ferlzc
November 11, 2020, 1:39pm
1
Hello, i’m trying to enable the UART4 and UART5 on a Colibri iMX6DL 512MB using a custom made SBC.
To enable it, I added the following on my device-tree:
&iomuxc {
uart {
pinctrl_uart4: ctrl_uart4 {
fsl,pins = <
MX6QDL_PAD_CSI0_DAT12__UART4_RX_DATA 0x1b0b1
MX6QDL_PAD_CSI0_DAT13__UART4_TX_DATA 0x1b0b1
pinctrl_uart5: ctrl_uart5 {
fsl,pins = <
MX6QDL_PAD_CSI0_DAT14__UART5_RX_DATA 0x1b0b1
MX6QDL_PAD_CSI0_DAT15__UART5_TX_DATA 0x1b0b1
&uart4 {
pintctrl-names = "default";
pinctrl-0 = <&pinctrl_uart4>;
fsl,dte-mode;
status = "okay"; };
&uart5 {
pinctrl-0 = <&pinctrl_uart5>;
fsl,dte-mode;
status = "okay";};
Then I proceed to boot and I can check that /dev/ttymxc3 and /dev/ttymxc4 were mounted.
Then I proceed to start a simple test writing and reading values from that UART using the following:
stty -F /dev/ttymxc3 115200
testing module TX
echo "test" > /dev/ttymxc3
testing module RX
cat < /dev/ttymxc3 &
I’m using a external USB-TTL converter on my host to test the UART.
However I not receiving any data from the module nor I’m receiving any data from the host pc.
I’m missing any additional configuration on the device tree?
Thank you in advance.
Hi @ferlzc ,
I did some tests here and was able to make UART4 and UART5 work, see below the patch:
diff --git a/arch/arm/boot/dts/imx6dl-colibri-eval-v3.dts b/arch/arm/boot/dts/imx6dl-colibri-eval-v3.dts
index 426eca00d529..1dfafe1d3a28 100644
--- a/arch/arm/boot/dts/imx6dl-colibri-eval-v3.dts
+++ b/arch/arm/boot/dts/imx6dl-colibri-eval-v3.dts
@@ -238,6 +238,14 @@
+&uart4 {
+ status = "okay";
+&uart5 {
+ status = "okay";
&usbh1 {
diff --git a/arch/arm/boot/dts/imx6qdl-colibri.dtsi b/arch/arm/boot/dts/imx6qdl-colibri.dtsi
index cb4581e53b1b..12740a5133b7 100644
--- a/arch/arm/boot/dts/imx6qdl-colibri.dtsi
+++ b/arch/arm/boot/dts/imx6qdl-colibri.dtsi
@@ -786,6 +786,24 @@
+ uart4 {
+ pinctrl_uart4_dte: uart4grp-dte { /* DTE mode */
+ fsl,pins = <
+ MX6QDL_PAD_CSI0_DAT12__UART4_RX_DATA 0x1b0b1
+ MX6QDL_PAD_CSI0_DAT13__UART4_TX_DATA 0x1b0b1
+ uart5 {
+ pinctrl_uart5_dte: uart5grp-dte { /* DTE mode */
+ fsl,pins = <
+ MX6QDL_PAD_CSI0_DAT14__UART5_RX_DATA 0x1b0b1
+ MX6QDL_PAD_CSI0_DAT15__UART5_TX_DATA 0x1b0b1
usdhc {
pinctrl_mmc_cd: gpio_mmc_cd {
fsl,pins = <
@@ -855,10 +873,10 @@
MX6QDL_PAD_CSI0_DAT7__EIM_DATA05 0x1b0b0
MX6QDL_PAD_CSI0_DAT8__EIM_DATA06 0x1b0b0
MX6QDL_PAD_CSI0_DAT9__EIM_DATA07 0x1b0b0
- MX6QDL_PAD_CSI0_DAT12__EIM_DATA08 0x1b0b0
+ /*MX6QDL_PAD_CSI0_DAT12__EIM_DATA08 0x1b0b0
MX6QDL_PAD_CSI0_DAT13__EIM_DATA09 0x1b0b0
MX6QDL_PAD_CSI0_DAT14__EIM_DATA10 0x1b0b0
- MX6QDL_PAD_CSI0_DAT15__EIM_DATA11 0x1b0b0
+ MX6QDL_PAD_CSI0_DAT15__EIM_DATA11 0x1b0b0*/
MX6QDL_PAD_CSI0_DAT16__EIM_DATA12 0x1b0b0
MX6QDL_PAD_CSI0_DAT17__EIM_DATA13 0x1b0b0
MX6QDL_PAD_CSI0_DAT18__EIM_DATA14 0x1b0b0
@@ -1022,6 +1040,20 @@
status = "disabled";
+&uart4 {
+ pinctrl-names = "default";
+ pinctrl-0 = <&pinctrl_uart4_dte>;
+ fsl,dte-mode;
+ status = "disabled";
+&uart5 {
+ pinctrl-0 = <&pinctrl_uart5_dte>;
+ fsl,dte-mode;
&usbh1 {
vbus-supply = <®_usb_host_vbus>;
It seems that your changes are correct, but you need to remove the previous function from the pin.
Can you please do some tests?
Daniel Morais
ferlzc
November 24, 2020, 2:23pm
3
Hi @daniel.tx ,
I got the UART4 e UART5 working with your patch.
I was getting error because I did the pinctrl declaration on the imx6dl-colibri-eval-v3.dts and configured the &uart4 e &uart5 in the same file. Seems to be a convention to declare a peripheral configuration on .dtsi file with status=“disabled” and the enabled it on the .dts file. See the first gotcha .
The correct way is, as your patch, to declare the pinctrl-uart4 e pinctrl-uart5 on the imx6qdl-colibri.dtsi then configure
&uart4 {
fsl,dte-mode;
&uart5 {
fsl,dte-mode;
and then on the imx6dl-colibri-eval-v3.dts change the node status=“okay”
&uart4 {
&uart5 {
Thanks again for your help!
