconfig-native_2.12.1.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/opkg/opkg_0.3.5.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-kernel/kmod/depmodwrapper-cross_1.0.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/pbzip2/pbzip2_1.1.13.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/glibc/glibc_2.26.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/e2fsprogs/e2fsprogs_1.43.5.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/quilt/quilt-native_0.65.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/bc/bc_1.06.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-angstrom/recipes-tweaks/xz/xz_5.2.0.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/gcc/gcc-cross_7.3.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/parted/parted_3.2.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/qemu/qemuwrapper-cross_1.0.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/prelink/prelink_git.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/binutils/binutils-cross_2.29.1.bb:do_populate_sysroot']
NOTE: Installed into sysroot: ['dosfstools-native', 'gptfdisk-native', 'mtools-native', 'linux-toradex', 'lzop-native', 'u-boot-mkimage-native', 'bc-native', 'gcc-cross-arm', 'parted-native', 'binutils-cross-arm', 'mpfr-native', 'gmp-native', 'libmpc-native']
NOTE: Skipping as already exists in sysroot: ['u-boot-toradex', 'makedevs-native', 'pigz-native', 'bmap-tools-native', 'gcc-runtime', 'update-rc.d-native', 'opkg-utils-native', 'pseudo-native', 'kmod-native', 'openssl-native', 'mklibs-native', 'dtc-native', 'ldconfig-native', 'opkg-native', 'depmodwrapper-cross', 'pbzip2-native', 'glibc', 'e2fsprogs-native', 'quilt-native', 'xz-native', 'qemuwrapper-cross', 'prelink-native', 'systemd-systemctl-native', 'automake-native', 'gnu-config-native', 'libtool-native', 'pkgconfig-native', 'autoconf-native', 'ncurses-native', 'popt-native', 'util-linux-native', 'zlib-native', 'python3-setuptools-native', 'python3-native', 'debianutils-native', 'gettext-minimal-native', 'shadow-native', 'qemu-native', 'flex-native', 'texinfo-dummy-native', 'nss-native', 'bison-native', 'libgcc', 'linux-libc-headers', 'lzo-native', 'gtk-doc-native', 'cryptodev-linux-native', 'makedepend-native', 'libarchive-native', 'libsolv-native', 'bzip2-native', 'attr-native', 'readline-native', 'binutils-native', 'elfutils-native', 'm4-native', 'unzip-native', 'sqlite3-native', 'glib-2.0-native', 'alsa-lib-native', 'pixman-native', 'nspr-native', 'xproto-native', 'util-macros-native', 'expat-native', 'rpm-native', 'cmake-native', 'libffi-native', 'libpcre-native', 'gettext-native', 'libpng-native', 'db-native', 'file-native', 'dbus-native', 'curl-native']
DEBUG: sed -e 's:^[^/]*/:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/recipe-sysroot-native/:g' /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/sysroots-components/x86_64/gcc-cross-arm/fixmepath /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/sysroots-components/x86_64/gmp-native/fixmepath | xargs sed -i -e 's:FIXMESTAGINGDIRTARGET:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/recipe-sysroot:g; s:FIXMESTAGINGDIRHOST:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/recipe-sysroot-native:g' -e 's:FIXME_COMPONENTS_DIR:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/sysroots-components:g' -e 's:FIXME_HOSTTOOLS_DIR:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/hosttools:g' -e 's:FIXME_PKGDATA_DIR:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/pkgdata/apalis-imx6:g' -e 's:FIXME_PSEUDO_LOCALSTATEDIR:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/pseudo/:g' -e 's:FIXME_LOGFIFO:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/temp/fifo.15807:g'
ERROR: _exec_cmd: install -m 0644 -D /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../deploy/images/apalis-imx6/zImage-imx6q-apalis-eval.dtb /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/deploy-core-image-minimal-image-complete/Angstrom-core-image-minimal-glibc-ipk-v2017.12-apalis-imx6/tmp.wic.c95g9m5e/boot.1/imx6q-apalis-eval.dtb returned '1' instead of 0
ERROR: Function failed: do_image_wic (log file is located at /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_image_wic.15807)
Thanks in advance and best regards,
Adriano Munin
Can you please try to execute the following?
bitbake linux-toradex -c cleanall && bitbake <image-name>
Daniel Morais
Hi Daniel,
Unfortunately bitbake linux-toradex -c cleanall && bitbake core-image-minimal not works :
Terminal execution:
oxigena@oxigena-VirtualBox:~/Desktop/oe-core-linoOLD14.Abril.2023/build$ bitbake linux-toradex -c cleanall && bitbake core-image-minimal
Loading cache: 100% |########################################################################################################################################################################| Time: 0:00:02
Loaded 3904 entries from dependency cache.
