I’m currently trying to implement the most recent LTS-Kernel int out BSP for the Colibri T30. I’m struggling with the GPIOs currently, to do the correct configuration in the device tree (I think). For now I’m focused on SODIMM 30 (gpiochip 0, offset 6, Tegra Pin A.06), which should act as a GPIO output (Turns an LED on/off).
(We need to setup more GPIO Pins, but before I contiue, I want to make sure I can get this one configured & working properly)
When using the “gpioset 0 6=1/0” command, nothing happens, the output isn’t changed.
From our DT:
pinmux@70000868 {
pinctrl-names = "default";
pinctrl-0 = <&state_default>;
state_default: pinmux {
/* Colibri Pin 30 LED */
sdmmc3-clk-pa6 {
nvidia,pins = "sdmmc3_clk_pa6";
nvidia,function = "sdmmc3"; //What function to use here for GPIO output functionallity?
nvidia,pull = <TEGRA_PIN_PULL_UP>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
I’m not sure if that configuration is correct to make that pin work as GPIO though, and I can hardly find references for possible functions. Closest I found (aside from Cilobro T30 datasheet) was probably this:
DTs to look at for further reference:
When I use the GPIO hogging mechanism, I can set permanent on/off states, but we need to be able to change this during runtime, which is not possible in this case, but this makes it clear that the hardware itself is working.
test1 {// this works but only static output
gpio-hog;
gpios = <TEGRA_GPIO(A, 6) GPIO_ACTIVE_HIGH>;
output-high;
line-name = "SODIMM_30_LED";
What am I doing wrong here? Any ideas what I need to change?
If further Information is needed, let me know.
I’m aware that this configuration might not be officially supported, but we need a solution regardless.
Softwareinfo:
- We use the latest official Yocto-BSP 2.8 as base
- libgpiod v1.4.3 (taken from yocto kirkstone release)
- Mainline kernel 6.6: Making sure you're not a bot!
gpioinfo output:
gpiochip0 - 256 lines:
line 0: unnamed unused input active-high
line 1: "SODIMM_121" unused input active-high
line 2: "SODIMM_186" unused input active-high
line 3: "SODIMM_184" unused input active-high
line 4: "SODIMM_146_1" unused input active-high
line 5: "SODIMM_144_1" unused input active-high
line 6: "SODIMM_30" unused output active-high
line 7: "SODIMM_67" unused input active-high
line 8: "SODIMM_36" unused input active-high
line 9: "SODIMM_32" unused input active-high
line 10: "SODIMM_154" unused input active-high
line 11: "SODIMM_56" unused input active-high
line 12: "SODIMM_59" unused input active-high
line 13: "SODIMM_28" unused input active-high
line 14: "SODIMM_55" unused input active-high
line 15: "SODIMM_63" unused input active-high
line 16: "SODIMM_119" unused input active-high
line 17: "SODIMM_81" unused input active-high
line 18: "SODIMM_21" unused input active-high
line 19: "SODIMM_19" unused input active-high
line 20: "SODIMM_196" unused input active-high
line 21: "SODIMM_194" unused input active-high
line 22: unnamed unused input active-high
line 23: "SODIMM_43" unused input active-high
line 24: unnamed unused input active-high
line 25: unnamed unused input active-high
line 26: unnamed unused input active-high
line 27: "SODIMM_86_2" unused input active-high
line 28: "SODIMM_92_2" unused input active-high
line 29: unnamed unused input active-high
line 30: unnamed unused input active-high
line 31: unnamed unused input active-high
line 32: "SODIMM_76" unused input active-high
line 33: "SODIMM_70" unused input active-high
line 34: "SODIMM_60" unused input active-high
