The following is console output of a clean shutdown for 2.7:
apalis-imx6-misa:~$
apalis-imx6-misa:~$
apalis-imx6-misa:~$
apalis-imx6-misa:~$
apalis-imx6-misa:~$
apalis-imx6-misa:~$ sudo halt
Password:
[ OK ] Closed Load/Save RF Kill Switc Stopping Session c1 of user misa.
[ OK ] Stopped target System Time Synchronized.
Stopping User Mana� Stopping Timestamping service...
[ OK ] Stopped Serial Getty on ttymxc0.
[ OK ] Stopped Misa startup service.
[ OK ] Stopped User Manager for UID 1000.
[ OK ] Stopped Session c1 of user misa.
[ OK ] Stopped Save/Restore Sound Card State.
[ OK ] Stopped Timestamping service.
[ OK ] Removed slice User Slice of misa.
[ OK ] Stopped target Multi-User System.
Stopping Avahi mDNS/DNS-SD Stack...
Stopping Login Service...
Stopping Xinetd A Powerful Replacement For Inetd...
Stopping Network Name Resolution...
Stopping Boa web server...
[ OK ] Stopped target Login Prompts.
Stopping Getty on tty1...
[ OK ] Removed slice system-serial\x2dgetty.slice.
[ OK ] Stopped Avahi mDNS/DNS-SD Stack.
[ OK ] Stopped Login Service.
[ OK ] Stopped Boa web server.
[ OK ] Stopped Network Name Resolution.
[ OK ] Stopped Xinetd A Powerful Replacement For Inetd.
[ OK ] Stopped Getty on tty1.
Stopping Permit User Sessions...
[ OK ] Removed slice system-getty.slice.
[ OK ] Stopped Permit User Sessions.
[ OK ] Stopped target Remote File Systems.
[ OK ] Stopped target Network.
Stopping Network Service...
[ OK ] Stopped Network Service.
Stopping D-Bus System Message Bus...
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped target Basic System.
[ OK ] Stopped target Slices.
[ OK ] Removed slice User and Session Slice.
[ OK ] Stopped target Paths.
[ OK ] Stopped Forward Password Requests to Wall Directory Watch.
[ OK ] Stopped Dispatch Password Requests to Console Directory Watch.
[ OK ] Stopped target Sockets.
[ OK ] Closed sshd.socket.
[ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Closed RPCbind Server Activation Socket.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Stopped target System Initialization.
Stopping Network Time Synchronization...
Stopping Load/Save Screen Backlight...htness of backlight:backlight...
[ OK ] Stopped Apply Kernel Variables.
Stopping Load/Save Random Seed...
Stopping Update UTMP about System Boot/Shutdown...
[ OK ] Stopped Load Kernel Modules.
[ OK ] Stopped Setup Virtual Console.
[ OK ] Stopped Network Time Synchronization.
[ OK ] Stopped Load/Save Screen Backlight Brightness of backlight:backlight.
[ OK ] Stopped Load/Save Random Seed.
[ OK ] Stopped Update UTMP about System Boot/Shutdown.
[ OK ] Removed slice system-systemd\x2dbacklight.slice.
[ OK ] Stopped Create Volatile Files and Directories.
[ OK ] Stopped target Local File Systems.
Unmounting /run/user/1000...
Unmounting Temporary Directory...
Unmounting /media/mmcblk0p1...
Unmounting /var/volatile...
[ OK ] Unmounted /run/user/1000.
[ OK ] Unmounted Temporary Directory.
[ OK ] Unmounted /media/mmcblk0p1.
[ OK ] Unmounted /var/volatile.
[ OK ] Stopped target Swap.
[ OK ] Reached target Unmount All Filesystems.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Stopped Create Static Device Nodes in /dev.
[ OK ] Reached target Shutdown.
[ 253.288109] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 253.304431] systemd-journald[183]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 253.420055] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 253.435235] systemd-shutdown[1]: Unmounting file systems.
[ 253.441154] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 253.494923] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 253.502881] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 253.510984] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 253.517059] systemd-shutdown[1]: All filesystems unmounted.
[ 253.522789] systemd-shutdown[1]: Deactivating swaps.
[ 253.527955] systemd-shutdown[1]: All swaps deactivated.
[ 253.533314] systemd-shutdown[1]: Detaching loop devices.
[ 253.543167] systemd-shutdown[1]: All loop devices detached.
[ 253.548840] systemd-shutdown[1]: Detaching DM devices.
[ 253.554350] systemd-shutdown[1]: All DM devices detached.
[ 253.563477] systemd-shutdown[1]: Halting system.
[ 256.128396] reboot: System halted
And then restarted by power cycling the Ixora board:
U-Boot 2016.11-2.7.5+g52259cf (Mar 15 2018 - 14:57:07 +0100)
CPU: Freescale i.MX6D rev1.5 at 792 MHz
Reset cause: POR
I2C: ready
DRAM: 512 MiB
PMIC: device id: 0x10, revision id: 0x21, programmed
auto-detected panel vga-rgb
Display: vga-rgb (640x480)
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX6 Dual 512MB V1.1B, Serial# 05095230
Net: using PHY at 7
FEC [PRIME]
Booting from internal eMMC chip...
reading imx6q-apalis-eval.dtb
50345 bytes read in 19 ms (2.5 MiB/s)
reading uImage
5209384 bytes read in 156 ms (31.8 MiB/s)
## Booting kernel from Legacy Image at 11000000 ...
Image Name: Linux-4.1.44-V2.7-misa+g18717e2
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 5209320 Bytes = 5 MiB
Load Address: 10008000
Entry Point: 10008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 12000000
Booting using the fdt blob at 0x12000000
Loading Kernel Image ... OK
Using Device Tree in place at 12000000, end 1200f4a8
Starting kernel ...
