I am getting an error during my torizoncore build in VSCode. I am executing the tcb-build task, which was working as of yesterday. Today, after rebooting my PC, I am not able to build. I get an error about a dind container name that is already in use.
The error says:
raise cls(e, response=response, explanation=explanation) from e
docker.errors.APIError: 409 Client Error for http+docker://localhost/v1.48/containers/create?name=tcb-fetch-dind: Conflict ("Conflict. The container name "/tcb-fetch-dind" is already in use by container "a37f51d17af720790c9ba5a98f673d114532d5bcd83134a34b65b73e48b301d3". You have to remove (or rename) that container to be able to reuse that name.")
However, when I run docker container ls or docker ps -a I cannot see any container with that name or that hash.
Executing task: DOCKER_HOST= source ./.conf/tcb-env-setup.sh -s /home/jzylkin/repos/chipotle_dbpt/storage -t 3.13.0
Warning: If you intend to use torizoncore-builder as a server (listening to ports), then you should pass extra parameters to "docker run" (via the -- switch).
Setting up TorizonCore Builder with version 3.13.0.
2025-07-08 16:45:52,448 - torizon.tcbuilder.cli.build - INFO - Building image as per configuration file 'tcbuild.yaml'...
2025-07-08 16:45:52,472 - torizon.tcbuilder.cli.build - INFO -
=>> Handling input section
2025-07-08 16:45:53,099 - torizon.tcbuilder.backend.images - INFO - Unpacking Toradex Easy Installer image.
2025-07-08 16:45:53,099 - torizon.tcbuilder.backend.images - DEBUG - Running tar command: tar -xf /workdir/torizon-docker-verdin-imx8mp-Tezi_7.3.0-devel-202506+build.9.tar -C /storage/tmpicu8xh5i
2025-07-08 16:45:53,243 - torizon.tcbuilder.backend.images - INFO - Unpacking TorizonCore Toradex Easy Installer image.
2025-07-08 16:45:53,243 - torizon.tcbuilder.backend.images - DEBUG - Running tar command: tar --xattrs '--xattrs-include=*' -xhf /storage/tezi/torizon-docker-verdin-imx8mp.ota.tar.zst -C /storage/sysroot --use-compress-program 'zstd -dc'
2025-07-08 16:45:55,923 - torizon.tcbuilder.backend.images - INFO - Importing OSTree revision ca92207f703e96336e78f889a461f124b80a2d09fa9819097b4e129eb1e2bcff from local repository...
2025-07-08 16:45:55,925 - torizon.tcbuilder.backend.ostree - DEBUG - Pulling from local repository /storage/sysroot/ostree/repo commit checksum ca92207f703e96336e78f889a461f124b80a2d09fa9819097b4e129eb1e2bcff
1283 metadata, 9748 content objects imported; 648.3 MB content written
2025-07-08 16:45:59,833 - torizon.tcbuilder.backend.ostree - DEBUG - Pulling from local repository /storage/sysroot/ostree/repo commit checksum ca92207f703e96336e78f889a461f124b80a2d09fa9819097b4e129eb1e2bcff
0 metadata, 0 content objects imported; 0 bytes content written
2025-07-08 16:45:59,876 - torizon.tcbuilder.backend.images - INFO - Unpacked OSTree from Toradex Easy Installer image:
2025-07-08 16:45:59,876 - torizon.tcbuilder.backend.images - INFO - Commit checksum: ca92207f703e96336e78f889a461f124b80a2d09fa9819097b4e129eb1e2bcff
2025-07-08 16:45:59,876 - torizon.tcbuilder.backend.images - INFO - TorizonCore Version: 7.3.0-devel-202506+build.9
2025-07-08 16:45:59,876 - torizon.tcbuilder.cli.build - INFO -
=>> Handling customization section
=> Handling device-tree subsection
=> Selecting custom device-tree 'imx8mp-verdin-non-wifi-ivy-flattened.dts'
2025-07-08 16:45:59,876 - torizon.tcbuilder.cli.dt - DEBUG - dt_apply: include directories:
2025-07-08 16:45:59,901 - torizon.tcbuilder.backend.dt - INFO - 'imx8mp-verdin-non-wifi-ivy-flattened.dts' compiles successfully.
2025-07-08 16:45:59,921 - torizon.tcbuilder.cli.dt - INFO - warning: removing currently applied device tree overlays
2025-07-08 16:45:59,921 - torizon.tcbuilder.cli.dt - INFO - Device tree imx8mp-verdin-non-wifi-ivy-flattened.dtb successfully applied.