line 35: "SODIMM_58" unused input active-high
line 36: "SODIMM_78" unused input active-high
line 37: "SODIMM_72" unused input active-high
line 38: "SODIMM_80" unused input active-high
line 39: "SODIMM_46" unused input active-high
line 40: "SODIMM_62" unused input active-high
line 41: "SODIMM_48" unused input active-high
line 42: "SODIMM_74" unused input active-high
line 43: "SODIMM_50" unused input active-high
line 44: "SODIMM_52" unused input active-high
line 45: "SODIMM_54" unused input active-high
line 46: "SODIMM_66" unused input active-high
line 47: "SODIMM_64" unused input active-high
line 48: "SODIMM_149" unused input active-high
line 49: "SODIMM_151" unused input active-high
line 50: "SODIMM_153" unused input active-high
line 51: "SODIMM_155" unused input active-high
line 52: "SODIMM_157" unused input active-high
line 53: "SODIMM_159" unused input active-high
line 54: "SODIMM_161" unused input active-high
line 55: "SODIMM_163" unused input active-high
line 56: "SODIMM_165" unused input active-high
line 57: "SODIMM_167" unused input active-high
line 58: "SODIMM_169" unused input active-high
line 59: "SODIMM_171" unused input active-high
line 60: "SODIMM_173" unused input active-high
line 61: "SODIMM_175" unused input active-high
line 62: "SODIMM_177" unused input active-high
line 63: "SODIMM_179" unused input active-high
line 64: "SODIMM_89" unused input active-high
line 65: "SODIMM_91" unused input active-high
line 66: unnamed unused input active-high
line 67: "SODIMM_130" unused input active-high
line 68: "SODIMM_87" unused input active-high
line 69: "SODIMM_95_2" unused input active-high
line 70: "SODIMM_132" unused input active-high
line 71: "SODIMM_95_1" unused input active-high
line 72: "SODIMM_126" unused input active-high
line 73: "SODIMM_44_1" unused input active-high
line 74: "SODIMM_128" unused input active-high
line 75: "SODIMM_68" unused input active-high
line 76: "SODIMM_82" unused input active-high
line 77: "SODIMM_113" unused input active-high
line 78: "SODIMM_111" unused input active-high
line 79: "SODIMM_38" unused input active-high
line 80: "SODIMM_150" unused input active-high
line 81: "SODIMM_152" unused input active-high
line 82: "SODIMM_105" unused output active-high
line 83: "SODIMM_107" unused input active-high
line 84: "SODIMM_106" unused input active-high
line 85: "SODIMM_137" unused input active-high
line 86: "SODIMM_135" unused input active-high
line 87: "SODIMM_34" unused input active-high
line 88: unnamed unused input active-high
line 89: unnamed unused input active-high
line 90: unnamed unused input active-high
line 91: unnamed unused input active-high
line 92: unnamed unused input active-high
line 93: unnamed unused input active-high
line 94: unnamed unused input active-high
line 95: unnamed unused input active-high
line 96: "SODIMM_57" unused input active-high
line 97: "SODIMM_61" unused input active-high
line 98: "SODIMM_136_2" unused input active-high
line 99: "SODIMM_138_2" unused input active-high
line 100: "SODIMM_140_2" unused input active-high
line 101: "SODIMM_142_2" unused input active-high
line 102: "SODIMM_144_2" unused input active-high
line 103: "SODIMM_146_2" unused input active-high
line 104: "SODIMM_174" unused input active-high
line 105: "SODIMM_176" unused input active-high
line 106: "SODIMM_178" unused input active-high
line 107: "SODIMM_180" unused input active-high
line 108: "SODIMM_160" unused input active-high
line 109: "SODIMM_158" unused input active-high
line 110: "SODIMM_162" unused input active-high