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.44-V2.7-misa+g18717e2 (nlanfran@XPS-13-9370) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP Fri 8
[ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Toradex Apalis iMX6Q/D Module on Apalis Evaluation Board
[ 0.000000] Reserved memory: created CMA memory pool at 0x1c000000, size 320 MiB
[ 0.000000] Reserved memory: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] PERCPU: Embedded 12 pages/cpu @8bb1a000 s16588 r8192 d24372 u49152
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: enable_wait_mode=off vmalloc=400M ip=off root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fec_mac=00:14:2d:4dM
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 181132K/524288K available (6751K kernel code, 239K rwdata, 2256K rodata, 332K init, 421K bss, 15476K reserved, 327680K cm)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xa0800000 - 0xff000000 (1512 MB)
[ 0.000000] lowmem : 0x80000000 - 0xa0000000 ( 512 MB)
[ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
[ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
[ 0.000000] .text : 0x80008000 - 0x808d40bc (9009 kB)
[ 0.000000] .init : 0x808d5000 - 0x80928000 ( 332 kB)
[ 0.000000] .data : 0x80928000 - 0x80963f20 ( 240 kB)
[ 0.000000] .bss : 0x80963f20 - 0x809cd6a0 ( 422 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Additional per-CPU info printed with stalls.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 ID prefetch enabled, offset 16 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 16 ways, 1024 kB
[ 0.000000] L2C-310: CACHE_ID 0x410000c7, AUX_CTRL 0x76470001
[ 0.000000] mxc_clocksource_init 3000000
[ 0.000000] Switching to timer-based delay loop, resolution 333ns
[ 0.000007] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[ 0.000023] clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.001101] Console: colour dummy device 80x30
[ 0.001723] console [tty1] enabled
[ 0.001746] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[ 0.001782] pid_max: default: 32768 minimum: 301
[ 0.001887] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001913] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002450] Initializing cgroup subsys freezer
[ 0.002486] Initializing cgroup subsys debug
[ 0.002521] CPU: Testing write buffer coherency: ok
[ 0.002775] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002872] Setting up static identity map for 0x10008280 - 0x100082d8
[ 0.004656] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.004730] Brought up 2 CPUs
[ 0.004778] SMP: Total of 2 processors activated (12.00 BogoMIPS).
[ 0.004798] CPU: All CPU(s) started in SVC mode.
[ 0.005225] devtmpfs: initialized
[ 0.018362] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.018753] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.018809] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.037298] pinctrl core: initialized pinctrl subsystem
[ 0.038409] NET: Registered protocol family 16
[ 0.046537] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.069691] cpuidle: using governor ladder
[ 0.099684] cpuidle: using governor menu
[ 0.099965] CPU identified as i.MX6Q, silicon rev 1.5
[ 0.125064] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.125109] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.126073] imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.127431] imx-gpc 20dc000.gpc: no fsl,ldo-bypass found!
[ 0.136843] usb_host_vbus: supplied by usb_host_vbus_hub
[ 0.137177] vgaarb: loaded
[ 0.137950] SCSI subsystem initialized
[ 0.138448] usbcore: registered new interface driver usbfs
[ 0.138535] usbcore: registered new interface driver hub
[ 0.138628] usbcore: registered new device driver usb
[ 0.139313] i2c-gpio i2c@0: using pins 80 (SDA) and 62 (SCL)
[ 0.140342] i2c i2c-1: IMX I2C adapter registered
[ 0.140378] i2c i2c-1: can't use DMA
[ 0.141918] stmpe-i2c 2-0041: stmpe811 detected, chip id: 0x811
[ 0.143813] i2c i2c-2: IMX I2C adapter registered
[ 0.143849] i2c i2c-2: can't use DMA
[ 0.144534] i2c i2c-3: IMX I2C adapter registered
[ 0.144569] i2c i2c-3: can't use DMA
[ 0.144731] Linux video capture interface: v2.00
[ 0.144805] pps_core: LinuxPPS API ver. 1 registered
[ 0.144827] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.144878] PTP clock support registered
[ 0.159734] imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.179732] imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.180634] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed ipu0 csi1
[ 0.180679] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
[ 0.180785] MIPI CSI2 driver module loaded
[ 0.180982] Advanced Linux Sound Architecture Driver Initialized.
[ 0.182648] Switched to clocksource mxc_timer1
[ 0.193481] NET: Registered protocol family 2
[ 0.194258] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.194329] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.194410] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.194475] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.194514] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.194693] NET: Registered protocol family 1
[ 0.194989] RPC: Registered named UNIX socket transport module.
[ 0.195018] RPC: Registered udp transport module.
[ 0.195036] RPC: Registered tcp transport module.
[ 0.195054] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.195754] CPU PMU: Failed to parse /soc/pmu/interrupt-affinity[0]
[ 0.195819] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 0.197460] Bus freq driver module loaded
[ 0.204434] VFS: Disk quotas dquot_6.6.0
[ 0.204631] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.206161] NFS: Registering the id_resolver key type
[ 0.206235] Key type id_resolver registered
[ 0.206256] Key type id_legacy registered
[ 0.206294] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.206796] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.207265] fuse init (API version 7.23)
[ 0.211272] io scheduler noop registered
[ 0.211314] io scheduler deadline registered
[ 0.211492] io scheduler cfq registered (default)
[ 0.213817] backlight supply power not found, using dummy regulator
[ 0.215426] MIPI DSI driver module loaded
[ 0.216825] 20e0000.hdmi_video supply HDMI not found, using dummy regulator
[ 0.218807] mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
[ 0.218866] fbcvt: 1920x1080@60: CVT Name - 2.073M9
[ 0.218991] mxc_sdc_fb fb@0: registered mxc display driver hdmi
[ 0.233494] mxc_sdc_fb fb@0: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 0.252731] imx-ipuv3 2400000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
[ 0.286613] mxc_sdc_fb fb@0: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 0.324247] Console: switching to colour frame buffer device 240x67
[ 0.359119] mxc_sdc_fb fb@1: mxcfb1 is turned off!
[ 0.359276] mxc_sdc_fb fb@2: mxcfb2 is turned off!
[ 0.359426] mxc_sdc_fb fb@3: mxcfb3 is turned off!
[ 0.360913] imx-sdma 20ec000.sdma: no iram assigned, using external mem
[ 0.361344] imx-sdma 20ec000.sdma: no event needs to be remapped
[ 0.361677] imx-sdma 20ec000.sdma: loaded firmware 3.3
[ 0.364357] imx-sdma 20ec000.sdma: initialized
[ 0.366126] pfuze100-regulator 2-0008: Full layer: 2, Metal layer: 1
[ 0.366846] pfuze100-regulator 2-0008: FAB: 0, FIN: 0
[ 0.366945] pfuze100-regulator 2-0008: pfuze100 found.
