I’m following the steps on the Splash Screen (Linux) page and I came across some errors.
Everything appeared to work fine until I got to the step where I needed to compile the kernel. Here’s what I’m getting.
chemtrac@chemtrac:~/linux-toradex$ make ARCH=arm CROSS_COMPILE=arm-angstrom-linux-gnueabi-
make: arm-angstrom-linux-gnueabi-gcc: Command not found
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
make[1]: `include/generated/mach-types.h' is up to date.
CC kernel/bounds.s
/bin/sh: 1: arm-angstrom-linux-gnueabi-gcc: not found
make[1]: *** [kernel/bounds.s] Error 127
make: *** [prepare0] Error 2
chemtrac@chemtrac:~/linux-toradex$ make ARCH=arm CROSS_COMPILE=arm-angstrom-linux-gnueabi- uImage
CC kernel/bounds.s
I’m running on an Ubuntu 64-bit system. I’m assuming I need to install some additional libraries.
Any help would be appreciated. Thanks.
Scott B.
