Hi, i got an error when I´m trying to cook the sdk, someone know whay can I do to solve it?
$ bitbake -c populate_sdk tdx-reference-minimal-image
Loading cache: 100% |#################################################################################################################################################################| Time: 0:00:02
Loaded 3886 entries from dependency cache.
Build Configuration:
BB_VERSION = "1.46.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "universal"
TARGET_SYS = "arm-tdx-linux-gnueabi"
MACHINE = "colibri-imx6ull"
DISTRO = "tdx-x11"
DISTRO_VERSION = "5.0.0-devel-20200826205205+build.0"
TUNE_FEATURES = "arm armv7a vfp thumb neon callconvention-hard"
TARGET_FPU = "hard"
meta-toradex-nxp = "HEAD:8a2e5df0404ac59a5f1e74638a4220274afb4867"
meta-freescale = "HEAD:6bc3d8825c20d21528e24a7237ff7392e01a81bd"
meta-freescale-3rdparty = "HEAD:9000d8b388de98a13d6db2a98cd21602e0a7b715"
meta-toradex-tegra = "HEAD:a275ddac7fd5bda9602a3fe365da2b845ce22e3e"
meta-toradex-bsp-common = "HEAD:cdcf6c6c538f4458e798530762d9d1b0db510f7a"
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python = "HEAD:cc6fc6b1641ab23089c1e3bba11e0c6394f0867c"
meta-freescale-distro = "HEAD:a1821b36af7bba4f6628e4244df7fc9a038d0f34"
meta-toradex-demos = "HEAD:bdfeb84dbe21cb614fb5db4347335ab26d81244b"
meta-qt5 = "HEAD:0e7015f7a86dda995a39662edbb5c26da647c496"
meta-toradex-distro = "HEAD:950ad2a54b87d56d938e615634c2e4079b386fca"
meta-poky = "HEAD:432b365f48f58ec0d9692a93607b65edd098ca1a"
meta = "HEAD:7ce425fa1295a9dca48f8474be58db3ac8aa540d"
meta-webserver = "HEAD:cc6fc6b1641ab23089c1e3bba11e0c6394f0867c"
WARNING: /home/boherdi/Escritorio/toradex/build/../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_4.14-2.3.x.bb:do_kernel_configme is tainted from a forced run | ETA: 0:00:06
WARNING: /home/boherdi/Escritorio/toradex/build/../layers/meta-toradex-nxp/recipes-kernel/linux/linux-toradex_4.14-2.3.x.bb:do_compile is tainted from a forced run
Initialising tasks: 100% |############################################################################################################################################################| Time: 0:00:08
Sstate summary: Wanted 321 Found 321 Missed 0 Current 1845 (100% match, 100% complete)
NOTE: Executing Tasks
ERROR: tdx-reference-minimal-image-1.0-r0 do_populate_sdk: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function:
0001:
*** 0002:do_populate_sdk(d)
0003:
File: '/home/boherdi/Escritorio/toradex/build/../layers/openembedded-core/meta/classes/populate_sdk_base.bbclass', lineno: 172, function: do_populate_sdk
0168:
0169: populate_sdk(d)
0170:
0171:fakeroot python do_populate_sdk() {
*** 0172: populate_sdk_common(d)
0173:}
0174:SSTATETASKS += "do_populate_sdk"
0175:SSTATE_SKIP_CREATION_task-populate-sdk = '1'
0176:do_populate_sdk[cleandirs] = "${SDKDEPLOYDIR}"
File: '/home/boherdi/Escritorio/toradex/build/../layers/openembedded-core/meta/classes/populate_sdk_base.bbclass', lineno: 169, function: populate_sdk_common
0165: manifest_type=Manifest.MANIFEST_TYPE_SDK_HOST)
0166: create_manifest(d, manifest_dir=d.getVar('SDK_DIR'),
0167: manifest_type=Manifest.MANIFEST_TYPE_SDK_TARGET)
0168:
*** 0169: populate_sdk(d)
0170:
0173:}
File: '/home/boherdi/Escritorio/toradex/build/../layers/openembedded-core/meta/lib/oe/sdk.py', lineno: 415, function: populate_sdk