[ 0.381252] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 27, base_baud = 5000000) is a IMX
[ 1.251848] console [ttymxc0] enabled
[ 1.256495] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 303, base_baud = 5000000) is a IMX
[ 1.265904] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 304, base_baud = 5000000) is a IMX
[ 1.275278] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 305, base_baud = 5000000) is a IMX
[ 1.284983] [drm] Initialized drm 1.1.0 20060810
[ 1.290080] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[ 1.304227] brd: module loaded
[ 1.312030] loop: module loaded
[ 1.316435] ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
[ 1.324543] ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
[ 1.332711] ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
[ 1.341034] ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
[ 1.352202] ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
[ 1.359354] ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 1.368317] ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 1.378783] scsi host0: ahci-imx
[ 1.382404] ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 315
[ 1.392625] spi_imx 2008000.ecspi: probed
[ 1.397563] spi_imx 200c000.ecspi: probed
[ 1.402555] vcan: Virtual CAN interface driver
[ 1.411869] CAN device driver interface
[ 1.420776] 2090000.flexcan supply xceiver not found, using dummy regulator
[ 1.433440] flexcan 2090000.flexcan: device registered (reg_base=a0aa0000, irq=36)
[ 1.446092] 2094000.flexcan supply xceiver not found, using dummy regulator
[ 1.458735] flexcan 2094000.flexcan: device registered (reg_base=a0aa8000, irq=37)
[ 1.472360] 2188000.ethernet supply phy not found, using dummy regulator
[ 1.503054] pps pps0: new PPS source ptp0
[ 1.513330] libphy: fec_enet_mii_bus: probed
[ 1.524220] fec 2188000.ethernet eth0: registered PHC device 0
[ 1.535418] usbcore: registered new interface driver asix
[ 1.545880] usbcore: registered new interface driver ax88179_178a
[ 1.557036] usbcore: registered new interface driver cdc_ether
[ 1.567878] usbcore: registered new interface driver net1080
[ 1.578463] usbcore: registered new interface driver cdc_subset
[ 1.589297] usbcore: registered new interface driver zaurus
[ 1.599786] usbcore: registered new interface driver cdc_ncm
[ 1.610265] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.621697] ehci-pci: EHCI PCI platform driver
[ 1.631057] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.641421] usbcore: registered new interface driver usb-storage
[ 1.652402] usbcore: registered new interface driver usbserial
[ 1.663106] usbcore: registered new interface driver usbserial_generic
[ 1.674370] usbserial: USB Serial support registered for generic
[ 1.685146] usbcore: registered new interface driver ftdi_sio
[ 1.695619] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.707723] usbcore: registered new interface driver pl2303
[ 1.718037] usbserial: USB Serial support registered for pl2303
[ 1.728658] ata1: SATA link down (SStatus 0 SControl 300)
[ 1.738731] ahci-imx 2200000.sata: no device found, disabling link.
[ 1.739954] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.761500] ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
[ 1.777418] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.780166] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 1.780193] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
[ 1.792686] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 1.793505] hub 1-0:1.0: USB hub found
[ 1.793540] hub 1-0:1.0: 1 port detected
[ 1.794498] mousedev: PS/2 mouse device common for all mice
[ 1.845331] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 2
[ 1.864319] input: stmpe-ts as /devices/soc0/soc/2100000.aips-bus/21a4000.i2c/i2c-2/2-0041/stmpe-ts/input/input0
[ 1.879403] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.890455] hub 2-0:1.0: USB hub found
[ 1.899009] hub 2-0:1.0: 1 port detected
[ 1.910078] rtc-ds1307 1-0068: oscillator failed, set time!
[ 1.920631] rtc-ds1307 1-0068: rtc core: registered m41t0 as rtc0
[ 1.932174] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
[ 1.945849] i2c /dev entries driver
[ 1.955480] mxc_v4l2_output v4l2_out: V4L2 device registered as video16
[ 1.967159] mxc_v4l2_output v4l2_out: V4L2 device registered as video17
[ 1.980059] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 1.991063] sdhci: Secure Digital Host Controller Interface driver
[ 2.002094] sdhci: Copyright(c) Pierre Ossman
[ 2.011449] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.023094] /soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified
[ 2.035184] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 2.046605] sdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found
[ 2.102810] mmc1: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[ 2.112679] usb 1-1: new high-speed USB device number 2 using ci_hdrc
[ 2.126573] /soc/aips-bus@02100000/usdhc@02194000: voltage-ranges unspecified
[ 2.138533] sdhci-esdhc-imx 2194000.usdhc: Got CD GPIO
[ 2.149856] sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found
[ 2.202794] mmc2: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[ 2.215543] /soc/aips-bus@02100000/usdhc@02198000: voltage-ranges unspecified
[ 2.227912] sdhci-esdhc-imx 2198000.usdhc: No vqmmc regulator found
[ 2.265622] hub 1-1:1.0: USB hub found
[ 2.274327] hub 1-1:1.0: 4 ports detected
[ 2.282677] mmc0: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
[ 2.295634] mxc_vpu 2040000.vpu_fsl: VPU initialized
[ 2.305985] mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
[ 2.321096] caam 2100000.caam: Entropy delay = 3200
[ 2.357907] mmc0: MAN_BKOPS_EN bit is not set
[ 2.386352] mmc0: new DDR MMC card at address 0001
[ 2.391614] caam 2100000.caam: Instantiated RNG4 SH0
[ 2.406250] mmcblk0: mmc0:0001 Q2J54A 3.64 GiB
[ 2.415845] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 2.00 MiB
[ 2.426883] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 2.00 MiB
[ 2.446552] mmcblk0: p1 p2
[ 2.452375] caam 2100000.caam: Instantiated RNG4 SH1
[ 2.452386] caam 2100000.caam: device ID = 0x0a16010000000000 (Era -524)
[ 2.452393] caam 2100000.caam: job rings = 2, qi = 0
[ 2.557618] caam algorithms registered in /proc/crypto
[ 2.571658] caam_jr 2101000.jr0: registering rng-caam
[ 2.582542] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
[ 2.593601] snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
[ 2.606848] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.617514] usbcore: registered new interface driver usbhid
[ 2.628151] usbhid: USB HID core driver
[ 2.642277] stmpe-adc stmpe-adc: Initialized
[ 2.653840] sgtl5000 2-000a: sgtl5000 revision 0x11
[ 2.826073] imx-sgtl5000 sound: sgtl5000 <-> 2028000.ssi mapping ok
[ 2.839748] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 2004000.spdif mapping ok
[ 2.855054] imx-audio-hdmi sound-hdmi: hdmi-hifi <-> soc:hdmi_audio@00120000 mapping ok
[ 2.869555] NET: Registered protocol family 10
[ 2.879992] NET: Registered protocol family 17
[ 2.889486] can: controller area network core (rev 20120528 abi 9)
[ 2.900764] NET: Registered protocol family 29
[ 2.910276] can: raw protocol (rev 20120528)
[ 2.919564] can: broadcast manager protocol (rev 20120528 t)
[ 2.930312] can: netlink gateway (rev 20130117) max_hops=1
[ 2.941330] Key type dns_resolver registered
[ 2.952256] Registering SWP/SWPB emulation handler
[ 2.963153] 1ffc000.pcie supply pcie-bus not found, using dummy regulator
[ 3.301581] imx6q-pcie 1ffc000.pcie: phy link never came up
[ 3.311173] imx6q-pcie 1ffc000.pcie: failed to initialize host
[ 3.321067] imx6q-pcie: probe of 1ffc000.pcie failed with error -22
[ 3.333630] input: gpio-keys as /devices/soc0/gpio-keys/input/input1
[ 3.345573] rtc-ds1307 1-0068: hctosys: unable to read the hardware clock
[ 3.364537] ALSA device list:
[ 3.371428] #0: imx6q-apalis-sgtl5000
[ 3.379148] #1: imx-spdif
[ 3.385821] #2: imx-hdmi-soc
[ 3.413609] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.425728] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.436880] devtmpfs: mounted
[ 3.444033] Freeing unused kernel memory: 332K
[ 3.533670] systemd[1]: System time before build time, advancing clock.
