Hello Toradex Community,
I’m working with a Verdin AM62 module and need to enable SPI1 through the device tree. In my Yocto build environment, I’m encountering the following
- File Location
- Found: k3-am62-verdin.dtsi in tmp/work-shared/verdin-am62/kernel-source/arch/arm64/boot/dts/
- Missing: k3-am62-verdin.dts (not found anywhere in the Yocto build
- Yocto-Specific Context:
Using Toradex’s BSP layer with linux-toradex-ti recipe
Building with Yocto Scarthgap
Need to configure SPI1 with:
Mode 3 (CPOL=1, CPHA=1)
3MHz speed
8 bits/word
Assume it modifies, what are my next steps and also like how to build that like i need to build full image or i need to build that specif dts part if so what is the command to do so
like i have mallow_carrier_board now and i choosen to use verdin_am62
Soo now there are many dts and dtsi files which one i should modify
udaykumar@SYS-TK01:~/oe-core/build/tmp/work-shared/verdin-am62/kernel-source/arch/arm64/boot/dts/ti$ ls
k3-am625-beagleplay-csi2-ov5640.dtso k3-am62p5-verdin-wifi-mallow.dts k3-am6548-iot2050-advanced-pg2.dts k3-j721e-evm-pcie0-ep.dtso
k3-am625-beagleplay-csi2-tevi-ov5640.dtso k3-am62p5-verdin-wifi-yavia.dts k3-am654-base-board.dts k3-j721e-evm-pcie1-ep.dtso
k3-am625-beagleplay.dts k3-am62p.dtsi k3-am654-base-board-rocktech-rk101-panel.dtso k3-j721e-evm-quad-port-eth-exp.dtso
k3-am625-beagleplay-lincolntech-lcd185-panel.dtso k3-am62-phycore-som.dtsi k3-am654-base-board-toshiba-tc358867-evm.dtso k3-j721e-main.dtsi
k3-am625.dtsi k3-am62p-main.dtsi k3-am654.dtsi k3-j721e-mcu-wakeup.dtsi
k3-am625-minimal.dts k3-am62p-mcu.dtsi k3-am654-icssg2.dtso k3-j721e-sk-csi2-dual-imx219.dtso
k3-am625-phyboard-lyra-rdk.dts k3-am62p-thermal.dtsi k3-am654-idk.dtso k3-j721e-sk-csi2-ov5640.dtso
k3-am625-sk.dts k3-am62p-verdin-dahlia.dtsi k3-am654-industrial-thermal.dtsi k3-j721e-sk.dts
k3-am625-sk-ecap-capture.dtso k3-am62p-verdin-dev.dtsi k3-am654-pcie-usb2.dtso k3-j721e-sk-fpdlink-fusion.dtso
k3-am625-sk-lincolntech-lcd185-panel.dtso k3-am62p-verdin.dtsi k3-am654-pcie-usb3.dtso k3-j721e-sk-rpi-hdr-ehrpwm.dtso
k3-am625-sk-m2-cc3301.dtso k3-am62p-verdin-ivy.dtsi k3-am65.dtsi k3-j721e-som-p0.dtsi
k3-am625-sk-mcspi-loopback.dtso k3-am62p-verdin-mallow.dtsi k3-am65-iot2050-common.dtsi k3-j721e-thermal.dtsi
k3-am625-sk-microtips-mf101hie-panel.dtso k3-am62p-verdin-nonwifi.dtsi k3-am65-iot2050-common-pg1.dtsi k3-j721s2-common-proc-board.dts
k3-am625-sk-rpi-hdr-ehrpwm.dtso k3-am62p-verdin-wifi.dtsi k3-am65-iot2050-common-pg2.dtsi k3-j721s2.dtsi
k3-am625-verdin-nonwifi-dahlia.dts k3-am62p-verdin-yavia.dtsi k3-am65-main.dtsi k3-j721s2-evm-csi2-ov5640.dtso
k3-am625-verdin-nonwifi-dev.dts k3-am62p-wakeup.dtsi k3-am65-mcu.dtsi k3-j721s2-evm-fusion.dtso
k3-am625-verdin-nonwifi-ivy.dts k3-am62-thermal.dtsi k3-am65-wakeup.dtsi k3-j721s2-evm-gesi-exp-board.dtso