0411: img_type = d.getVar('IMAGE_PKGTYPE')
0412: if img_type == "rpm":
0413: RpmSdk(d, manifest_dir).populate()
0414: elif img_type == "ipk":
*** 0415: OpkgSdk(d, manifest_dir).populate()
0416: elif img_type == "deb":
0417: DpkgSdk(d, manifest_dir).populate()
0418:
0419: os.environ.clear()
File: '/home/boherdi/Escritorio/toradex/build/../layers/openembedded-core/meta/lib/oe/sdk.py', lineno: 42, function: populate
0038: def populate(self):
0039: self.mkdirhier(self.sdk_output)
0040:
0041: # call backend dependent implementation
*** 0042: self._populate()
0043:
0044: # Don't ship any libGL in the SDK
0045: self.remove(os.path.join(self.sdk_output, self.sdk_native_path,
0046: self.d.getVar('libdir_nativesdk').strip('/'),
File: '/home/boherdi/Escritorio/toradex/build/../layers/openembedded-core/meta/lib/oe/sdk.py', lineno: 272, function: _populate
0268: self.target_pm.remove_packaging_data()
0269:
0270: bb.note("Installing NATIVESDK packages")
0271: self._populate_sysroot(self.host_pm, self.host_manifest)
*** 0272: self.install_locales(self.host_pm)
0273:
0274: self.host_pm.run_intercepts(populate_sdk='host')
0275:
0276: execute_pre_post_process(self.d, self.d.getVar("POPULATE_SDK_POST_HOST_COMMAND"))
File: '/home/boherdi/Escritorio/toradex/build/../layers/openembedded-core/meta/lib/oe/sdk.py', lineno: 104, function: install_locales
0100: # Generate a locale archive of them
0101: target_arch = self.d.getVar('SDK_ARCH')
0102: rootfs = oe.path.join(self.sdk_host_sysroot, self.sdk_native_path)
0103: localedir = oe.path.join(rootfs, self.d.getVar("libdir_nativesdk"), "locale")
*** 0104: generate_locale_archive(self.d, rootfs, target_arch, localedir)
0105: # And now delete the binary locales
0106: pkgs = fnmatch.filter(pm.list_installed(), "nativesdk-glibc-binary-localedata-*.utf-8")
0107: pm.remove(pkgs)
0108: else:
File: '/home/boherdi/Escritorio/toradex/build/../layers/openembedded-core/meta/lib/oe/package_manager.py', lineno: 135, function: generate_locale_archive
0131: # Need to set this so cross-localedef knows where the archive is
0132: env = dict(os.environ)
0133: env["LOCALEARCHIVE"] = oe.path.join(localedir, "locale-archive")
0134:
*** 0135: for name in sorted(os.listdir(localedir)):
0136: path = os.path.join(localedir, name)
0137: if os.path.isdir(path):
0138: cmd = ["cross-localedef", "--verbose"]
0139: cmd += arch_options
Exception: FileNotFoundError: [Errno 2] No such file or directory: '/home/boherdi/Escritorio/toradex/build/tmp/work/colibri_imx6ull-tdx-linux-gnueabi/tdx-reference-minimal-image/1.0-r0/sdk/image/opt/tdx-x11/5.0.0-devel-20200826205205+build.0/sysroots/x86_64-tdxsdk-linux/usr/lib/locale'
ERROR: Logfile of failure stored in: /home/boherdi/Escritorio/toradex/build/tmp/work/colibri_imx6ull-tdx-linux-gnueabi/tdx-reference-minimal-image/1.0-r0/temp/log.do_populate_sdk.31874
ERROR: Task (/home/boherdi/Escritorio/toradex/build/../layers/meta-toradex-demos/recipes-images/images/tdx-reference-minimal-image.bb:do_populate_sdk) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6239 tasks of which 6238 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
NOTE: Writing buildhistory took: 6 seconds
Summary: 1 task failed:
Summary: There were 2 WARNING messages shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
thanks
