Error loading footer (aaos nxp)
I am trying to flashing android automotive os on Toradex Ixora Apalis i.MX8 board. But there is the following problem:
avb_slot_verify.c:699: ERROR: boot_a: Error loading footer.
Help me to solve the problem
For those interested in running Android Automotive OS (AAOS) on the Apalis iMX8 with the Ixora carrier board, support is available through Toradex partners. Specifically, Sibrain Technologies and Kynetics offer support for AAOS on Toradex products. You can find more information about this on the Toradex Android page.
The Android BSPs provided are intended for evaluation purposes and will require customization before they can be used in production environments. To ensure a smooth setup, please verify that you are using the correct BSP version for your specific hardware configuration. This is crucial for compatibility and optimal performance.
For additional support, you can explore the Toradex Partner Network and engage with the Community Forums where you can connect with other users and experts.
I hope this information helps you with your project.
Hi @Nurys
I think we already had a similar topic in the past.
So, were you able to contact any of our android partners?
Toradex does not provide Android support for its products. This support is provided by our partners.