Parsing recipes: 100% |######################################################################################################################################################################| Time: 0:00:20
Parsing of 3035 .bb files complete (3034 cached, 1 parsed). 3905 targets, 495 skipped, 1 masked, 0 errors.
WARNING: No recipes available for:
  /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-freescale/dynamic-layers/browser-layer/recipes-browser/chromium/chromium-wayland_48.0.2548.0.bbappend
  /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-freescale/dynamic-layers/browser-layer/recipes-browser/chromium/chromium_52.0.2743.76.bbappend
  /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-toradex-tegra/recipes-graphics/wayland/weston_1.%.bbappend
  /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-toradex-tegra/jetson-tk1/recipes-graphics/xorg-xserver/xserver-xorg_1.17.2.bbappend
Build Configuration:
BB_VERSION           = "1.36.0"
BUILD_SYS            = "x86_64-linux"
NATIVELSBSTRING      = "ubuntu-16.04"
TARGET_SYS           = "arm-angstrom-linux-gnueabi"
MACHINE              = "apalis-imx6"
DISTRO               = "angstrom"
DISTRO_VERSION       = "v2017.12"
TUNE_FEATURES        = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU           = "hard"
meta-angstrom
meta-toradex-nxp
meta-freescale
meta-toradex-tegra
meta-jetson-tk1
meta-toradex-bsp-common
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python
meta-lxde
meta-browser
meta-qt4
meta-qt5
meta-qt5-extra
meta-freescale-distro
meta-toradex-demos   = "<unknown>:<unknown>"
meta-vertex-hdmi     = "master:f6f17260dee30e88cb8248d027e4707e7527e6ba"
meta                 = "<unknown>:<unknown>"
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:00
NOTE: Executing RunQueue Tasks
NOTE: Tasks Summary: Attempted 3 tasks of which 0 didn't need to be rerun and all succeeded.
NOTE: Writing buildhistory
Summary: There was 1 WARNING message shown.
Loading cache: 100% |########################################################################################################################################################################| Time: 0:00:01
Parsing recipes: 100% |######################################################################################################################################################################| Time: 0:00:19
DISTRO               = "angstrom"
TARGET_FPU           = "hard"
meta-angstrom
meta-toradex-nxp
meta-freescale
meta-toradex-tegra
meta-jetson-tk1
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python
meta-lxde
meta-browser
meta-qt4
meta-qt5
meta-qt5-extra
Initialising tasks: 100% |###################################################################################################################################################################| Time: 0:00:04
NOTE: Executing SetScene Tasks
ERROR: core-image-minimal-1.0-r0 do_image_teziimg: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
     0001:
 *** 0002:rootfs_tezi_json(d)
     0003:
File: '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-toradex-bsp-common/classes/image_type_tezi.bbclass', lineno: 202, function: rootfs_tezi_json
     0198:
     0199:    if bb.utils.contains("TORADEX_FLASH_TYPE", "rawnand", True, False, d):
     0200:        data["mtddevs"] = rootfs_tezi_rawnand(d)
     0201:    else:
 *** 0202:        data["blockdevs"] = rootfs_tezi_emmc(d)
     0203:
     0204:    deploy_dir = d.getVar('DEPLOY_DIR_IMAGE', True)
     0205:    with open(os.path.join(deploy_dir, 'image.json'), 'w') as outfile:
     0206:        json.dump(data, outfile, indent=4)
File: '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-toradex-bsp-common/classes/image_type_tezi.bbclass', lineno: 44, function: rootfs_tezi_emmc
     0040:            bootfiles.append(os.path.join(deploydir, kernel + "-" + dtb))
     0041:
     0042:    args = ['du', '-kLc']
     0043:    args.extend(bootfiles)
 *** 0044:    output = subprocess.check_output(args)
     0045:    bootfssize_kb = int(output.splitlines()[-1].split()[0])
     0046:
     0047:    bootpart_rawfiles = []
     0048:
File: '/usr/lib/python3.5/subprocess.py', lineno: 626, function: check_output
     0622:        # empty string. That is maintained here for backwards compatibility.
     0623:        kwargs['input'] = '' if kwargs.get('universal_newlines', False) else b''
     0624:
     0625:    return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
 *** 0626:               **kwargs).stdout
     0627:
     0628:
     0629:class CompletedProcess(object):
     0630:    """A process that has finished running.
