Hello! Thank you for providing detailed output regarding your TorizonCore Builder issue.
Your error message indicates a conflict with a Docker container named /tcb-fetch-dind, which TorizonCore Builder uses for Docker-in-Docker operations. This type of conflict often appears even if you do not see the container in docker ps -a. It typically happens due to orphaned containers or inconsistent Docker contexts, especially after restarting your PC or switching between VS Code and a terminal.
Here are clear steps to resolve this issue:
1. Force Remove the Stuck Container
Even if it is not listed, try to force remove it by name:
docker rm -f tcb-fetch-dind
Or, if you have the container ID (from the error: a37f51d17af720790c9ba5a98f673d114532d5bcd83134a34b65b73e48b301d3):
docker rm -f a37f51d17af720790c9ba5a98f673d114532d5bcd83134a34b65b73e48b301d3
2. Remove the DinD Volume
There may also be a lingering volume (dind-volume) in use. Try:
docker volume rm dind-volume
If you get a “volume is in use” error, first ensure no containers are using it—removing the container above helps.
3. Verify Docker Context in VS Code
VS Code can use its own Docker context, which might differ from your terminal:
In the VS Code command palette, search for “Docker: Contexts” and ensure it is set to “default” (unless you know you’re using a specific context).
You can also check the
DOCKER_HOSTvariable. In your VS Code terminal, run:echo $DOCKER_HOSTIf it is set, try unsetting it:
unset DOCKER_HOST
Or, simply close and reopen VS Code after cleaning up containers above.
4. Restart Docker Daemon
After cleanup, restart Docker for good measure:
For Linux:
sudo systemctl restart docker
For Windows/Mac, restart Docker Desktop.
5. Prune Docker System (Optional and Destructive)
If the problem persists, prune all unused containers, volumes, networks, and images (this will remove unused stuff—be careful):
docker system prune -a --volumes
6. Alternative: Run From Command Line
If VS Code continues to have problems, try running your TorizonCore Builder operations in your system terminal or command prompt instead (not the VS Code integrated terminal) (source). Sometimes, context mismatches only occur in the VS Code terminal.
Once you have completed these steps, you should be able to build again. These steps address typical situations where a Docker context or orphaned container is causing a conflict.
Please let me know if you need further help or if this resolves the issue.
Reference: Docker container name conflict in TorizonCore Builder and VS Code context
