WARNING: modbus-sdk-1.0+git${SRCPV}-r0 do_fetch: Failed to fetch URL ssh://git@github.com/.../MISC-Modbus-SDK-Cpp-Library.git;branch=master, attempting MIRRORS if available
ERROR: modbus-sdk-1.0+git${SRCPV}-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export PATH="/home/build/shared/oe-core/layers/openembedded-core/scripts:/home/build/shared/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/modbus-sdk/1.0+git${SRCPV}-r0/recipe-sysroot-native/usr/bin/arm-angstrom-linux-gnueabi:/home/build/shared/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/modbus-sdk/1.0+git${SRCPV}-r0/recipe-sysroot/usr/bin/crossscripts:/home/build/shared/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/modbus-sdk/1.0+git${SRCPV}-r0/recipe-sysroot-native/usr/sbin:/home/build/shared/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/modbus-sdk/1.0+git${SRCPV}-r0/recipe-sysroot-native/usr/bin:/home/build/shared/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/modbus-sdk/1.0+git${SRCPV}-r0/recipe-sysroot-native/sbin:/home/build/shared/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/modbus-sdk/1.0+git${SRCPV}-r0/recipe-sysroot-native/bin:/home/build/shared/oe-core/layers/openembedded-core/bitbake/bin:/home/build/shared/oe-core/build/tmp-glibc/hosttools"; export HOME="/home/build"; scp -B -r git@github.com:.../MISC-Modbus-SDK-Cpp-Library.git /home/build/shared/oe-core/build/downloads/ failed with exit code 127, output:
/bin/sh: 1: scp: not found
ERROR: modbus-sdk-1.0+git${SRCPV}-r0 do_fetch: Fetcher failure for URL: 'ssh://git@github.com/.../MISC-Modbus-SDK-Cpp-Library.git;branch=master'. Unable to fetch URL from any source.
ERROR: modbus-sdk-1.0+git${SRCPV}-r0 do_fetch: Function failed: base_do_fetch
ERROR: Logfile of failure stored in: /home/build/shared/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/modbus-sdk/1.0+git${SRCPV}-r0/temp/log.do_fetch.170
ERROR: Task (/home/build/shared/oe-core/build/../layers/meta-semisens/recipes-support/modbus-sdk/modbus-sdk_git.bb:do_fetch) failed with exit code '1'
I don’t know why scp can not be found. The scp package should be installed.
I don’t know if i made something wrong with the scp intallation.
It would be great if somebody could help me with this issue.