k3-am625-verdin-nonwifi-mallow.dts k3-am62-verdin-dahlia.dtsi k3-am68-sk-base-board.dts k3-j721s2-evm-pcie1-ep.dtso
k3-am625-verdin-nonwifi-yavia.dts k3-am62-verdin-dev.dtsi k3-am68-sk-bb-csi2-ov5640.dtso k3-j721s2-main.dtsi
k3-am625-verdin-wifi-dahlia.dts k3-am62-verdin.dtsi k3-am68-sk-rpi-hdr-ehrpwm.dtso k3-j721s2-mcu-wakeup.dtsi
k3-am625-verdin-wifi-dev.dts k3-am62-verdin-ivy.dtsi k3-am68-sk-som.dtsi k3-j721s2-som-p0.dtsi
k3-am625-verdin-wifi-ivy.dts k3-am62-verdin-mallow.dtsi k3-am68-sk-v3link-fusion.dtso k3-j721s2-thermal.dtsi
k3-am625-verdin-wifi-mallow.dts k3-am62-verdin-nonwifi.dtsi k3-am69-aquila-clover.dts k3-j722s.dtsi
k3-am625-verdin-wifi-yavia.dts k3-am62-verdin-wifi.dtsi k3-am69-aquila-dev.dts k3-j722s-evm-csi2-ov5640.dtso
k3-am62a7.dtsi k3-am62-verdin-yavia.dtsi k3-am69-aquila.dtsi k3-j722s-evm-csi2-quad-rpi-cam-imx219.dtso
k3-am62a7-sk-csi2-ox05b1s.dtso k3-am62-wakeup.dtsi k3-am69-sk-csi2-ov5640.dtso k3-j722s-evm-csi2-quad-tevi-ov5640.dtso
k3-am62a7-sk.dts k3-am62x-phyboard-lyra-gpio-fan.dtso k3-am69-sk.dts k3-j722s-evm-dsi-rpi-7inch-panel.dtso
k3-am62a7-sk-e3-max-opp.dtso k3-am62x-sk-common.dtsi k3-am69-sk-fpdlink-fusion-auxport.dtso k3-j722s-evm.dts
k3-am62a7-sk-ethernet-dc01.dtso k3-am62x-sk-csi2-imx219.dtso k3-am69-sk-rpi-hdr-ehrpwm.dtso k3-j722s-evm-fpdlink-fusion.dtso
k3-am62a7-sk-fusion.dtso k3-am62x-sk-csi2-ov5640.dtso k3-fpdlink-imx390-rcm-0-0.dtso k3-j722s-evm-microtips-mf101hie-panel.dtso
k3-am62a7-sk-m2-cc3301.dtso k3-am62x-sk-csi2-tevi-ov5640.dtso k3-fpdlink-imx390-rcm-0-1.dtso k3-j722s-evm-pwm.dtso
k3-am62a7-sk-rpi-hdr-ehrpwm.dtso k3-am62x-sk-csi2-v3link-fusion.dtso k3-fpdlink-imx390-rcm-0-2.dtso k3-j722s-evm-v3link-fusion.dtso
k3-am62a7-sk-ub954-evm.dtso k3-am62x-sk-dmtimer-pwm.dtso k3-fpdlink-imx390-rcm-0-3.dtso k3-j722s-main.dtsi
k3-am62a.dtsi k3-am62x-sk-eqep.dtso k3-fpdlink-imx390-rcm-1-0.dtso k3-j742s2.dtsi
k3-am62a-main.dtsi k3-am62x-sk-fastboot-disable-hdmi.dtso k3-fpdlink-imx390-rcm-1-1.dtso k3-j742s2-evm.dts
k3-am62a-mcu.dtsi k3-am62x-sk-hdmi-audio.dtso k3-fpdlink-imx390-rcm-1-2.dtso k3-j742s2-evm-ethfw.dtso
k3-am62a-thermal.dtsi k3-am62x-sk-lpm-wkup-sources.dtso k3-fpdlink-imx390-rcm-1-3.dtso k3-j742s2-main.dtsi
k3-am62a-wakeup.dtsi k3-am62x-sk-mcan.dtso k3-fpdlink-imx390-rcm-2-0.dtso k3-j784s4.dtsi
k3-am62.dtsi k3-am62x-sk-microtips-mf103hie-lcd2.dtso k3-fpdlink-imx390-rcm-2-1.dtso k3-j784s4-evm-csi2-ov5640.dtso
k3-am62-lp-sk.dts k3-am62x-sk-pwm.dtso k3-fpdlink-imx390-rcm-2-2.dtso k3-j784s4-evm.dts
k3-am62-lp-sk-lincolntech-lcd185-panel.dtso k3-am642.dtsi k3-fpdlink-imx390-rcm-2-3.dtso k3-j784s4-evm-ethfw.dtso
k3-am62-lp-sk-microtips-mf101hie-panel.dtso k3-am642-evm.dts k3-fpdlink-ov2312-0-0.dtso k3-j784s4-evm-pcie0-pcie1-ep.dtso