File: '/usr/lib/python3.5/subprocess.py', lineno: 708, function: run
     0704:            raise
     0705:        retcode = process.poll()
     0706:        if check and retcode:
     0707:            raise CalledProcessError(retcode, process.args,
 *** 0708:                                     output=stdout, stderr=stderr)
     0709:    return CompletedProcess(process.args, retcode, stdout, stderr)
     0710:
     0711:
     0712:def list2cmdline(seq):
Exception: subprocess.CalledProcessError: Command '['du', '-kLc', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../deploy/images/apalis-imx6/zImage', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../deploy/images/apalis-imx6/zImage-imx6q-apalis-eval.dtb', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../deploy/images/apalis-imx6/zImage-imx6q-apalis-ixora.dtb', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../deploy/images/apalis-imx6/zImage-imx6q-apalis-ixora-v1.1.dtb']' returned non-zero exit status 1
Subprocess output:
5240	/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../deploy/images/apalis-imx6/zImage
5240	total
ERROR: core-image-minimal-1.0-r0 do_image_teziimg: Function failed: rootfs_tezi_json
ERROR: Logfile of failure stored in: /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_image_teziimg.25928
ERROR: Task (/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/images/core-image-minimal.bb:do_image_teziimg) failed with exit code '1'
ERROR: core-image-minimal-1.0-r0 do_image_wic: Function failed: do_image_wic (log file is located at /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_image_wic.25925)
ERROR: Logfile of failure stored in: /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_image_wic.25925
Log data follows:
| NOTE: Direct dependencies are ['virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/bc/bc_1.06.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/glibc/glibc_2.26.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-freescale-3rdparty/recipes-bsp/u-boot/u-boot-toradex_2016.11.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/quilt/quilt-native_0.65.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/pseudo/pseudo_1.8.2.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/qemu/qemuwrapper-cross_1.0.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/opkg-utils/opkg-utils_0.3.5.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/glibc/ldconfig-native_2.12.1.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/gcc/gcc-runtime_7.3.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-support/lzop/lzop_1.03.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/pbzip2/pbzip2_1.1.13.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/dosfstools/dosfstools_4.1.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/makedevs/makedevs_1.0.1.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_4.9-2.3.x.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/mklibs/mklibs-native_0.1.43.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/fdisk/gptfdisk_1.0.3.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/parted/parted_3.2.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-kernel/kmod/depmodwrapper-cross_1.0.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/binutils/binutils-cross_2.29.1.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/mtools/mtools_4.0.18.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-kernel/kmod/kmod-native_git.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/opkg/opkg_0.3.5.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-extended/pigz/pigz_2.3.4.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/e2fsprogs/e2fsprogs_1.43.5.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-kernel/dtc/dtc_1.4.4.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-connectivity/openssl/openssl_1.0.2o.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-bsp/u-boot/u-boot-mkimage_2017.09.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-support/bmap-tools/bmap-tools_3.4.bb:do_populate_sysroot', '/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/gcc/gcc-cross_7.3.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/update-rc.d/update-rc.d_0.7.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-angstrom/recipes-tweaks/xz/xz_5.2.0.bb:do_populate_sysroot', 'virtual:native:/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-devtools/prelink/prelink_git.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: []
| NOTE: Skipping as already exists in sysroot: ['bc-native', 'glibc', 'u-boot-toradex', 'quilt-native', 'pseudo-native', 'qemuwrapper-cross', 'opkg-utils-native', 'ldconfig-native', 'gcc-runtime', 'lzop-native', 'pbzip2-native', 'dosfstools-native', 'makedevs-native', 'linux-toradex', 'mklibs-native', 'gptfdisk-native', 'parted-native', 'depmodwrapper-cross', 'binutils-cross-arm', 'mtools-native', 'kmod-native', 'opkg-native', 'pigz-native', 'e2fsprogs-native', 'dtc-native', 'openssl-native', 'u-boot-mkimage-native', 'bmap-tools-native', 'gcc-cross-arm', 'update-rc.d-native', 'xz-native', 'prelink-native', 'automake-native', 'flex-native', 'texinfo-dummy-native', 'gnu-config-native', 'autoconf-native', 'libtool-native', 'linux-libc-headers', 'systemd-systemctl-native', 'qemu-native', 'libgcc', 'shadow-native', 'lzo-native', 'bzip2-native', 'pkgconfig-native', 'gettext-minimal-native', 'debianutils-native', 'util-linux-native', 'popt-native', 'ncurses-native', 'readline-native', 'zlib-native', 'bison-native', 'gtk-doc-native', 'nss-native', 'libsolv-native', 'libarchive-native', 'attr-native', 'cryptodev-linux-native', 'makedepend-native', 'python3-setuptools-native', 'python3-native', 'libmpc-native', 'mpfr-native', 'gmp-native', 'binutils-native', 'elfutils-native', 'm4-native', 'pixman-native', 'alsa-lib-native', 'glib-2.0-native', 'sqlite3-native', 'nspr-native', 'rpm-native', 'expat-native', 'cmake-native', 'xproto-native', 'util-macros-native', 'unzip-native', 'libpng-native', 'gettext-native', 'libffi-native', 'libpcre-native', 'db-native', 'dbus-native', 'file-native', 'curl-native']
| ERROR: _exec_cmd: install -m 0644 -D /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../deploy/images/apalis-imx6/zImage-imx6q-apalis-eval.dtb /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/deploy-core-image-minimal-image-complete/Angstrom-core-image-minimal-glibc-ipk-v2017.12-apalis-imx6/tmp.wic.ow7tlnl8/boot.1/imx6q-apalis-eval.dtb returned '1' instead of 0
| ERROR: Function failed: do_image_wic (log file is located at /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/tmp-glibc/work/apalis_imx6-angstrom-linux-gnueabi/core-image-minimal/1.0-r0/temp/log.do_image_wic.25925)
ERROR: Task (/home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/openembedded-core/meta/recipes-core/images/core-image-minimal.bb:do_image_wic) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2117 tasks of which 2094 didn't need to be rerun and 2 failed.
