Enabling GPU Acceleration Mode using Chromium Version 112.X.X.X
Dear Support Team,
I hope this email finds you well. I am writing to seek assistance with a technical issue I have encountered while using the Toradex iMX8MP board as an HTML server with the Chromium browser (v12) installed. I have also provided details of the setup and the problem below:
Setup:
Currently We are planning to Enable the GPU HW Aacceleration on the Chromium Version 112 With Toradex BSP Version 6.2.0.
As provided in your manual based on Version V102.
Queries :
  1. Can GPU HW Acceleration be enabled on versions greater than v102.
  2. Do we need to follow the same steps as suggested in manual.
Please guide us on the above concerns.
Regards
Raghu
Hi @raghu.reddy ,
Currently only tested version is mentioned in article. That said you can test newer version as per your requirement. Ideally steps should be same.
Ritesh Kumar