2025-07-08 16:45:59,921 - torizon.tcbuilder.cli.dto - DEBUG - Removing all overlays
2025-07-08 16:45:59,947 - torizon.tcbuilder.cli.build - INFO -
=>> Handling output section
2025-07-08 16:45:59,957 - torizon.tcbuilder.cli.union - DEBUG - union: subject='first-attempt' body='None'
2025-07-08 16:45:59,959 - torizon.tcbuilder.cli.union - INFO - Applying changes from STORAGE/dt.
2025-07-08 16:45:59,963 - torizon.tcbuilder.backend.union - DEBUG - Processing whiteouts.
2025-07-08 16:46:00,011 - torizon.tcbuilder.cli.union - INFO - Applying changes from WORKDIR/isolated-changes.
2025-07-08 16:46:00,014 - torizon.tcbuilder.backend.union - DEBUG - Processing whiteouts.
2025-07-08 16:46:00,015 - torizon.tcbuilder.backend.union - DEBUG - Removing all contents from /usr/etc/rpm-postinsts.
2025-07-08 16:46:00,062 - torizon.tcbuilder.backend.union - DEBUG - Transaction committed. 102521 bytes 21 objects written.
2025-07-08 16:46:00,065 - torizon.tcbuilder.cli.union - INFO - Commit 19f33dd03f655bd8d71b4941b809309352e0ffc68fcdfecbce41b1903badf373 has been generated for changes and is ready to be deployed.
2025-07-08 16:46:00,070 - torizon.tcbuilder.backend.deploy - INFO - Pulling OSTree with ref default from local archive repository...
2025-07-08 16:46:00,070 - torizon.tcbuilder.backend.deploy - INFO - Commit checksum: 19f33dd03f655bd8d71b4941b809309352e0ffc68fcdfecbce41b1903badf373
2025-07-08 16:46:00,070 - torizon.tcbuilder.backend.deploy - INFO - TorizonCore Version: 7.3.0-devel-202506+build.9-tcbuilder.20250708164600
2025-07-08 16:46:00,070 - torizon.tcbuilder.backend.deploy - INFO - Default kernel arguments: quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3
2025-07-08 16:46:00,070 - torizon.tcbuilder.backend.ostree - DEBUG - Pulling from local repository /storage/ostree-archive commit checksum 19f33dd03f655bd8d71b4941b809309352e0ffc68fcdfecbce41b1903badf373
1289 metadata, 9761 content objects imported; 648.4 MB content written
2025-07-08 16:46:01,654 - torizon.tcbuilder.backend.deploy - INFO - Pulling done.
2025-07-08 16:46:01,654 - torizon.tcbuilder.backend.deploy - INFO - Deploying OSTree with checksum 19f33dd03f655bd8d71b4941b809309352e0ffc68fcdfecbce41b1903badf373
2025-07-08 16:46:01,655 - torizon.tcbuilder.backend.deploy - DEBUG - Deploying revision 19f33dd03f655bd8d71b4941b809309352e0ffc68fcdfecbce41b1903badf373
2025-07-08 16:46:02,150 - torizon.tcbuilder.backend.deploy - INFO - Bootloader found in unpacked image: U-Boot
2025-07-08 16:46:02,150 - torizon.tcbuilder.backend.deploy - DEBUG - Write deployment for revision 19f33dd03f655bd8d71b4941b809309352e0ffc68fcdfecbce41b1903badf373
2025-07-08 16:46:02,274 - torizon.tcbuilder.backend.deploy - INFO - Deploying done.
2025-07-08 16:46:02,274 - torizon.tcbuilder.backend.deploy - INFO - Copy files not under OSTree control from original deployment.
2025-07-08 16:46:02,280 - torizon.tcbuilder.backend.deploy - INFO - Packing rootfs...
2025-07-08 16:46:02,283 - torizon.tcbuilder.backend.deploy - DEBUG - Running tar command: tar --xattrs '--xattrs-include=*' -cf /workdir/chipotle-TCB-CUSTOM/torizon-docker-verdin-imx8mp.ota.tar -S -C /deploy -p .
2025-07-08 16:46:03,128 - torizon.tcbuilder.backend.deploy - DEBUG - Running compress command: zstd --rm /workdir/chipotle-TCB-CUSTOM/torizon-docker-verdin-imx8mp.ota.tar
2025-07-08 16:46:05,137 - torizon.tcbuilder.backend.deploy - INFO - Packing rootfs done.