[ 3.559275] random: systemd urandom read with 14 bits of entropy available
[ 3.575073] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYP)
[ 3.599050] systemd[1]: Detected architecture arm.
Welcome to The Ångström Distribution v2016.12!
[ 3.623096] systemd[1]: Set hostname to <apalis-imx6-misa>.
[ 3.811901] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 3.852986] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 3.892785] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 3.923365] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 3.973103] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 4.003336] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.033114] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 4.062980] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 4.103632] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 4.136432] systemd[1]: Starting Export GPIOs to user space...
[ 4.173601] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 4.204908] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 4.246554] systemd[1]: Starting File System Check on Root Device...
[ 4.285026] systemd[1]: Starting Setup Virtual Console...
[ 4.304873] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 4.331848] systemd[1]: Starting Load Kernel Modules...
[ 4.342668] systemd[1]: Created slice User and Session Slice.
[ OK [ 4.356405] systemd[1]: Reached target Slices.
] Created slice User and Session Slice.
[ OK ] Reached target Slices.
[ 4.384697] systemd[1]: Mounting Temporary Directory...
[ 4.422944] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 4.464460] systemd[1]: Mounting Debug File System...
[ 4.504266] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 4.544477] systemd[1]: Starting Journal Service...
[ 4.572986] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.596036] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 4.622920] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 4.653142] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started Export GPIOs to user space.
[ OK ] Started File System Check on Root Device.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[ OK ] Started Load Kernel Modules.
Mounting Configuration File System...
Mounting FUSE Control File System...
Starting Apply Kernel Variables...
Starting Remount Root and Kernel File Systems...
[ OK ] Mounted Configuration File System.
[ 4.939176] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Mounted FUSE Control File System.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Remount Root and Kernel File Systems.
Starting Flush Journal to Persistent Storage...
Starting udev Coldplug all Devices...
Starting Create Static Device Nodes in /dev...
[ OK ] Started Create Static Device Nodes in /dev.
[ 5.117952] systemd-journald[190]: Received request to flush runtime journal from PID 1
[ OK ] Reached target Local File Systems (Pre).
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started udev Coldplug all Devices.
[ OK ] Created slice system-systemd\x2dbacklight.slice.
Starting Load/Save Screen Backlight...htness of backlight:backlight...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Found device /dev/ttymxc0.
[ OK ] Started Network Time Synchronization.
[ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[ OK ] Reached target System Time Synchronized.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
Starting sshd.socket.
[ 5.807570] adv7280 3-0021: chip found @ 0x42 (21a8000.i2c)
[ 5.825399] adv7280 3-0021: no sensor pwdn pin available
[ OK ] Listening on sshd.socket.
[ OK ] Reached target[ 5.864215] adv7280 3-0021: adv7280_probe:Analog Device adv7280 not detected -5!
Sockets.
[ OK ] Reached target Basic System.
[ 5.900253] max9526 3-0020: Device seems not to be a MAX9526
[ OK ] Started D-Bus System Message Bus.
[ 5.946507] /soc/aips-bus@02100000/i2c@021a8000/ov5640_mipi@3c: arguments longer than property
Starting Boa web server...
Starting Load default USB gadget schema g1.schema...
Starting Login Service...
[ 6.213097] ov5640_read_reg:write reg error:reg=300a
[ 6.222824] camera ov5640_mipi is not found
Starting Save/Restore Sound Card State...
[ OK ] Started Timestamping service.
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Boa web server.
[FAILED] Failed to start Load default USB gadget schema g1.schema.
See 'systemctl status usbg.service' for details.
[ OK ] Started Save/Restore Sound Card State.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ 6.885627] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 6.897941] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 6.905875] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ OK ] Started Login Service.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting Network Service...
[ OK ] Reached target Sound Card.
[ OK ] Started Network Service.
[ OK ] Reached target Network.
Starting Network Name Resolution...
Starting Xinetd A Powerful Replacement For Inetd...
Starting Permit User Sessions...
[ OK ] Started Network Name Resolution.
[ OK ] Started Xinetd A Powerful Replacement For Inetd.
[ OK ] Started Permit User Sessions.
[ OK ] Started Serial Getty on ttymxc0.
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
[ OK ] Reached target Multi-User System.
[ OK ] Started Misa startup service.
[ OK ] Reached target Graphical Interface.
Starting Update UTMP about System Runlevel Changes...
Middlesex Industries S.A. - All rights reserved
initUpdtScript (v. 2.0.1):
The script is run as root !!
