Dear Sir,
I cannot upgrade linux system on apalis T30. After running a command
opkg update
opkg upgrade
on fresh V2.6_20160826 BSP I got following errors:
Collected errors:
* pkg_run_script: Internal error: dbus-1 has a NULL tmp_unpack_dir.
* opkg_remove_pkg: not removing package "dbus-1", prerm script failed
* get_pkg_url: Package dbus-1 is not available from any configured src.
* opkg_install_pkg: Failed to download dbus-1. Perhaps you need to run 'opkg update'?
* pkg_run_script: Internal error: openssh-sshd has a NULL tmp_unpack_dir.
* opkg_remove_pkg: not removing package "openssh-sshd", prerm script failed
* get_pkg_url: Package openssh-sshd is not available from any configured src.
* opkg_install_pkg: Failed to download openssh-sshd. Perhaps you need to run 'opkg update'?
* pkg_run_script: Internal error: rpcbind has a NULL tmp_unpack_dir.
* opkg_remove_pkg: not removing package "rpcbind", prerm script failed
* get_pkg_url: Package rpcbind is not available from any configured src.
* opkg_install_pkg: Failed to download rpcbind. Perhaps you need to run 'opkg update'?
* pkg_get_installed_files: Failed to open ///var/lib/opkg/info/dbus-1.list: No such file or directory.
* pkg_run_script: Internal error: ofono has a NULL tmp_unpack_dir.
* opkg_remove_pkg: not removing package "ofono", prerm script failed
* get_pkg_url: Package ofono is not available from any configured src.
* opkg_install_pkg: Failed to download ofono. Perhaps you need to run 'opkg update'?
* pkg_run_script: Internal error: wpa-supplicant has a NULL tmp_unpack_dir.
* opkg_remove_pkg: not removing package "wpa-supplicant", prerm script failed
* get_pkg_url: Package wpa-supplicant is not available from any configured src.
* opkg_install_pkg: Failed to download wpa-supplicant. Perhaps you need to run 'opkg update'?
* pkg_run_script: Internal error: udev has a NULL tmp_unpack_dir.
* opkg_remove_pkg: not removing package "udev", prerm script failed
* get_pkg_url: Package udev is not available from any configured src.
* opkg_install_pkg: Failed to download udev. Perhaps you need to run 'opkg update'?
* pkg_run_script: Internal error: fontconfig-utils has a NULL tmp_unpack_dir.
* opkg_remove_pkg: not removing package "fontconfig-utils", prerm script failed
* get_pkg_url: Package fontconfig-utils is not available from any configured src.
* opkg_install_pkg: Failed to download fontconfig-utils. Perhaps you need to run 'opkg update'?
* pkg_run_script: Internal error: kmod has a NULL tmp_unpack_dir.
* opkg_remove_pkg: not removing package "kmod", prerm script failed
* get_pkg_url: Package kmod is not available from any configured src.
* opkg_install_pkg: Failed to download kmod. Perhaps you need to run 'opkg update'?
* pkg_run_script: Internal error: libnotify has a NULL tmp_unpack_dir.
* opkg_remove_pkg: not removing package "libnotify", prerm script failed
* get_pkg_url: Package libnotify is not available from any configured src.
* opkg_install_pkg: Failed to download libnotify. Perhaps you need to run 'opkg update'?
* pkg_run_script: Internal error: kbd has a NULL tmp_unpack_dir.
* opkg_remove_pkg: not removing package "kbd", prerm script failed
* get_pkg_url: Package kbd is not available from any configured src.
* opkg_install_pkg: Failed to download kbd. Perhaps you need to run 'opkg update'?
* pkg_get_installed_files: Failed to open ///var/lib/opkg/info/ofono.list: No such file or directory.
* pkg_get_installed_files: Failed to open ///var/lib/opkg/info/wpa-supplicant.list: No such file or directory.
* pkg_run_script: Internal error: connman has a NULL tmp_unpack_dir.
