I have followed this tutorial for V2.8. The steps were very clear and laid out. In local.conf, I uncomment the correct machine and added the following two lines:
IMAGE_INSTALL_append = " mysql5"
ACCEPT_FSL_EUAL = "1"
After bitbaking, I moved the files to a flashdrive. The Toradex Easy Installer was able to identify this image, but errored out when I tried flashing it. Here is the error:
Error setting U-Boot environment
Line 1 not corrected terminated or too long
The image has not been written completely. Please restart the process, otherwise you might end up in a non-bootable system.
I am trying to get a MySQL database up and running on the Apalis iMX6. Is there a better way to go about doing this? Or, is there a way to correct this error message?
Thank you for taking the time to answer my question!
Looks like your uEnv.txt is empty. How exactly did you “moved the files to a flashdrive”?
Hello @alex.tx,
Thank you for responding to my original post! I used sudo cp -a apalis-imx6/. /media/admin1/usb-drive to copy the files over.
It looks like my uEnv.txt file is not empty, I attached it to this post. Could there possibly be something wrong with this file? If so, could you help me to fix it?
Thank you!
Hi @samantha
Usually after a successful build, there should be a Toradex Easy Installer Image (.tar) which you need to extract to the flashdrive. Did you get this .tar file?
Hello @jaski.tx!
Here are the contents of my folder, which include a .tar file.
Do any of these seem incorrect? Am I missing anything?
The image you posted is not shown.
Could you share the output of ls *.tar in text format? Thanks.
Yep @jaski.tx! Sorry for any confusion
Here is the output of ls *.tar:
Apalis-iMX6_LXDE-Image.bootfs.tar
Apalis-iMX6_LXDE-Image-Tezi_2.8b7-20200811.tar
marketing.tar
Hi Samantha
There is no issue.
You should extract this file to the flashdrive:
same issue solved.
big thanks
Perfect. Thanks for the feedback.
