Enable Virtual Keyboard on Weston
Failed to open connection to “session” message bus: /usr/bin/dbus-launch terminated abnormally without any error message
:handshake:
The error message you’re encountering indicates an issue with the D-Bus session bus, which is often required for various desktop environment components, including virtual keyboards.
To resolve this, you can try the following steps:
  1. Ensure D-Bus is Running:
    Make sure that the D-Bus service is running inside your Weston container. You can start it manually if it’s not running:
    dbus-daemon --system --fork
  2. Install D-Bus:
    Ensure that D-Bus is installed in your Weston container. You can install it using the package manager:
    apt-get update
    apt-get install dbus
  3. Launch D-Bus Session:
    You might need to launch a D-Bus session manually before starting your application:
    eval `dbus-launch --sh-syntax`
    export DBUS_SESSION_BUS_ADDRESS
  4. Modify Dockerfile:
    If you are using a custom Dockerfile for your Weston container, ensure that D-Bus is installed and started within the Dockerfile:
    RUN apt-get update && apt-get install -y dbus
    CMD ["dbus-daemon", "--system", "--fork", "&&", "weston"]
  5. Check Permissions:
    Ensure that the user running the Weston container has the necessary permissions to access the D-Bus session bus.
By following these steps, you should be able to resolve the D-Bus related issue and enable the virtual keyboard on Weston.
Best regards, Toradex AI Assistant
Hello @Ahmed49,
Could you please provide more details regarding this error that you are seeing?
When do you see this error log?
Are you using Torizon OS? If yes which version?
What kind of application are you building? Are you using one of our templates from VS Code IDE Integration? If yes, which one?
Hello @rudhi.tx,
First, I got this reply from @jeremias.tx Enable the Virtual Keyboard on Weston - Technical Support - Toradex Community
The idea was about enabling the virtual Keyboard on my weston, so for user input, the virtual keyboard should apear, then no need to a physical keyboard .
I have included the Utils folder from the avaloniaDemo from @matheus.tx GitHub’s repository wince-alternative-demos/avaloniaDemo at main · microhobby/wince-alternative-demos · GitHub
So, when I got focus on any TextBox in my Avalonia Application, I got this error:
Here is more details about the Environment where I’ am working.
I am building the Avalonia MVVM GTK from the VS Code IDE Extension.
So the missing part is the org.onboard.Onboard Dbus user service
Then I need to create a bind mount between the Dbus on the Torizon OS and the one from the Avalonia Application?
Any Help?
Ahmed49
Hello @Ahmed49,
As @jeremias.tx answered on the other post, this code was specifically written for that Avalonia demo that we have. It would be best if you did some adaptation to get it working in your environment. We can recommend you a partner to help you with that. Here is our partner network: Embedded Computing | Hardware & Software Service Partners
Please let me know what you think.
Hi @Ahmed49 !
We were informed that most of your open questions are solved. So we are going to close this question tomorrow.
Could you please confirm that this specific thread is indeed solved? Otherwise, please let us know how we can further help you.
