Hi all, I tried to flash the Toradex easy installer to an apalis iMX6. I used multiple host computers running different Windows operation systems, including Windows 8, Windows 10. Nevertheless, I met the following error message. I also plug the usb cable to USB2.0 connector but it does not help.
Do you have an idea how it happens?
error message (the last 2 lines):
config file <recovery\\\imx_usb.conf>
vid=0x15a2 pid=0x0054 file_name=mx6_usb_rom.conf
-> vid=0x1b67 pid=0x4fff file_name=mx6_usb_sdp_spl.conf
-> vid=0x1b67 pid=0x4000 file_name=mx6_usb_sdp_uboot.conf
vid=0x15a2 pid=0x0061 file_name=mx6_usb_rom.conf
vid=0x15a2 pid=0x0076 file_name=mx7_usb_rom.conf
-> vid=0x1b67 pid=0x4000 file_name=mx7_usb_sdp_uboot.conf
vid=0x15a2 pid=0x0080 file_name=mx6ull_usb_rom.conf
-> vid=0x1b67 pid=0x4000 file_name=mx6ull_usb_sdp_uboot.conf
config file <recovery\\\mx6_usb_rom.conf>
parse recovery\\\mx6_usb_rom.conf
Trying to open device vid=0x15a2 pid=0x0054
Interface 0 claimed
HAB security state: development mode (0x56787856)
== work item
filename SPL
load_size 0 bytes
load_addr 0x13f00000
dcd 0
clear_dcd 0
plug 0
jump_mode 3
jump_addr 0x00000000
== end work item
loading binary file(SPL) to 00907400, skip=0, fsize=bc00 type=aa
<<<48128, 48128 bytes>>>
succeeded (status 0x88888888)
jumping to 0x00907400
config file <recovery\\\mx6_usb_sdp_spl.conf>
parse recovery\\\mx6_usb_sdp_spl.conf
Trying to open device vid=0x1b67 pid=0x4fff.........................
Could not open device vid=0x1b67 pid=0x4fff
Press any key to continue . . .
I am using Apalis iMX6 on an Ixora Carrier Board, and a Windows 10 host. The answer from the serial port is the same wether I enter recovery mode from the U-Boot or shortening the hardware pads.
And you did remove JP2 and have nothing plugged into the lower X8?
BTW: Rather than hijacking an old question it would be better to ask a new one giving all the details about your environment so we may better help you.
The JP2 was already removed and no USB connected to the lower X8, I removed two USB devices I had connected to the upper X8 and X7 but the result is the same.
you.
Sorry about that, I’m new to the community. I’ll keep this in mind for future questions
May I suggest for you to try a different USB cable, USB port, going through a USB hub vs. direct connection or even trying a completely different PC preferably running any sane OS.
Ok I’ve changed the cable, I was using the USB micro A to female USB A cable from the carrier board accessory kit and a male USB A to male USB A cable i had in hand, now I use a normal USB micro A to male USB A and it Works just fine, thanks for the advice
