Hi all,
we are using Verdin am62 and we are trying to check the PREEMPT_RT in the kernel . we tried to enable it by adding below changes to the conf.local.conf file, but it seems like RT is not enabled properly.
PREFERRED_PROVIDER_virtual/kernel = "linux-toradex-rt"
DISTRO_mx8 = "tdx-xwayland-rt"
we followed the below link, but it does not work
we tried both the things but, we are unable to see Fully Preemptible Kernel (Real-Time) under general setup in menuconffig (bitbake virtual/kernel -c menuconfig)
kindly let us know the steps.
Hello! Thank you for reaching out with your question about enabling PREEMPT_RT on the Verdin AM62.
The configuration you used is specific to i.MX8-based modules (DISTRO_mx8 = "tdx-xwayland-rt"), and will not work for the Verdin AM62. While Toradex provides an experimental PREEMPT_RT kernel for some platforms, enabling RT on the Verdin AM62 requires its own procedure.
Here’s how you can proceed:
1. Use the Correct Distro and Kernel Configuration
For Verdin AM62, do not use the DISTRO_mx8 variable. Instead, you should set the preferred kernel provider:
Set the correct real-time distro as follows (replace tdx-xwayland with your current Torizon distro if different):
DISTRO = "tdx-xwayland-rt"
2. Explicitly Enable PREEMPT_RT in the Kernel
After configuring your build, run:
bitbake -c menuconfig virtual/kernel
In menuconfig, under General setup, look for the following options:
Preemption Model
- Choose Fully Preemptible Kernel (Real-Time)
If you do not see this option, it is likely the PREEMPT_RT patches are not applied for your kernel branch or machine. In that case, ensure you are building with linux-toradex-rt and the correct distro.
3. Build and Deploy
Save your configuration and rebuild the kernel:
bitbake -f -c compile virtual/kernel
Deploy the new kernel to your target device.
4. Check if PREEMPT_RT is Enabled
After booting, on the device run:
zcat /proc/config.gz | grep PREEMPT
You should see:
CONFIG_PREEMPT_RT_FULL=y
Or in recent kernels:
CONFIG_PREEMPT_DYNAMIC=y
CONFIG_PREEMPT_RT=y
For more information and detailed instructions on real-time Linux on Toradex platforms, please refer to the official documentation:
If you have any further questions or need step-by-step guidance for a specific Yocto/TorizonCore version, please provide those details!