Enabling the core dumps
Setting ownership and privileges for /var, /work and /tmp
Start checking the system configuration:
Checking for already running application instances (TmuControlApp)
Checking for already running application instances (TmuDispatchController)
Checking for already running application instances (TmuHostInterface)
Checking the configuration dir (/work/data/config)
Check '/work/data/config': exists
Check '/work/data/log': exists
/work/data/log renamed log_bck_1
Check: '/work/data/log' created
initUpdtScript: configuring the eth0 interface
initUpdtScript: only for flash set up
FLASH board
ip addr flush dev eth0;
ip link set eth0 down;
ip link set eth0 up;
[ 7.863614] fec 2188000.ethernet eth0: Freescale FEC PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=2188000.ethernet:07, irq=70)
[ 7.878893] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
ip addr add 192.168.10.2/24 brd + dev eth0;
initUpdtScript: configuring the lo interface
ip addr flush dev lo;
ip link set lo down;
ip link set lo up;
ip addr add 127.0.0.1/8 dev lo;
RTNETLINK answers: File exists
initUpdtScript: loading the CAN driver
tmu_app_conf_custom.txt exists
ip link set can0 type can bitrate 500000
ip link set can0 up
[ 7.974873] flexcan 2090000.flexcan can0: writing ctrl=0x03292005
Check for upgrades / backups in /var/www/uploads
'tmu_backup.tar.gz' not found, skipping upgrade
'tmu_upgrade.tar.gz' not found, skipping upgrade
chown: /work/TmuDispatchController: No such file or directory
chmod: /work/TmuDispatchController: No such file or directory
chown: /work/TmuHostInterface: No such file or directory
chmod: /work/TmuHostInterface: No such file or directory
KEEPALIVE settings - These settings are system-wide
keepalive_time= 10
keepalive_intvl= 2
keepalive_probes= 2
initUpdtScript: start the control application (TmuControlApp)
TMU Control Application (v. 3.8.43) started
Apalis-iMX6-misa_Console-Image 2.7b5 20180330
apalis-imx6-misa login: [ 11.311227] fec 2188000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 11.319044] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.921437] ci_hdrc ci_hdrc.0: Device No Response
Here is clean shutdown for 2.8:
apalis-imx6-misa:~$
apalis-imx6-misa:~$
apalis-imx6-misa:~$
apalis-imx6-misa:~$
apalis-imx6-misa:~$
Password:
Stopping Save/Res Stopping Session c1 of user misa.
Stopping Serial Getty on ttymxc0...
Stopping NFS status monitor for NFSv2/3 locking....
Stopping Telephony service...
Stopping User Manager for UID 1000...
[ OK ] Stopped target Timers.
[ OK ] Stopped Daily Cleanup of Temporary Directories.
[ OK ] Stopped target Sound Card.
[ OK ] Stopped target Containers.
[ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Stopped Telephony service.
[ OK ] Stopped NFS status monitor for NFSv2/3 locking..
[ OK ] Stopped target Host and Network Name Lookups.
Stopping RPC Bind Service...
[ OK ] Stopped RPC Bind Service.
Stopping Load/Save Screen Backlight…ightness of backlight:backlight...
[ OK ] Stopped Update is Completed.
[ OK ] Stopped Rebuild Dynamic Linker Cache.
[ OK ] Stopped Rebuild Journal Catalog.
[ OK ] Stopped Rebuild Hardware Database.
Unmounting Temporary Directory (/tmp)...
[ OK ] Unmounted Temporary Directory (/tmp).
[ OK ] Stopped Create System Users.
[ 101.967455] systemd-shutdow: 19 output lines suppressed due to ratelimiting
[ 102.054711] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 102.075997] systemd-journald[217]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 102.113940] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 102.136785] systemd-shutdown[1]: Unmounting file systems.
[ 102.143198] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 102.176637] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 102.184793] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 102.194227] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 102.200265] systemd-shutdown[1]: All filesystems unmounted.
[ 102.205946] systemd-shutdown[1]: Deactivating swaps.
[ 102.211121] systemd-shutdown[1]: All swaps deactivated.
[ 102.216463] systemd-shutdown[1]: Detaching loop devices.
[ 102.225705] systemd-shutdown[1]: All loop devices detached.
[ 102.257633] ci_hdrc ci_hdrc.1: remove, state 4
[ 102.262175] usb usb2: USB disconnect, device number 1
[ 102.267429] usb 2-1: USB disconnect, device number 2
[ 102.273592] ci_hdrc ci_hdrc.1: USB bus 2 deregistered
[ 102.282113] ci_hdrc ci_hdrc.0: remove, state 4
[ 102.286671] usb usb1: USB disconnect, device number 1
[ 102.292264] ci_hdrc ci_hdrc.0: USB bus 1 deregistered
[ 102.352708] reboot: System halted
And restarted by power cycling:
U-Boot 2016.11-2.8.1+g30a1208 (Mar 18 2018 - 15:42:53 +0100)
Reset cause: POR
I2C: ready
DRAM: 512 MiB
In: serial
Out: serial
Err: serial
Net: using PHY at 7
FEC [PRIME]
53915 bytes read in 18 ms (2.9 MiB/s)
reading uImage
5363832 bytes read in 160 ms (32 MiB/s)
Image Name: Linux-4.9.67-+g1db9f06
Data Size: 5363768 Bytes = 5.1 MiB
Using Device Tree in place at 12000000, end 1201029a
Starting kernel ...
[ 0.000000] Linux version 4.9.67-+g1db9f06 (oe-user@oe-host) (gcc version 7.2.0 (GCC) ) #1 SMP Sun Mar 18 15:39:50 CET 2018
[ 0.000000] OF: fdt:Machine model: Toradex Apalis iMX6Q/D Module on Apalis Evaluation Board
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] percpu: Embedded 14 pages/cpu @8bb13000 s25612 r8192 d23540 u57344
[ 0.000000] Memory: 179124K/524288K available (8192K kernel code, 279K rwdata, 1956K rodata, 1024K init, 439K bss, 17484K reserved, 327680K c)
[ 0.000000] vmalloc : 0xa0800000 - 0xff800000 (1520 MB)
[ 0.000000] .text : 0x80008000 - 0x80900000 (9184 kB)
[ 0.000000] .init : 0x80b00000 - 0x80c00000 (1024 kB)
[ 0.000000] .data : 0x80c00000 - 0x80c45e60 ( 280 kB)
[ 0.000000] .bss : 0x80c45e60 - 0x80cb3d8c ( 440 kB)
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
[ 0.000000] L2C-310 errata 752271 769419 enabled
[ 0.000006] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[ 0.000024] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.001496] Console: colour dummy device 80x30
[ 0.002139] console [tty1] enabled
[ 0.002167] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[ 0.002209] pid_max: default: 32768 minimum: 301
[ 0.002313] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002340] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002932] CPU: Testing write buffer coherency: ok
[ 0.003220] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.003296] Setting up static identity map for 0x10100000 - 0x10100058
[ 0.005064] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.005164] Brought up 2 CPUs
[ 0.005213] SMP: Total of 2 processors activated (12.00 BogoMIPS).