line 111: unnamed unused input active-high
line 112: "SODIMM_23" unused input active-high
line 113: "SODIMM_35" unused input active-high
line 114: "SODIMM_33" unused input active-high
line 115: "SODIMM_25" unused input active-high
line 116: "SODIMM_27" unused input active-high
line 117: "SODIMM_37" unused input active-high
line 118: "SODIMM_31" unused input active-high
line 119: "SODIMM_29" unused input active-high
line 120: unnamed unused input active-high
line 121: unnamed unused input active-high
line 122: unnamed unused input active-high
line 123: unnamed unused input active-high
line 124: "SODIMM_120" unused input active-high
line 125: "SODIMM_122" unused input active-high
line 126: "SODIMM_124" unused input active-high
line 127: "SODIMM_188" unused input active-high
line 128: unnamed unused input active-high
line 129: unnamed unused input active-high
line 130: unnamed unused input active-high
line 131: unnamed unused input active-high
line 132: unnamed unused input active-high
line 133: unnamed unused input active-high
line 134: unnamed unused input active-high
line 135: unnamed unused input active-high
line 136: unnamed unused input active-high
line 137: unnamed unused input active-high
line 138: unnamed unused input active-high
line 139: unnamed unused input active-high
line 140: unnamed unused input active-high
line 141: unnamed unused input active-high
line 142: unnamed unused input active-high
line 143: unnamed unused input active-high
line 144: "SODIMM_73" unused input active-high
line 145: unnamed unused input active-high
line 146: "SODIMM_47_2" unused input active-high
line 147: "SODIMM_190_2" unused input active-high
line 148: "SODIMM_192_2" unused input active-high
line 149: "SODIMM_49_2" unused input active-high
line 150: "SODIMM_51_2" unused input active-high
line 151: "SODIMM_53_2" unused input active-high
line 152: unnamed unused input active-high
line 153: unnamed unused input active-high
line 154: unnamed unused input active-high
line 155: unnamed unused input active-high
line 156: unnamed unused input active-high
line 157: "SODIMM_133" unused input active-high
line 158: "SODIMM_127" unused input active-high
line 159: unnamed unused input active-high
line 160: "SODIMM_123" unused input active-high
line 161: "SODIMM_125" unused input active-high
line 162: "SODIMM_110" unused input active-high
line 163: "SODIMM_112" unused input active-high
line 164: "SODIMM_114" unused input active-high
line 165: "SODIMM_116" unused input active-high
line 166: "SODIMM_118" unused input active-high
line 167: unnamed unused input active-high
line 168: unnamed "irq" input active-low [used]
line 169: "SODIMM_45" unused input active-high
line 170: "SODIMM_71" unused input active-high
line 171: "SODIMM_85" unused input active-high
line 172: unnamed unused input active-high
line 173: unnamed unused input active-high
line 174: unnamed unused input active-high
line 175: unnamed unused input active-high
line 176: "SODIMM_93" unused input active-high
line 177: "SODIMM_44_2" unused input active-high
line 178: "SODIMM_129" unused input active-high
line 179: "SODIMM_131" unused input active-high
line 180: unnamed unused input active-high
line 181: "SODIMM_75" unused input active-high
line 182: "SODIMM_115" unused input active-high
line 183: "SODIMM_117" unused input active-high
line 184: "SODIMM_142_1" unused input active-high
line 185: "SODIMM_140_1" unused input active-high
line 186: "SODIMM_138_1" unused input active-high
line 187: "SODIMM_136_1" unused input active-high