* opkg_remove_pkg: not removing package "connman", prerm script failed
* get_pkg_url: Package connman is not available from any configured src.
* opkg_install_pkg: Failed to download connman. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7at2hf-vfp-neon/base/xdpyinfo_1.3.2-r0.3_armv7at2hf-vfp-neon.ipk, wget returned 1.
* opkg_install_pkg: Failed to download xdpyinfo. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7ahf-vfp-neon/base/ldd_2.22-r0.3_armv7ahf-vfp-neon.ipk, wget returned 1.
* opkg_install_pkg: Failed to download ldd. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7ahf-vfp-neon/base/libvpx_1.4.0-r0.0_armv7ahf-vfp-neon.ipk, wget returned 1.
* opkg_install_pkg: Failed to download libvpx. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7at2hf-vfp-neon/gstreamer/gst-plugins-good-isomp4_0.10.31-r8.0_armv7at2hf-vfp-neon.ipk, wget ret.
* opkg_install_pkg: Failed to download gst-plugins-good-isomp4. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7at2hf-vfp-neon/base/alsa-utils_1.0.29-r0.9_armv7at2hf-vfp-neon.ipk, wget returned 1.
* opkg_install_pkg: Failed to download alsa-utils. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7at2hf-vfp-neon/base/xset_1.2.3-r0.0_armv7at2hf-vfp-neon.ipk, wget returned 1.
* opkg_install_pkg: Failed to download xset. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7at2hf-vfp-neon/base/xrandr_1.4.3-r0.3_armv7at2hf-vfp-neon.ipk, wget returned 1.
* opkg_install_pkg: Failed to download xrandr. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7at2hf-vfp-neon/base/e2fsprogs-mke2fs_1.42.9-r0.5_armv7at2hf-vfp-neon.ipk, wget returned 1.
* opkg_install_pkg: Failed to download e2fsprogs-mke2fs. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7at2hf-vfp-neon/base/alsa-utils-aseqnet_1.0.29-r0.9_armv7at2hf-vfp-neon.ipk, wget returned 1.
* opkg_install_pkg: Failed to download alsa-utils-aseqnet. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7at2hf-vfp-neon/base/wpa-supplicant-passphrase_2.4-r0.6_armv7at2hf-vfp-neon.ipk, wget returned 1.
* opkg_install_pkg: Failed to download wpa-supplicant-passphrase. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7at2hf-vfp-neon/base/alsa-utils-aseqdump_1.0.29-r0.9_armv7at2hf-vfp-neon.ipk, wget returned 1.
* opkg_install_pkg: Failed to download alsa-utils-aseqdump. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7at2hf-vfp-neon/base/wireless-tools_30.pre9-r0.0_armv7at2hf-vfp-neon.ipk, wget returned 1.
* opkg_install_pkg: Failed to download wireless-tools. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7at2hf-vfp-neon/gstreamer/gst-plugins-good-wavenc_0.10.31-r8.0_armv7at2hf-vfp-neon.ipk, wget ret.
* opkg_install_pkg: Failed to download gst-plugins-good-wavenc. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7at2hf-vfp-neon/base/udev-hwdb_226+git0+4211d5bd13-r0.9_armv7at2hf-vfp-neon.ipk, wget returned 1.
* opkg_install_pkg: Failed to download udev-hwdb. Perhaps you need to run 'opkg update'?
* opkg_download_backend: Failed to download http://feeds.toradex.com/angstrom/feeds/v2015.12/ipk/glibc/armv7at2hf-vfp-neon/base/libnss-mdns_0.10-r7.3_armv7at2hf-vfp-neon.ipk, wget returned 1.
* opkg_install_pkg: Failed to download libnss-mdns. Perhaps you need to run 'opkg update'?
* pkg_run_script: package "avahi-daemon" postinst script returned status 1.
* opkg_configure: avahi-daemon.postinst returned 1.
* pkg_run_script: package "alsa-state" postinst script returned status 99.
* opkg_configure: alsa-state.postinst returned 99.
Kamil
