OS: linux
:: arm64
Distro: Ubuntu 22.04.3 LTS
Extension activation logs:
Activating Torizon IDE ...
Telemetry is enabled
Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://github.com/toradex/torizon-experimental-torizon-ide-v2-docs/blob/main/USAGE-DATA.md#opt-out
Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
Resolving host IP address ...
Host IP address OK
Docker installed OK
Docker running OK
Docker compose OK
PowerShell OK
git OK
dig OK
avahi-resolve OK
nmap OK
iputils-ping OK
file OK
sshpass OK
net-tools OK
Cloning project templates
Project templates clone OK
Checkout templates repo to dev OK
Project templates updated
Checking connected devices ...
Scanning Torizon devices ...
Configuring debug id_rsa ...
Debug id_rsa OK
Torizon IDE extension activated
ERROR :: run-torizon-binfmt failed with exit code 64
Tasks logs:
The argument 'exit' is not recognized as the name of a script file. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
Usage: pwsh[.exe] [-Login] [[-File] <filePath> [args]]
[-Command { - | <script-block> [-args <arg-array>]
| <string> [<CommandParameters>] } ]
[-CommandWithArgs <string> [<CommandParameters>]
[-ConfigurationName <string>] [-ConfigurationFile <filePath>]
[-CustomPipeName <string>] [-EncodedCommand <Base64EncodedCommand>]
[-ExecutionPolicy <ExecutionPolicy>] [-InputFormat {Text | XML}]
[-Interactive] [-MTA] [-NoExit] [-NoLogo] [-NonInteractive] [-NoProfile]
[-NoProfileLoadTime] [-OutputFormat {Text | XML}]
[-SettingsFile <filePath>] [-SSHServerMode] [-STA]
[-Version] [-WindowStyle <style>]
[-WorkingDirectory <directoryPath>]
pwsh[.exe] -h | -Help | -? | /?
PowerShell Online Help https://aka.ms/powershell-docs
All parameters are case-insensitive.
* Der Terminalprozess "pwsh 'exit'" wurde mit folgendem Exitcode beendet: 64.
* Das Terminal wird von Aufgaben wiederverwendet, drücken Sie zum Schließen eine beliebige Taste.
Reported by: @undefined
If you have more data that you think that is interesting from the context of the issue please reply below.