line 188: "SODIMM_134" unused input active-high
line 189: "SODIMM_100" unused input active-high
line 190: "SODIMM_102" unused input active-high
line 191: "SODIMM_104" unused input active-high
line 192: "SODIMM_92_1" unused input active-high
line 193: "SODIMM_90" unused input active-high
line 194: "SODIMM_88" unused input active-high
line 195: "SODIMM_86_1" unused input active-high
line 196: "SODIMM_97" unused input active-high
line 197: "SODIMM_79" unused input active-high
line 198: "SODIMM_103" unused input active-high
line 199: "SODIMM_101" unused input active-high
line 200: "SODIMM_96" unused input active-high
line 201: "SODIMM_98" unused input active-high
line 202: "SODIMM_156" unused input active-high
line 203: "SODIMM_99" unused input active-high
line 204: "SODIMM_164" unused input active-high
line 205: unnamed unused input active-high
line 206: unnamed unused input active-high
line 207: unnamed unused input active-high
line 208: unnamed unused input active-high
line 209: unnamed unused input active-high
line 210: unnamed unused input active-high
line 211: unnamed unused input active-high
line 212: unnamed unused input active-high
line 213: unnamed unused input active-high
line 214: unnamed unused input active-high
line 215: unnamed unused input active-high
line 216: "SODIMM_192_1" unused input active-high
line 217: "SODIMM_49_1" unused input active-high
line 218: "SODIMM_51_1" unused input active-high
line 219: "SODIMM_53_1" unused input active-high
line 220: "SODIMM_166" unused input active-high
line 221: "SODIMM_168" unused input active-high
line 222: "SODIMM_170" unused input active-high
line 223: "SODIMM_172" unused input active-high
line 224: "SODIMM_47_1" unused input active-high
line 225: "SODIMM_190_1" unused input active-high
line 226: unnamed unused input active-high
line 227: unnamed unused input active-high
line 228: unnamed unused input active-high
line 229: unnamed unused input active-high
line 230: "SODIMM_24" unused input active-high
line 231: "SODIMM_94" unused input active-high
line 232: unnamed "LAN_RESET#" output active-high [used]
line 233: unnamed unused input active-high
line 234: unnamed "regulator-lan-v-bus" output active-high [used]
line 235: unnamed unused input active-high
line 236: unnamed unused input active-high
line 237: "SODIMM_69" unused input active-high
line 238: "SODIMM_65" unused input active-high
line 239: "SODIMM_22" unused input active-high
line 240: unnamed unused input active-high
line 241: unnamed unused input active-high
line 242: unnamed unused input active-high
line 243: unnamed unused input active-high
line 244: unnamed unused input active-high
line 245: unnamed unused input active-high
line 246: unnamed unused input active-high
line 247: unnamed unused input active-high
line 248: unnamed unused input active-high
line 249: unnamed unused input active-high
line 250: unnamed unused input active-high
line 251: unnamed unused input active-high
line 252: unnamed unused input active-high
line 253: unnamed unused input active-high
line 254: unnamed unused input active-high
line 255: unnamed unused input active-high
gpiochip1 - 9 lines:
line 1: unnamed unused input active-high
line 2: unnamed unused input active-high
line 3: unnamed unused input active-high
line 4: unnamed unused input active-high
line 5: unnamed unused input active-high
line 6: unnamed "regulator-1v8-avdd-hdmi-pll" output active-high [used]
line 7: unnamed unused input active-high
line 8: unnamed unused input active-high
Our current custom devicetree (beware this is WIP code!):