2025-07-08 16:46:05,137 - torizon.tezi.image - DEBUG - No 'filelist' present in image configuration.
2025-07-08 16:46:05,138 - torizon.tezi.image - DEBUG - Reading json_data[key], value 'Torizon OS'
2025-07-08 16:46:05,138 - torizon.tezi.image - DEBUG - Writing json_data[key] = 'Torizon OS'
2025-07-08 16:46:05,138 - torizon.tezi.image - DEBUG - Reading json_data[key], value '7.3.0-devel-202506+build.9'
2025-07-08 16:46:05,138 - torizon.tezi.image - DEBUG - Writing json_data[key] = '7.3.0-devel-202506+build.9.modified'
2025-07-08 16:46:05,138 - torizon.tezi.image - DEBUG - Writing json_data[key] = '2025-07-08'
2025-07-08 16:46:05,138 - torizon.tezi.image - DEBUG - Writing json_data[key] = 'True'
2025-07-08 16:46:05,138 - torizon.tezi.image - DEBUG - Reading json_data[key], value '7.3.0-devel-202506+build.9.modified'
2025-07-08 16:46:05,138 - torizon.tcbuilder.cli.build - INFO - Bundling images to directory bundle_20250708164605_138633.tmp
2025-07-08 16:46:05,139 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2025-07-08 16:46:05,139 - docker.utils.config - DEBUG - No config file found
2025-07-08 16:46:05,146 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /version HTTP/1.1" 200 852
2025-07-08 16:46:05,149 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.48/containers/json?limit=-1&all=0&size=0&trunc_cmd=0&filters=%7B%22name%22%3A+%5B%22tcb_1751993152%22%5D%7D HTTP/1.1" 200 1697
2025-07-08 16:46:05,150 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.48/containers/da29f806c759fe78e0676c6ce06a96d0f3ee6539f6b49aed43b21ac816caef82/json HTTP/1.1" 200 None
2025-07-08 16:46:05,151 - torizon.tcbuilder.backend.common - DEBUG - Current container ID (found by container name): da29f806c759fe78e0676c6ce06a96d0f3ee6539f6b49aed43b21ac816caef82
2025-07-08 16:46:05,152 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.48/containers/da29f806c759fe78e0676c6ce06a96d0f3ee6539f6b49aed43b21ac816caef82/json HTTP/1.1" 200 None
2025-07-08 16:46:05,152 - torizon.tcbuilder.backend.bundle - INFO - NOTE: TCB no longer expands environment variables present in the compose file.
2025-07-08 16:46:05,153 - torizon.tcbuilder.backend.bundle - DEBUG - recursive_yaml_value_check: Call with obj <class 'dict'>. Checking config values in ''
2025-07-08 16:46:05,153 - torizon.tcbuilder.backend.bundle - DEBUG - recursive_yaml_value_check: Call with obj <class 'dict'>. Checking config values in '/services'
2025-07-08 16:46:05,153 - torizon.tcbuilder.backend.bundle - DEBUG - recursive_yaml_value_check: Call with obj <class 'dict'>. Checking config values in '/services/chipotle'
2025-07-08 16:46:05,153 - torizon.tcbuilder.backend.bundle - DEBUG - recursive_yaml_value_check: Call with obj <class 'str'>. Checking config values in '/services/chipotle/image'
2025-07-08 16:46:05,153 - torizon.tcbuilder.backend.bundle - DEBUG - recursive_yaml_value_check: Call with obj <class 'str'>. Checking config values in '/services/chipotle/network_mode'
2025-07-08 16:46:05,153 - torizon.tcbuilder.backend.bundle - DEBUG - recursive_yaml_value_check: Call with obj <class 'str'>. Checking config values in '/services/chipotle/restart'
2025-07-08 16:46:05,153 - torizon.tcbuilder.backend.bundle - DEBUG - recursive_yaml_value_check: Call with obj <class 'list'>. Checking config values in '/services/chipotle/volumes'
2025-07-08 16:46:05,154 - torizon.tcbuilder.backend.bundle - DEBUG - recursive_yaml_value_check: Call with obj <class 'str'>. Checking config values in '/services/chipotle/volumes'
2025-07-08 16:46:05,154 - torizon.tcbuilder.backend.bundle - DEBUG - recursive_yaml_value_check: Call with obj <class 'dict'>. Checking config values in '/services/faad-wes'
2025-07-08 16:46:05,154 - torizon.tcbuilder.backend.bundle - DEBUG - recursive_yaml_value_check: Call with obj <class 'str'>. Checking config values in '/services/faad-wes/image'
2025-07-08 16:46:05,154 - torizon.tcbuilder.backend.bundle - DEBUG - recursive_yaml_value_check: Call with obj <class 'str'>. Checking config values in '/services/faad-wes/network_mode'
