OS: linux
:: x64
:: WSL 2
Distro: Ubuntu 22.04.3 LTS
Extension activation logs:
Activating Torizon IDE ...
Telemetry is enabled
Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://github.com/toradex/torizon-experimental-torizon-ide-v2-docs/blob/main/USAGE-DATA.md#opt-out
Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
Resolving host IP address ...
Host IP address OK
Docker installed OK
Docker running OK
Docker compose OK
PowerShell OK
git OK
dig OK
avahi-resolve OK
nmap OK
iputils-ping OK
file OK
sshpass OK
net-tools OK
Cloning project templates
Project templates clone OK
Project templates fetched OK
Checkout templates repo to v2.3.2 OK
Checking connected devices ...
Scanning Torizon devices ...
Configuring debug id_rsa ...
Debug id_rsa OK
Torizon IDE extension activated
Checking host ip sanity ...
Host ip is OK
Device 10.0.0.150 set as Docker Host
Debian bookworm packages list load OK
ERROR :: publish-torizon-arm64 failed with exit code 1
Host ip is OK
ERROR :: Shell: torizon_twave-debug_1 failed with exit code 134
ERROR :: Shell: torizon_twave-debug_1 failed with exit code 137
Host ip is OK
Tasks logs:
* Executing task: pwsh .conf/validateDepsRunning.ps1
⚠️ VALIDATING ENVIRONMENT
✅ Environment is valid!
* Terminal will be reused by tasks, press any key to close it.
* Executing task: bash -c [[ ! -z "10.0.0.150" ]] && true || false
* Executing task: bash -c [[ "aarch64" == "aarch64" ]] && true || false
* Executing task: sleep 1
* Executing task: sshpass -p sensor scp -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /home/mllona/apollox/TWave/docker-compose.yml torizon@10.0.0.150:~/
Warning: Permanently added '10.0.0.150' (ED25519) to the list of known hosts.
* Executing task: sshpass -p sensor ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no torizon@10.0.0.150 LOCAL_REGISTRY=10.0.0.76 TAG=arm64 GPU=-vivante docker-compose down --remove-orphans
The DOCKER_LOGIN variable is not set. Defaulting to a blank string.
Stopping torizon_twave-debug_1 ...
Reported by: @undefined
If you have more data that you think that is interesting from the context of the issue please reply below.