// SPDX-License-Identifier: GPL-2.0
/dts-v1/;
#include <dt-bindings/input/input.h>
#include "tegra30-colibri.dtsi"
#include "tegra30-cpu-opp.dtsi"
aliases {
rtc0 = "/i2c@7000c000/rtc@68";
rtc1 = "/i2c@7000d000/pmic@2d";
rtc2 = "/rtc@7000e000";
serial0 = &uarta;
serial1 = &uartb;
serial2 = &uartd;
serial3 = &uartc;
chosen {
stdout-path = "serial0:115200n8";
cpus {
#address-cells = <1>;
#size-cells = <0>;
cpu0: cpu@0 {
device_type = "cpu";
compatible = "arm,cortex-a9";
reg = <0>;
clocks = <&tegra_car TEGRA30_CLK_PLL_X>,
<&tegra_car TEGRA30_CLK_PLL_P>,
<&tegra_car TEGRA30_CLK_CCLK_G>;
clock-names = "pll_x", "backup", "cpu";
operating-points-v2 = <&cpu0_opp_table>;
#cooling-cells = <2>;
cpu1: cpu@1 {
reg = <1>;
cpu2: cpu@2 {
reg = <2>;
cpu3: cpu@3 {
reg = <3>;
thermal-zones {
tsensor0-thermal {
trips {
level1_trip: dvfs-alert {
/* throttle at 70C until temperature drops to 69.8C */
temperature = <70000>;
hysteresis = <200>;
type = "passive";
level2_trip: cpu-div2-throttle {
/* hardware CPU x2 freq throttle at 75C */
temperature = <75000>;
hysteresis = <200>;
type = "hot";
level3_trip: soc-critical {
/* hardware shut down at 80C */
temperature = <80000>;
hysteresis = <2000>;
type = "critical";
cooling-maps {
map0 {
trip = <&level1_trip>;
cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&actmon THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
/* Colibri UART-A */
serial@70006000 {
/delete-property/ dmas;
/delete-property/ dma-names;
/* Colibri UART-B */
serial@70006300 {
/* UART-D (UART-C/UART3 on NVidia) (Debug) */
serial@70006200 {
compatible = "nvidia,tegra30-hsuart";
/delete-property/ reg-shift;
/* GEN2_I2C: unused */
/* CAM_I2C (I2C3): unused */
/* EHCI instance 0: USB1_DP/N -> USBC_P/N */
usb@7d000000 {
dr_mode = "host";
usb-phy@7d000000 {
/* EHCI instance 2: USB3_DP/N -> USBH_P/N */
usb@7d008000 {
usb-phy@7d008000 {
clk16m: clock-osc3 {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <16000000>;
reg_3v3: regulator-3v3 {
compatible = "regulator-fixed";
regulator-name = "3.3V_SW";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
reg_5v0: regulator-5v0 {
regulator-name = "5V_SW";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
gpio: gpio@6000d000 {
gpio-line-names =
"", "SODIMM_121", "SODIMM_186", "SODIMM_184", /* GPIO-A.00 - GPIO-A.03 */
"SODIMM_146_1", "SODIMM_144_1", "SODIMM_30", "SODIMM_67", /* GPIO-A.04 - GPIO-A.07 */
"SODIMM_36", "SODIMM_32", "SODIMM_154", "SODIMM_56", /* GPIO-B.00 - GPIO-B.03 */
"SODIMM_59", "SODIMM_28", "SODIMM_55", "SODIMM_63", /* GPIO-B.04 - GPIO-B.07 */
"SODIMM_119", "SODIMM_81", "SODIMM_21", "SODIMM_19", /* GPIO-C.00 - GPIO-C.03 */
"SODIMM_196", "SODIMM_194", "", "SODIMM_43", /* GPIO-C.04 - GPIO-C.07 */
"", "", "", "SODIMM_86_2", /* GPIO-D.00 - GPIO-D.03 */
"SODIMM_92_2", "", "", "", /* GPIO-D.04 - GPIO-D.07 */
"SODIMM_76", "SODIMM_70", "SODIMM_60", "SODIMM_58", /* GPIO-E.00 - GPIO-E.03 */
"SODIMM_78", "SODIMM_72", "SODIMM_80", "SODIMM_46", /* GPIO-E.04 - GPIO-E.07 */
"SODIMM_62", "SODIMM_48", "SODIMM_74", "SODIMM_50", /* GPIO-F.00 - GPIO-F.03 */
"SODIMM_52", "SODIMM_54", "SODIMM_66", "SODIMM_64", /* GPIO-F.04 - GPIO-F.07 */
"SODIMM_149", "SODIMM_151", "SODIMM_153", "SODIMM_155", /* GPIO-G.00 - GPIO-G.03 */
"SODIMM_157", "SODIMM_159", "SODIMM_161", "SODIMM_163", /* GPIO-G.04 - GPIO-G.07 */
"SODIMM_165", "SODIMM_167", "SODIMM_169", "SODIMM_171", /* GPIO-H.00 - GPIO-H.03 */
"SODIMM_173", "SODIMM_175", "SODIMM_177", "SODIMM_179", /* GPIO-H.04 - GPIO-H.07 */
"SODIMM_89", "SODIMM_91", "", "SODIMM_130", /* GPIO-I.00 - GPIO-I.03 */