[ 0.005237] CPU: All CPU(s) started in SVC mode.
[ 0.005975] devtmpfs: initialized
[ 0.019430] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.019766] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.019819] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.036512] pinctrl core: initialized pinctrl subsystem
[ 0.037585] NET: Registered protocol family 16
[ 0.044848] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.069581] cpuidle: using governor menu
[ 0.069890] CPU identified as i.MX6Q, silicon rev 1.5
[ 0.094762] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.094811] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.095776] imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.097250] imx-gpc 20dc000.gpc: no fsl,ldo-bypass found!
[ 0.097399] imx-gpc 20dc000.gpc: Registered imx-gpc
[ 0.118633] usb_host_vbus: supplied by usb_host_vbus_hub
[ 0.119116] vgaarb: loaded
[ 0.119873] SCSI subsystem initialized
[ 0.120326] usbcore: registered new interface driver usbfs
[ 0.120412] usbcore: registered new interface driver hub
[ 0.120504] usbcore: registered new device driver usb
[ 0.121151] i2c-gpio i2c@0: using pins 80 (SDA) and 62 (SCL)
[ 0.122126] i2c i2c-1: IMX I2C adapter registered
[ 0.122164] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.130238] stmpe-i2c 2-0041: stmpe811 detected, chip id: 0x811
[ 0.220519] i2c i2c-2: IMX I2C adapter registered
[ 0.220558] i2c i2c-2: can't use DMA, using PIO instead.
[ 0.221261] i2c i2c-3: IMX I2C adapter registered
[ 0.221297] i2c i2c-3: can't use DMA, using PIO instead.
[ 0.221454] Linux video capture interface: v2.00
[ 0.221519] pps_core: LinuxPPS API ver. 1 registered
[ 0.221544] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.221594] PTP clock support registered
[ 0.249640] imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.279633] imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
[ 0.280558] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed ipu0 csi1
[ 0.280603] mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
[ 0.280716] MIPI CSI2 driver module loaded
[ 0.280910] Advanced Linux Sound Architecture Driver Initialized.
[ 0.282664] clocksource: Switched to clocksource mxc_timer1
[ 0.282786] VFS: Disk quotas dquot_6.6.0
[ 0.282860] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.292955] NET: Registered protocol family 2
[ 0.293537] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.293607] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.293689] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.293756] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.293798] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.293946] NET: Registered protocol family 1
[ 0.294334] RPC: Registered named UNIX socket transport module.
[ 0.294364] RPC: Registered udp transport module.
[ 0.294386] RPC: Registered tcp transport module.
[ 0.294408] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.295151] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 0.296694] Bus freq driver module loaded
[ 0.298353] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.304678] NFS: Registering the id_resolver key type
[ 0.304726] Key type id_resolver registered
[ 0.304749] Key type id_legacy registered
[ 0.304781] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.305316] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.305640] fuse init (API version 7.26)
[ 0.311568] io scheduler noop registered
[ 0.311602] io scheduler deadline registered
[ 0.311774] io scheduler cfq registered (default)
[ 0.314061] OF: PCI: host bridge /soc/pcie@0x01000000 ranges:
[ 0.314100] OF: PCI: No bus range found for /soc/pcie@0x01000000, using [bus 00-ff]
[ 0.314152] OF: PCI: IO 0x01f80000..0x01f8ffff -> 0x00000000
[ 0.314184] OF: PCI: MEM 0x01000000..0x01efffff -> 0x01000000
[ 0.563807] imx6q-pcie 1ffc000.pcie: phy link never came up
[ 0.563844] imx6q-pcie 1ffc000.pcie: Link never came up
[ 0.566928] imx6q-pcie 1ffc000.pcie: failed to initialize host
[ 0.567025] imx6q-pcie: probe of 1ffc000.pcie failed with error -110
[ 0.568041] backlight supply power not found, using dummy regulator
[ 0.570924] 20e0000.hdmi_video supply HDMI not found, using dummy regulator
[ 0.572926] mxc_hdmi 20e0000.hdmi_video: Detected HDMI controller 0x13:0xa:0xa0:0xc1
[ 0.572987] fbcvt: 1920x1080@60: CVT Name - 2.073M9
[ 0.573115] mxc_sdc_fb fb@0: registered mxc display driver hdmi
[ 0.587758] mxc_sdc_fb fb@0: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 0.612740] imx-ipuv3 2400000.ipu: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
[ 0.646623] mxc_sdc_fb fb@0: 1920x1080 h_sync,r,l: 44,88,148 v_sync,l,u: 5,4,36 pixclock=148500000 Hz
[ 0.694436] Console: switching to colour frame buffer device 240x67
[ 0.729266] mxc_sdc_fb fb@1: mxcfb1 is turned off!
[ 0.729417] mxc_sdc_fb fb@2: mxcfb2 is turned off!
[ 0.729560] mxc_sdc_fb fb@3: mxcfb3 is turned off!
[ 0.731387] imx-sdma 20ec000.sdma: no iram assigned, using external mem
[ 0.732035] imx-sdma 20ec000.sdma: loaded firmware 3.3
[ 0.736640] pfuze100-regulator 2-0008: Full layer: 2, Metal layer: 1
[ 0.737472] pfuze100-regulator 2-0008: FAB: 0, FIN: 0
[ 0.737572] pfuze100-regulator 2-0008: pfuze100 found.
