OS: linux
:: x64
:: WSL 2
Distro: Ubuntu 22.04.2 LTS
Extension activation logs:
Activating Torizon IDE ...
Telemetry is enabled
Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://github.com/toradex/torizon-experimental-torizon-ide-v2-docs/blob/main/USAGE-DATA.md#opt-out
Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
Resolving host IP address ...
Host IP address OK
Docker installed OK
Docker running OK
Docker compose OK
PowerShell OK
git OK
dig OK
avahi-resolve OK
nmap OK
iputils-ping OK
file OK
sshpass OK
net-tools OK
Cloning project templates
Project templates clone OK
Checkout templates repo to dev OK
Project templates updated
Checking connected devices ...
Scanning Torizon devices ...
Configuring debug id_rsa ...
Debug id_rsa OK
Torizon IDE extension activated
Checking host ip sanity ...
Host ip is OK
Device 192.168.1.115 set as Docker Host
Debian bookworm packages list load OK
ERROR :: pre-cleanup failed with exit code 1
Tasks logs:
Container Runtime: docker
Run Arguments: -d -p 5002:5000 --restart=always registry:2
Container Name: registry
Error response from daemon: No such container: registry
Container does not exists. Starting ...
Unable to find image 'registry:2' locally
2: Pulling from library/registry
96526aa774ef: Pull complete
834bccaa730c: Pull complete
87a69098c0a9: Pull complete
afc17120a9f7: Pull complete
e5ac04f3acf5: Pull complete
Digest: sha256:8a60daaa55ab0df4607c4d8625b96b97b06fd2e6ca8528275472963c4ae8afa0
Status: Downloaded newer image for registry:2
c4bc7fbe56312b52d17d277dec83068da9bd163ad18faf5f4c0be0f39938ba98
* Terminal will be reused by tasks, press any key to close it.
* Executing task: pwsh -nop .conf/validateDepsRunning.ps1
⚠️ VALIDATING ENVIRONMENT
✅ Environment is valid!
* Executing task: bash -c [[ ! -z "192.168.1.115" ]] && true || false
* Executing task: bash -c [[ "aarch64" == "aarch64" ]] && true || false
* Executing task: [ $(/bin/python3 -m pip --version | awk '{print $2}' | cut -d'.' -f1) -lt 23 ] && /bin/python3 -m pip install --upgrade pip || true
Defaulting to user installation because normal site-packages is not writeable
Requirement already satisfied: pip in /usr/lib/python3/dist-packages (22.0.2)
Collecting pip
Downloading pip-23.3.1-py3-none-any.whl (2.1 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 2.1/2.1 MB 8.4 MB/s eta 0:00:00
Installing collected packages: pip
WARNING: The scripts pip, pip3, pip3.10 and pip3.11 are installed in '/home/tobias/.local/bin' which is not on PATH.
Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
Successfully installed pip-23.3.1
* Executing task: /bin/python3 -m pip install --break-system-packages -r requirements-debug.txt
Collecting debugpy (from -r requirements-debug.txt (line 1))
Downloading debugpy-1.8.0-cp310-cp310-manylinux_2_17_x86_64.manylinux2014_x86_64.whl.metadata (1.0 kB)
Downloading debugpy-1.8.0-cp310-cp310-manylinux_2_17_x86_64.manylinux2014_x86_64.whl (3.3 MB)
━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.3/3.3 MB 9.4 MB/s eta 0:00:00
DEPRECATION: distro-info 1.1build1 has a non-standard version number. pip 24.0 will enforce this behaviour change. A possible replacement is to upgrade to a newer version of distro-info or contact the author to suggest that they release a version with a conforming version number. Discussion can be found at https://github.com/pypa/pip/issues/12063
Installing collected packages: debugpy
Successfully installed debugpy-1.8.0
* Executing task: sleep 1
* Executing task: sshpass -p f3M70p$Wd scp -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no /home/tobias/quickstart/quickstart/docker-compose.yml torizon@192.168.1.115:~/
Warning: Permanently added '192.168.1.115' (ED25519) to the list of known hosts.
* Executing task: DOCKER_HOST=192.168.1.115:2375 docker-compose -p torizon down --remove-orphans
The command 'docker-compose' could not be found in this WSL 2 distro.
We recommend to activate the WSL integration in Docker Desktop settings.
For details about using Docker Desktop with WSL 2, visit:
https://docs.docker.com/go/wsl2/
* The terminal process "/bin/bash '-c', 'DOCKER_HOST=192.168.1.115:2375 docker-compose -p torizon down --remove-orphans'" failed to launch (exit code: 1).
Requirement already satisfied: debugpy in /home/tobias/.local/lib/python3.10/site-packages (from -r requirements-debug.txt (line 1)) (1.8.0)
Reported by: @undefined
If you have more data that you think that is interesting from the context of the issue please reply below.
