Error building torizon-core-docker with extra module
i am trying to add a kernel module when building the torizon-core-docker image with yocto. I updated everything to latest git version with repo (the bug from here is resolved.
Using bitbake i can build the module (aka generate tje .ko file)
i added the layer to yocto with bitbake-layers and added MACHINE_ESSENTIAL_EXTRA_RDEPENDS += directive to build/conf/local.conf file.
The error i get is torizon-core-docker.bb:do_image_ostreecommit failed with exit code 1
Log file attached.
should i inject the .ko file after building the image without my recipe (layer and local.conf directive)?
I need the module for a touch controller that is available only starting in kernel version 5.14.
log.do_image_ostreecommit.txt (7.4 KB)
Greetings @c.gantner,
If I understand correctly, you have a custom meta-layer with your changes then correct?
Is this meta-layer being Git version controlled as described here: Build Torizon OS from Source With Yocto Project/OpenEmbedded | Toradex Developer Center
All meta-layers involved with a Torizon Yocto build need to be controlled by Git due to how we manage the versioning with Torizon.
The meta-layer was not git version controlled.
After applying git it did build ok.
Thanks,
Cristian
Great, good to hear that was the only issue.