k3-am62-lp-sk-nand.dtso k3-am642-evm-icssg1-dualemac.dtso k3-fpdlink-ov2312-0-1.dtso k3-j784s4-evm-quad-port-eth-exp1.dtso
k3-am62-main.dtsi k3-am642-evm-icssg1-dualemac-mii.dtso k3-fpdlink-ov2312-0-2.dtso k3-j784s4-evm-usxgmii-exp1-exp2.dtso
k3-am62-mcu.dtsi k3-am642-evm-nand.dtso k3-fpdlink-ov2312-0-3.dtso k3-j784s4-main.dtsi
k3-am62p5.dtsi k3-am642-evm-pcie0-ep.dtso k3-j7200-common-proc-board.dts k3-j784s4-mcu-wakeup.dtsi
k3-am62p5-sk-dsi-rpi-7inch-panel.dtso k3-am642-evm-sk-cpsw3g-pps.dtso k3-j7200.dtsi k3-j784s4-thermal.dtsi
k3-am62p5-sk-dss-shared-mode.dtso k3-am642-phyboard-electra-rdk.dts k3-j7200-evm-ethfw.dtso k3-pinctrl.h
k3-am62p5-sk.dts k3-am642-sk.dts k3-j7200-evm-mcspi-loopback.dtso k3-serdes.h
k3-am62p5-sk-eqep.dtso k3-am642-sk-pwm.dtso k3-j7200-evm-pcie1-ep.dtso k3-v3link-imx219-0-0.dtso
k3-am62p5-sk-ethfw.dtso k3-am642-tqma64xxl.dtsi k3-j7200-evm-quad-port-eth-exp.dtso k3-v3link-imx219-0-1.dtso
k3-am62p5-sk-m2-cc3301.dtso k3-am642-tqma64xxl-mbax4xxl.dts k3-j7200-main.dtsi k3-v3link-imx219-0-2.dtso
k3-am62p5-sk-mcan.dtso k3-am64.dtsi k3-j7200-mcu-wakeup.dtsi k3-v3link-imx219-0-3.dtso
k3-am62p5-sk-microtips-mf070zima-lcd3.dtso k3-am64-main.dtsi k3-j7200-som-p0.dtsi k3-v3link-imx219-1-0.dtso
k3-am62p5-sk-microtips-mf101hie-panel.dtso k3-am64-mcu.dtsi k3-j7200-thermal.dtsi k3-v3link-imx219-1-1.dtso
k3-am62p5-sk-microtips-mf103hie-lcd2.dtso k3-am64-phycore-som.dtsi k3-j721e-beagleboneai64-dsi-rpi-7inch-panel.dtso k3-v3link-imx219-1-2.dtso
k3-am62p5-sk-pwm.dtso k3-am64-thermal.dtsi k3-j721e-beagleboneai64.dts k3-v3link-imx219-1-3.dtso
k3-am62p5-sk-rpi-hdr-ehrpwm.dtso k3-am64-tqma64xxl-mbax4xxl-sdcard.dtso k3-j721e-beagleboneai64-microtips-mf070zima-lcd3.dtso k3-v3link-ov5640-0-0.dtso
k3-am62p5-verdin-nonwifi-dahlia.dts k3-am64-tqma64xxl-mbax4xxl-wlan.dtso k3-j721e-common-proc-board.dts k3-v3link-ov5640-0-1.dtso
k3-am62p5-verdin-nonwifi-dev.dts k3-am6528-iot2050-basic-common.dtsi k3-j721e-common-proc-board-infotainment.dtso k3-v3link-ov5640-0-2.dtso
k3-am62p5-verdin-nonwifi-ivy.dts k3-am6528-iot2050-basic.dts k3-j721e.dtsi k3-v3link-ov5640-0-3.dtso
k3-am62p5-verdin-nonwifi-mallow.dts k3-am6528-iot2050-basic-pg2.dts k3-j721e-evm-csi2-ov5640.dtso k3-v3link-tevi-ov5640-0-0.dtso
k3-am62p5-verdin-nonwifi-yavia.dts k3-am652.dtsi k3-j721e-evm-ethfw.dtso k3-v3link-tevi-ov5640-0-1.dtso
k3-am62p5-verdin-wifi-dahlia.dts k3-am6548-iot2050-advanced-common.dtsi k3-j721e-evm-fusion.dtso k3-v3link-tevi-ov5640-0-2.dtso
k3-am62p5-verdin-wifi-dev.dts k3-am6548-iot2050-advanced.dts k3-j721e-evm-gesi-exp-board.dtso k3-v3link-tevi-ov5640-0-3.dtso
k3-am62p5-verdin-wifi-ivy.dts k3-am6548-iot2050-advanced-m2.dts k3-j721e-evm-ina2xx.dtso Makefile
udaykumar@SYS-TK01:~/oe-core/build/tmp/work-shared/verdin-am62/kernel-source/arch/arm64/boot/dts/ti$ nano k3-am62-verdin.dtsi