"SODIMM_87", "SODIMM_95_2", "SODIMM_132", "SODIMM_95_1", /* GPIO-I.04 - GPIO-I.07 */
"SODIMM_126", "SODIMM_44_1", "SODIMM_128", "SODIMM_68", /* GPIO-J.00 - GPIO-J.03 */
"SODIMM_82", "SODIMM_113", "SODIMM_111", "SODIMM_38", /* GPIO-J.04 - GPIO-J.07 */
"SODIMM_150", "SODIMM_152", "SODIMM_105", "SODIMM_107", /* GPIO-K.00 - GPIO-K.03 */
"SODIMM_106", "SODIMM_137", "SODIMM_135", "SODIMM_34", /* GPIO-K.04 - GPIO-K.07 */
"", "", "", "", /* GPIO-L.00 - GPIO-L.03 */
"", "", "", "", /* GPIO-L.04 - GPIO-L.07 */
"SODIMM_57", "SODIMM_61", "SODIMM_136_2", "SODIMM_138_2", /* GPIO-M.00 - GPIO-M.03 */
"SODIMM_140_2", "SODIMM_142_2", "SODIMM_144_2", "SODIMM_146_2", /* GPIO-M.04 - GPIO-M.07 */
"SODIMM_174", "SODIMM_176", "SODIMM_178", "SODIMM_180", /* GPIO-N.00 - GPIO-N.03 */
"SODIMM_160", "SODIMM_158", "SODIMM_162", "", /* GPIO-N.04 - GPIO-N.07 */
"SODIMM_23", "SODIMM_35", "SODIMM_33", "SODIMM_25", /* GPIO-O.00 - GPIO-O.03 */
"SODIMM_27", "SODIMM_37", "SODIMM_31", "SODIMM_29", /* GPIO-O.04 - GPIO-O.07 */
"", "", "", "", /* GPIO-P.00 - GPIO-P.03 */
"SODIMM_120", "SODIMM_122", "SODIMM_124", "SODIMM_188", /* GPIO-P.04 - GPIO-P.07 */
"", "", "", "", /* GPIO-Q.00 - GPIO-Q.03 */
"", "", "", "", /* GPIO-Q.04 - GPIO-Q.07 */
"", "", "", "", /* GPIO-R.00 - GPIO-R.03 */
"", "", "", "", /* GPIO-R.04 - GPIO-R.07 */
"SODIMM_73", "", "SODIMM_47_2", "SODIMM_190_2", /* GPIO-S.00 - GPIO-S.03 */
"SODIMM_192_2", "SODIMM_49_2", "SODIMM_51_2", "SODIMM_53_2", /* GPIO-S.04 - GPIO-S.07 */
"", "", "", "", /* GPIO-T.00 - GPIO-T.03 */
"", "SODIMM_133", "SODIMM_127", "", /* GPIO-T.04 - GPIO-T.07 */
"SODIMM_123", "SODIMM_125", "SODIMM_110", "SODIMM_112", /* GPIO-U.00 - GPIO-U.03 */
"SODIMM_114", "SODIMM_116", "SODIMM_118", "", /* GPIO-U.04 - GPIO-U.07 */
"", "SODIMM_45", "SODIMM_71", "SODIMM_85", /* GPIO-V.00 - GPIO-V.03 */
"", "", "", "", /* GPIO-V.04 - GPIO-V.07 */
"SODIMM_93", "SODIMM_44_2", "SODIMM_129", "SODIMM_131", /* GPIO-W.00 - GPIO-W.03 */
"", "SODIMM_75", "SODIMM_115", "SODIMM_117", /* GPIO-W.04 - GPIO-W.07 */
"SODIMM_142_1", "SODIMM_140_1", "SODIMM_138_1", "SODIMM_136_1", /* GPIO-X.00 - GPIO-X.03 */
"SODIMM_134", "SODIMM_100", "SODIMM_102", "SODIMM_104", /* GPIO-X.04 - GPIO-X.07 */
"SODIMM_92_1", "SODIMM_90", "SODIMM_88", "SODIMM_86_1", /* GPIO-Y.00 - GPIO-Y.03 */
"SODIMM_97", "SODIMM_79", "SODIMM_103", "SODIMM_101", /* GPIO-Y.04 - GPIO-Y.07 */
"SODIMM_96", "SODIMM_98", "SODIMM_156", "SODIMM_99", /* GPIO-Z.00 - GPIO-Z.03 */
"SODIMM_164", "", "", "", /* GPIO-Z.04 - GPIO-Z.07 */
"", "", "", "", /* GPIO-AA.00 - GPIO-AA.03 */
"", "", "", "", /* GPIO-AA.04 - GPIO-AA.07 */
"SODIMM_192_1", "SODIMM_49_1", "SODIMM_51_1", "SODIMM_53_1", /* GPIO-BB.00 - GPIO-BB.03 */
"SODIMM_166", "SODIMM_168", "SODIMM_170", "SODIMM_172", /* GPIO-BB.04 - GPIO-BB.07 */
"SODIMM_47_1", "SODIMM_190_1", "", "", /* GPIO-CC.00 - GPIO-CC.03 */
"", "", "SODIMM_24", "SODIMM_94", /* GPIO-CC.04 - GPIO-CC.07 */
"", "", "", "", /* GPIO-DD.00 - GPIO-DD.03 */
"", "SODIMM_69", "SODIMM_65", "SODIMM_22", /* GPIO-DD.04 - GPIO-DD.07 */
"", "", "", "", /* GPIO-EE.00 - GPIO-EE.03 */
"", "", "", "", /* GPIO-EE.04 - GPIO-EE.07 */
"", "", "", "", /* GPIO-FF.00 - GPIO-FF.03 */
"", "", "", ""; /* GPIO-FF.04 - GPIO-FF.07 */
/*nox-test1 {// this works but only static output
gpio-hog;
output-high;
pinmux@70000868 {
/* Colibri UART-D (Not default) */
uart3-rxd-pw7 {
nvidia,pins = "uart3_rxd_pw7",
"uart3_txd_pw6";
nvidia,function = "uartc";
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
sdmmc3-clk-pa6 {
Thanks and Regards,
Simon