2025-07-08 16:46:05,154 - torizon.tcbuilder.backend.bundle - DEBUG - recursive_yaml_value_check: Call with obj <class 'str'>. Checking config values in '/services/faad-wes/restart'
2025-07-08 16:46:05,154 - torizon.tcbuilder.backend.bundle - DEBUG - Using DindManager
2025-07-08 16:46:05,154 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2025-07-08 16:46:05,155 - docker.utils.config - DEBUG - No config file found
2025-07-08 16:46:05,155 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2025-07-08 16:46:05,162 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /version HTTP/1.1" 200 852
2025-07-08 16:46:05,169 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.48/info HTTP/1.1" 200 None
2025-07-08 16:46:05,170 - docker.utils.config - DEBUG - Trying paths: ['/root/.docker/config.json', '/root/.dockercfg']
2025-07-08 16:46:05,170 - docker.utils.config - DEBUG - No config file found
2025-07-08 16:46:05,177 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /version HTTP/1.1" 200 852
2025-07-08 16:46:05,179 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.48/containers/json?limit=-1&all=0&size=0&trunc_cmd=0&filters=%7B%22name%22%3A+%5B%22tcb_1751993152%22%5D%7D HTTP/1.1" 200 1697
2025-07-08 16:46:05,180 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.48/containers/da29f806c759fe78e0676c6ce06a96d0f3ee6539f6b49aed43b21ac816caef82/json HTTP/1.1" 200 None
2025-07-08 16:46:05,180 - torizon.tcbuilder.backend.common - DEBUG - Current container ID (found by container name): da29f806c759fe78e0676c6ce06a96d0f3ee6539f6b49aed43b21ac816caef82
2025-07-08 16:46:05,181 - urllib3.connectionpool - DEBUG - http://localhost:None "GET /v1.48/containers/da29f806c759fe78e0676c6ce06a96d0f3ee6539f6b49aed43b21ac816caef82/json HTTP/1.1" 200 None
2025-07-08 16:46:05,182 - torizon.tcbuilder.backend.bundle - INFO -
Starting DIND container
2025-07-08 16:46:05,183 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.48/volumes/create HTTP/1.1" 201 182
2025-07-08 16:46:05,183 - torizon.tcbuilder.backend.bundle - DEBUG - Default platform: linux/arm/v7
2025-07-08 16:46:05,183 - torizon.tcbuilder.backend.bundle - DEBUG - Volume mapping for DinD: [{'Target': '/workdir/', 'Source': '/home/jzylkin/repos/chipotle_dbpt', 'Type': 'bind', 'ReadOnly': False}, {'Target': '/var/lib/docker/', 'Source': 'dind-volume', 'Type': 'volume', 'ReadOnly': False}]
2025-07-08 16:46:05,183 - torizon.tcbuilder.backend.bundle - DEBUG - Environment variables for DinD: {'DOCKER_TLS_CERTDIR': '/workdir/certs_20250708164605_154605.tmp', 'DOCKER_DEFAULT_PLATFORM': 'linux/arm/v7'}
2025-07-08 16:46:05,183 - torizon.tcbuilder.backend.bundle - DEBUG - Running DinD container: ports={'22376/tcp': 22376}, network=bridge
2025-07-08 16:46:05,185 - urllib3.connectionpool - DEBUG - http://localhost:None "POST /v1.48/containers/create?name=tcb-fetch-dind HTTP/1.1" 409 241
2025-07-08 16:46:05,185 - torizon.tcbuilder.backend.bundle - INFO - Stopping DIND container
2025-07-08 16:46:06,188 - urllib3.connectionpool - DEBUG - http://localhost:None "DELETE /v1.48/volumes/dind-volume HTTP/1.1" 409 120
2025-07-08 16:46:06,189 - torizon.tcbuilder.cli.build - INFO - Removing output directory 'chipotle-TCB-CUSTOM' due to build errors
2025-07-08 16:46:06,210 - root - ERROR - Error: Error trying to bundle Docker containers
2025-07-08 16:46:06,211 - root - DEBUG - Traceback (most recent call last):
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 275, in _raise_for_status
response.raise_for_status()
File "/usr/local/lib/python3.9/dist-packages/requests/models.py", line 1024, in raise_for_status
raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 409 Client Error: Conflict for url: http+docker://localhost/v1.48/containers/create?name=tcb-fetch-dind
The above exception was the direct cause of the following exception:
File "/builder/tcbuilder/backend/bundle.py", line 636, in download_containers_by_compose_file
