I am using colibri imx6 with voila plus for 7" display. (G070VTT01-AUO) . This display support DE mode only. It not have any vsync and hsync. How and where i can make changes to enable DE mode in imx6 (means which dtsi file and what parameter). my parameters are as attached.link text
Dear @deepakrajpoot
Thank you for contacting Toradex Community!
Please kindly refer to the following artcles to enable Vsync and Hsync for the Display with iMX6:
Hope this answer helps!
Janani
I had gone through this document. I am using linux(lxde). Where i make change to enable DE mode because support LCD with i have purchased for toradex do not have DE mode.
Dear @deepakrajpoot,
Thank you for your message. You could try the following to get your display up and running:
We advise you to set-up display configuration in U-boot (Display Output, Resolution and Timings (Linux) | Toradex Developer Center) and
saveenv. Please make sure to enter your display resolution and RGB (based on the bit), depending on the monitor. This shoudl solve the issue -
If the issue still persists, you can modify the file (
drivers/video/fbdev/mxc/mxc_lcdif.c) with the necessary vsync and hsync settings (from the monitor’s datasheet) and re-compile the kernel.
Thank you and regards,
Janani.