Summary: 2 tasks failed:
Summary: There were 3 ERROR messages shown, returning a non-zero exit code.
log.do_image_wic.25925:
Adriano Munin
This is really strange, the kernel files aren’t being deployed to the deploy folder.
Please try to execute bitbake linux-toradex -c cleanall && bitbake linux-toradex and verify if the file imx6q-apalis-eval.dtb exists on the deploy directory, this will clean the kernel build and build it again, generating the zImage and .dtb files. If the file doesn’t exist and you have another layer included, please try to remove this layer and do the same test again to verify if with this change the files begin to be deployed correctly.
Daniel Morais
Hi Daniel,
the linux-toradex build works, but it does not generate imx6q-apalis-eval.dtb.
I don know how many extra layers added I have. How could I know it and remove it?
In the Layers folder I have:
oxigena@oxigena-VirtualBox:~/Desktop/oe-core-linoOLD14.Abril.2023/layers$ ls
meta-angstrom            meta-qt4                 meta-toradex-tegra
meta-browser             meta-qt5                 meta-vertex-agt
meta-freescale           meta-qt5-extra           meta-vertex-hdmi
meta-freescale-3rdparty  meta-svb19-agt           meta-vertex-hdmiV1
meta-freescale-distro    meta-svb19-hdmi          meta-vertex-lvds
meta-jetson-tk1          meta-toradex-bsp-common  openembedded-core
meta-lxde                meta-toradex-demos
meta-openembedded        meta-toradex-nxp
Build success logs:
oxigena@oxigena-VirtualBox:~/Desktop/oe-core-linoOLD14.Abril.2023/build$ bitbake linux-toradex -c cleanall && bitbake linux-toradex
WARNING: /home/oxigena/Desktop/oe-core-linoOLD14.Abril.2023/build/../layers/meta-toradex-demos/recipes-images/images/console-tdx-image.bb: Variable key IMAGE_NAME_${MACHINE} (${MACHINE}_vertex-10.1-HDMI_${IHM_SOFTWARE_VERSION}) replaces original key IMAGE_NAME_apalis-imx6 (Apalis-iMX6_${IMAGE_BASENAME}).
Parsing recipes: 100% |#########################################################################################################| Time: 0:03:55
Parsing of 3035 .bb files complete (0 cached, 3035 parsed). 3905 targets, 495 skipped, 1 masked, 0 errors.
DISTRO               = "angstrom"
TARGET_FPU           = "hard"
meta-angstrom
meta-toradex-nxp
meta-freescale
meta-toradex-tegra
meta-jetson-tk1
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python
meta-lxde
meta-browser
meta-qt4
meta-qt5
meta-qt5-extra
Initialising tasks: 100% |######################################################################################################| Time: 0:00:00
Summary: There were 2 WARNING messages shown.
Loading cache: 100% |###########################################################################################################| Time: 0:00:01
Parsing recipes: 100% |#########################################################################################################| Time: 0:00:19
DISTRO               = "angstrom"
TARGET_FPU           = "hard"
meta-angstrom
meta-toradex-nxp
meta-freescale
meta-toradex-tegra
meta-jetson-tk1
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python
meta-lxde
meta-browser
meta-qt4
meta-qt5
meta-qt5-extra
NOTE: Tasks Summary: Attempted 506 tasks of which 0 didn't need to be rerun and all succeeded.
Thanks and Best Regards,
Adriano Munin
You added the layer meta-vertex-hdmi that is not default on our project. Can you please try to remove it and check if the file is generated?
You can do this by changing the content of the build/conf/bblayers.conf file.
Daniel Morais
Hi @daniel_m.tx !
Removing the meta-vertex-hdmi layer it has builded with success!
Now I will investigate why this layer is broken.
Thanks!