manager.start(network, default_platform=platform,
File "/builder/tcbuilder/backend/bundle.py", line 282, in start
self.dind_container = self.host_client.containers.run(
File "/usr/local/lib/python3.9/dist-packages/docker/models/containers.py", line 876, in run
container = self.create(image=image, command=command,
File "/usr/local/lib/python3.9/dist-packages/docker/models/containers.py", line 935, in create
resp = self.client.api.create_container(**create_kwargs)
File "/usr/local/lib/python3.9/dist-packages/docker/api/container.py", line 440, in create_container
return self.create_container_from_config(config, name, platform)
File "/usr/local/lib/python3.9/dist-packages/docker/api/container.py", line 457, in create_container_from_config
return self._result(res, True)
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 281, in _result
self._raise_for_status(response)
File "/usr/local/lib/python3.9/dist-packages/docker/api/client.py", line 277, in _raise_for_status
raise create_api_error_from_http_exception(e) from e
File "/usr/local/lib/python3.9/dist-packages/docker/errors.py", line 39, in create_api_error_from_http_exception
File "/builder/tcbuilder/backend/bundle.py", line 675, in download_containers_by_compose_file
raise OperationFailureError(
tcbuilder.errors.OperationFailureError: Error: container images download failed: 409 Client Error for http+docker://localhost/v1.48/containers/create?name=tcb-fetch-dind: Conflict ("Conflict. The container name "/tcb-fetch-dind" is already in use by container "a37f51d17af720790c9ba5a98f673d114532d5bcd83134a34b65b73e48b301d3". You have to remove (or rename) that container to be able to reuse that name.")
During handling of the above exception, another exception occurred:
requests.exceptions.HTTPError: 409 Client Error: Conflict for url: http+docker://localhost/v1.48/volumes/dind-volume
File "/builder/tcbuilder/cli/build.py", line 459, in handle_bundle_common
download_containers_by_compose_file(**download_params)
File "/builder/tcbuilder/backend/bundle.py", line 679, in download_containers_by_compose_file
manager.stop()
File "/builder/tcbuilder/backend/bundle.py", line 346, in stop
self.dind_volume.remove()
File "/usr/local/lib/python3.9/dist-packages/docker/models/volumes.py", line 25, in remove
return self.client.api.remove_volume(self.id, force=force)
File "/usr/local/lib/python3.9/dist-packages/docker/api/volume.py", line 163, in remove_volume
self._raise_for_status(resp)
docker.errors.APIError: 409 Client Error for http+docker://localhost/v1.48/volumes/dind-volume: Conflict ("remove dind-volume: volume is in use - [a37f51d17af720790c9ba5a98f673d114532d5bcd83134a34b65b73e48b301d3]")
File "/builder/torizoncore-builder", line 231, in <module>
mainargs.func(mainargs)
File "/builder/tcbuilder/cli/build.py", line 695, in do_build
raise exc
File "/builder/tcbuilder/cli/build.py", line 668, in do_build
build(args.config_fname, args.storage_directory,
File "/builder/tcbuilder/cli/build.py", line 654, in build
raise exc
File "/builder/tcbuilder/cli/build.py", line 639, in build
handle_output_section(
File "/builder/tcbuilder/cli/build.py", line 309, in handle_output_section
handle_easy_installer_output(tezi_props, storage_dir, union_params)
File "/builder/tcbuilder/cli/build.py", line 387, in handle_easy_installer_output
handle_bundle_output(
File "/builder/tcbuilder/cli/build.py", line 476, in handle_bundle_output
bundle_dir, is_tmp_dir = handle_bundle_common(
File "/builder/tcbuilder/cli/build.py", line 464, in handle_bundle_common
raise TorizonCoreBuilderError(
tcbuilder.errors.TorizonCoreBuilderError: Error trying to bundle Docker containers
Deploying commit ref: default
* The terminal process "/usr/bin/bash '-c', 'DOCKER_HOST= source ./.conf/tcb-env-setup.sh -s /home/jzylkin/repos/chipotle_dbpt/storage -t 3.13.0'" terminated with exit code: 255.
* Terminal will be reused by tasks, press any key to close it.