[ 0.754871] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 30, base_baud = 5000000) is a IMX
[ 1.642912] console [ttymxc0] enabled
[ 1.647540] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 80, base_baud = 5000000) is a IMX
[ 1.656877] 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 81, base_baud = 5000000) is a IMX
[ 1.666229] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 82, base_baud = 5000000) is a IMX
[ 1.675899] [drm] Initialized
[ 1.679311] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[ 1.694668] brd: module loaded
[ 1.703363] loop: module loaded
[ 1.707746] ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
[ 1.715842] ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
[ 1.724017] ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
[ 1.732340] ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
[ 1.743243] ahci-imx 2200000.sata: SSS flag set, parallel bus scan disabled
[ 1.750358] ahci-imx 2200000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 1.759332] ahci-imx 2200000.sata: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ 1.769894] scsi host0: ahci-imx
[ 1.773519] ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02203fff] port 0x100 irq 89
[ 1.783884] spi_imx 2008000.ecspi: probed
[ 1.789020] spi_imx 200c000.ecspi: probed
[ 1.793862] libphy: Fixed MDIO Bus: probed
[ 1.798409] vcan: Virtual CAN interface driver
[ 1.802961] CAN device driver interface
[ 1.811952] 2090000.flexcan supply xceiver not found, using dummy regulator
[ 1.824595] flexcan 2090000.flexcan: device registered (reg_base=a0b2c000, irq=39)
[ 1.837471] 2094000.flexcan supply xceiver not found, using dummy regulator
[ 1.850303] flexcan 2094000.flexcan: device registered (reg_base=a0b34000, irq=40)
[ 1.864043] 2188000.ethernet supply phy not found, using dummy regulator
[ 1.887359] pps pps0: new PPS source ptp0
[ 1.897794] libphy: fec_enet_mii_bus: probed
[ 1.908703] fec 2188000.ethernet eth0: registered PHC device 0
[ 1.920054] usbcore: registered new interface driver asix
[ 1.930651] usbcore: registered new interface driver ax88179_178a
[ 1.941893] usbcore: registered new interface driver cdc_ether
[ 1.952818] usbcore: registered new interface driver net1080
[ 1.963476] usbcore: registered new interface driver cdc_subset
[ 1.974342] usbcore: registered new interface driver zaurus
[ 1.984885] usbcore: registered new interface driver cdc_ncm
[ 1.995395] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.006836] ehci-pci: EHCI PCI platform driver
[ 2.016248] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 2.026699] usbcore: registered new interface driver usb-storage
[ 2.037749] usbcore: registered new interface driver usbserial
[ 2.048470] usbcore: registered new interface driver usbserial_generic
[ 2.059831] usbserial: USB Serial support registered for generic
[ 2.070638] usbcore: registered new interface driver ftdi_sio
[ 2.081219] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.093410] usbcore: registered new interface driver pl2303
[ 2.103815] usbserial: USB Serial support registered for pl2303
[ 2.115734] 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 2.119100] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.119140] ahci-imx 2200000.sata: no device found, disabling link.
[ 2.119146] ahci-imx 2200000.sata: pass ahci_imx..hotplug=1 to enable hotplug
[ 2.165683] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 2.175241] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 2.212699] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 2.223665] hub 1-0:1.0: USB hub found
[ 2.232137] hub 1-0:1.0: 1 port detected
[ 2.246851] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 2.256445] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 2.292698] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 2.303588] hub 2-0:1.0: USB hub found
[ 2.312030] hub 2-0:1.0: 1 port detected
[ 2.321498] mousedev: PS/2 mouse device common for all mice
[ 2.341927] input: stmpe-ts as /devices/soc0/soc/2100000.aips-bus/21a4000.i2c/i2c-2/2-0041/stmpe-ts/input/input0
[ 2.360849] rtc-ds1307 1-0068: oscillator failed, set time!
[ 2.374143] rtc-ds1307 1-0068: rtc core: registered m41t0 as rtc0
[ 2.385810] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc1
[ 2.399713] i2c /dev entries driver
[ 2.409439] mxc_v4l2_output v4l2_out: V4L2 device registered as video16
[ 2.421323] mxc_v4l2_output v4l2_out: V4L2 device registered as video17
[ 2.434222] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 2.445705] sdhci: Secure Digital Host Controller Interface driver
[ 2.456767] sdhci: Copyright(c) Pierre Ossman
[ 2.465962] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.477579] sdhci-esdhc-imx 2190000.usdhc: could not get ultra high speed state, work on normal mode
[ 2.491710] sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
[ 2.562819] mmc1: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[ 2.577641] sdhci-esdhc-imx 2194000.usdhc: could not get ultra high speed state, work on normal mode
[ 2.591769] sdhci-esdhc-imx 2194000.usdhc: Got CD GPIO
[ 2.662809] mmc2: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[ 2.677644] sdhci-esdhc-imx 2198000.usdhc: could not get ultra high speed state, work on normal mode
[ 2.692042] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 2.762695] mmc0: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
[ 2.787668] mxc_vpu 2040000.vpu_fsl: VPU initialized
[ 2.802438] mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
[ 2.824775] caam 2100000.caam: ERA source: CAAMVID.
[ 2.834849] caam 2100000.caam: AXI pipeline throttling enabled.
[ 2.853132] caam 2100000.caam: Entropy delay = 3200
[ 2.863229] caam 2100000.caam: Instantiated RNG4 SH0
[ 2.898443] hub 2-1:1.0: USB hub found
[ 2.908352] random: fast init done
[ 2.916779] hub 2-1:1.0: 4 ports detected
[ 2.923992] caam 2100000.caam: Instantiated RNG4 SH1
[ 2.924002] caam 2100000.caam: device ID = 0x0a16010000000000 (Era 4)
[ 2.924009] caam 2100000.caam: job rings = 2, qi = 0
[ 2.931851] caam algorithms registered in /proc/crypto
[ 2.947856] caam_jr 2101000.jr0: registering rng-caam
[ 2.948718] snvs-secvio 20cc000.caam-snvs: can't get snvs clock
[ 2.948766] snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
[ 2.948987] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.949135] usbcore: registered new interface driver usbhid
[ 2.949137] usbhid: USB HID core driver
[ 3.040657] stmpe-adc stmpe-adc: Initialized
[ 3.049319] mmc0: new DDR MMC card at address 0001
[ 3.060654] mmcblk0: mmc0:0001 Q2J54A 3.64 GiB
[ 3.070710] mmcblk0boot0: mmc0:0001 Q2J54A partition 1 2.00 MiB
[ 3.082102] mmcblk0boot1: mmc0:0001 Q2J54A partition 2 2.00 MiB
[ 3.093420] sgtl5000 2-000a: sgtl5000 revision 0x11
[ 3.094319] mmcblk0: p1 p2
[ 3.140827] fsl-ssi-dai 2028000.ssi: No cache defaults, reading back from HW
[ 3.283556] imx-sgtl5000 sound: sgtl5000 <-> 2028000.ssi mapping ok
[ 3.297259] imx-spdif sound-spdif: snd-soc-dummy-dai <-> 2004000.spdif mapping ok
[ 3.312775] imx-audio-hdmi sound-hdmi: hdmi-hifi.0 <-> soc:hdmi_audio@00120000 mapping ok
[ 3.327587] NET: Registered protocol family 10
[ 3.338106] NET: Registered protocol family 17
[ 3.347692] can: controller area network core (rev 20120528 abi 9)
[ 3.359149] NET: Registered protocol family 29
[ 3.368714] can: raw protocol (rev 20120528)
[ 3.378104] can: broadcast manager protocol (rev 20161123 t)
[ 3.388909] can: netlink gateway (rev 20130117) max_hops=1
[ 3.399857] Key type dns_resolver registered
[ 3.410596] mmc2: Switching to 3.3V signalling voltage failed
[ 3.423163] cpu cpu0: Registered imx6q-cpufreq
[ 3.432864] Registering SWP/SWPB emulation handler
[ 3.457322] imx_thermal 2000000.aips-bus:tempmon: Extended Commercial CPU temperature grade - max:105C critical:100C passive:95C
[ 3.474170] input: gpio-keys as /devices/soc0/gpio-keys/input/input1
[ 3.486421] rtc-ds1307 1-0068: hctosys: unable to read the hardware clock
[ 3.500066] ALSA device list:
[ 3.507213] #0: imx6q-apalis-sgtl5000
[ 3.515263] #1: imx-spdif
[ 3.522067] #2: imx-hdmi-soc
[ 3.570025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.582368] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.593720] devtmpfs: mounted
[ 3.601611] Freeing unused kernel memory: 1024K
[ 3.757377] systemd[1]: System time before build time, advancing clock.
