colibri imx7d emmc
Linux BSP 3, kernel 4.14
We use the Colibri imx7d and we have the same Wifi/BT module as you have on the imx6 module with Wifi AW-CM276NF
I would like to know what extra features I need to enable when I compile the kernel to support the ability to be able to send audio over BT to a BT audio speaker.
BT and Wifi works perfectly for us.
Hi @eoin_oc1 !
You are using the Wifi AW-CM276NF module connected to which interface on Colibri iMX7D?
And, please take a look at this Verdin IMX8MM: configuring BT Audio post.
Although it targets Verdin iMX8M Mini and BSP 5, it might be a good reference to follow.
Thanks for the useful info, how can I edit the volume? I am sending to a Bluetooth speaker, I am the source.
I can already play back through my speaker after following that guide, but don’t know how to do volume control
Hi @eoin_oc1,
did you try to use alsamixer on your module?
More information can be found here:
Kevin
Heres the trick for changing the volume
amixer -D bluealsa set ‘17932 SPEAKER - A2DP’ 0-127
the 17932 was the name of my BT speaker are checking
amixer -D bluealsa scontrols
Hi @eoin_oc1 ,
Thank you for letting us know, glad that it worked.
Kevin