[ 3.801867] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYP)
[ 3.827503] systemd[1]: Detected architecture arm.
Welcome to The Ångström Distribution v2017.12!
[ 3.863080] systemd[1]: Set hostname to <apalis-imx6-misa>.
[ 4.097362] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.142974] systemd[1]: Listening on udev Control Socket.
[ 4.182965] systemd[1]: Listening on Journal Socket.
[ 4.222992] systemd[1]: Listening on udev Kernel Socket.
[ 4.263018] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 4.302834] systemd[1]: Reached target Remote File Systems.
[ 4.358803] systemd[1]: Listening on Journal Socket (/dev/log).
Mounting Kernel Debug File System...
Starting Create list of required st…ce nodes for the current kernel...
Mounting Temporary Directory (/tmp)...
[ OK ] Created slice User and Session Slice.
[ OK ] Mounted Kernel Debug File System.
[ OK ] Mounted Temporary Directory (/tmp).
[ OK ] Started Create list of required sta…vice nodes for the current kernel.
Mounting Kernel Configuration File System...
[ OK ] Mounted Kernel Configuration File System.
[ 5.144136] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Starting Create System Users...
Starting Rebuild Hardware Database...
[ OK ] Started Create System Users.
[ 5.305746] systemd-journald[213]: Received request to flush runtime journal from PID 1
[ 5.330950] systemd-journald[213]: File /var/log/journal/f6a76da00d724b30a04207da6eb33c09/system.journal corrupted or uncleanly shut down, re.
Starting Rebuild Dynamic Linker Cache...
Starting Rebuild Journal Catalog...
[ OK ] Started Rebuild Dynamic Linker Cache.
[ OK ] Started Rebuild Journal Catalog.
[ OK ] Started Rebuild Hardware Database.
Starting Update is Completed...
[ OK ] Started Update is Completed.
[ 7.719102] max9526 3-0020: Device seems not to be a MAX9526
[ 7.751399] adv7280 3-0021: chip found @ 0x42 (21a8000.i2c)
[ 7.781262] adv7280 3-0021: no sensor pwdn pin available
Starting Load/Save Screen Backlight…ightness of backlight:backlight...
[ OK ] Reached target Sockets.
[ 7.853183] adv7280 3-0021: adv7280_probe:Analog Device adv7280 not detected -6!
[ 7.901556] ov564x_mipi 3-003c: found pwm2, period=0
Starting Telephony service...
[ 8.193079] ov5640_read_reg:write reg error:reg=300a
[ 8.203173] camera ov5640_mipi is not found
[ 8.309146] compat: loading out-of-tree module taints kernel.
[ OK ] Started Telephony service.
[ OK ] Reached target Containers.
[ 8.363693] Loading modules backported from Linux version v4.14-0-gbebc608
[ 8.375729] Backport generated by backports.git v4.14-rc2-1-34-g1d8cc15
Starting RPC Bind Service...
[ 8.518535] Bluetooth: Core ver 2.22
[ 8.624516] NET: Registered protocol family 31
[ 8.634030] Bluetooth: HCI device and connection manager initialized
[ OK ] Started RPC Bind Service.
[ 8.703901] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 8.717596] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 8.727414] ERROR: v4l2 capture: slave not found! V4L2_CID_HUE
[ 8.744041] Bluetooth: HCI socket layer initialized
[FAILED] Failed to st[ 8.755680] Bluetooth: L2CAP socket layer initialized
art Load default USB gadget schem[ 8.766874] Bluetooth: SCO socket layer initialized
a g1.schema.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Started NFS status monitor for NFSv2/3 locking..
FLASH board
[ 10.125017] Micrel KSZ9031 Gigabit PHY 2188000.ethernet-1:07: attached PHY driver [Micrel KSZ9031 Gigabit PHY] (mii_bus:phy_addr=2188000.ethe)
[ 10.145716] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
ip link set lo up;
ip link set can0 up
keepalive_time= 10
keepalive_intvl= 2
keepalive_probes= 2
ExecuteStepE failed Unable to complete Start Procedure! Exiting application...
Apalis-iMX6-misa_Console-Image 2.8b1 20180329
apalis-imx6-misa login: [ 13.827471] fec 2188000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 13.835494] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
apalis-imx6-misa login: misa
Password:
Last login: Sun Mar 18 14:08:59 UTC 2018 on ttymxc0
[ 25.006078] systemd-journald[213]: File /var/log/journal/f6a76da00d724b30a04207da6eb33c09/user-1000.journal corrupted or uncleanly shut down,.
apalis-imx6-misa:~$
apalis-imx6-misa:~$
apalis-imx6-misa:~$
apalis-imx6-misa:~$
